Hi got tiny model s42sd-ydo5 when turning tv on 2 green light appear on buffer board then about 4 secs later hear a click and red light appears leaving only 1 green lit any help would appreciate
techman
  • 3130 Answers
SOURCE: Toshiba model 57H81
If you have zagged lines there are 10 small surface mounted capacitors you will need to change on the HYper Board. This is not an easy repair so alot of folks simply replace the hyper board. You will need a service manual to take this set apart and to get the proper part number. If you have no TV repair experience or do not know how to solder, as the hyper board has sheild arounfd it, you should play it safe and call out a pro to assist you in this repair. Good Luck
Posted on Mar 19, 2007
  • 8 Answers
SOURCE: 62 in. DLP Toshiba model # 62HM14
This just happened to me and it was the bulb. A fast easy way to check is to unplug your tv, remove the side door on the left side (left side if you are looking at the screen) and remove the 2 screws holding in the bulb case and remove. If there is glass in there and the wires are just hanging out inside the bulb, its done. Replace bulb and all is good again.
Posted on Jan 21, 2008
SOURCE: RCA- R52WH74
Just like the forum says; follow step by step and make sure to re-solder the FLYBACK and this will work! I had to pay a little more than $13 after shipping and cost of Fuse (about $5!!). Don't bother with local TV repairmen, the 10 or so I talked to are very rude and cocky people. Partstore.com was very helpful and quick with ordering, although I had to wait on a RCA Company backorder!! Thanks for the help!
Posted on Jun 12, 2008
shbuckler
  • 126 Answers
SOURCE: sony wega kp51 turns on for 3 secs than off w/ blinking red light
The flashes are fault codes. It means your system is faulty. If it is intermittent then it is more than likely a dust issue. Buy an air duster, spray out the back and restart. Should be fine
If it continues to play up then it will be a repair job
Posted on Dec 24, 2008
tvtek
  • 1284 Answers
SOURCE: I have a 56
I suspect you probably have a bad LED assembly. It could be either the red, green or blue that is bad and give you the same symptom. The problem is locating parts for it as it looks like the light engine is no longer available. I would have a technician look at the TV to verify this and what parts are needed for repair.
Posted on Nov 03, 2009
Toshiba regaza 37rv635db wont turn on
seems like capacitor problem, chack them and if thay have exploded replace them.
Aug 25, 2013 | Toshiba 37RV635DB Regza 37-inch Widescreen...
When I turn the set on green leds appear for about 30 sec then it swicthes to red stanby and flashes 5 times intermitently
May I know what is the exact model number of your TV, it is located at the rear cover, manual, and on the receipt. It will help diagnose accurately where the fault came from and confirm the blinking error code.
Jdvillanueva
Jan 11, 2012 | Televison & Video
TV won't stay on
One of two things can be the problem...one the bulb is bad...two the ballast is bad. If the bulb is not bad then the ballast is...it can usually be fixed by replacing a resistor on the board itself...it is labeled R3 and is a 1000 ohm resistor
Jul 25, 2010 | Toshiba TheaterWide 46HM84 46" Rear...
I have a 37" Philips (37PF9431D/37) flat panel tv. It won't power on. When you plug it in you can hear a click the green light stays on for a few seconds then goes out. I've checked the power board for bad...
i am having the same problem. My Phillips 37" 37PF9431D/37I LCD High Definition TV won;t turn on. When I press the power button i hear a click and the green light comes on for a couple of seconds and then the red light appears. I can;t figure it out. Did you find a solution?
May 20, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
Telly on but no sound orpicture
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is XL2100 you can find it here http://www.discount-merchant.com/Sony-XL-2100U-TV-Lamp-p/sony_xl-2100u_replacement_lamp.htm?Click=48173 .Have a blessed one!
Apr 20, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
My tv wont turn on
My LA40A550 Samsung HDTV is 4 months old. It is doing same. That is the red led blinking 2 sec on and then off for ever. No picture, no sound, nothing. just dark black screen. What to do ?
Mar 16, 2009 | Samsung LA40A550 40 in. HD-Ready LCD TV
D52W19 No pix, sound good - now green light blinks, no come on
First of all you need to find out which CRT leaked and replace it before any other repairs are done. The clear liquid is conductive and has done damage to the CRT board or boards.
Jun 15, 2008 | RCA D52W19 52" Rear Projection Television
Lg tv will not turn on, red light
i think your bulb is shot must be replaced
Dec 17, 2007 | LG 42PX4DR 42 in. Plasma TV
My tv wont turn on
I am having the same issue. I think it's the bulb.
Aug 04, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
100 people viewed this question
Top Televison & Video Experts
