My hp430 very often shut down itself says 'thermal shutdown' what is the solution?
As stated
  • 32,281 Answers
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Posted on Feb 16, 2012
Unexpected shut down
Good chances this is a thermal shutdown. if this is the case, the computer is shutting off to protect itself from permanent damage. if your OS is old enough (Snow leopard, I think) then the system logs show what caused the shutdown. it will give a number. anything other than a 0 or a 1 are bad. if I recall correctly 1, 5, 13 are thermal shutdowns. Newer OS's don't seem to show these codes. and Apple does not publish their meanings.
Dec 11, 2013 | Apple 13inch Economy MacBook laptop Intel...
Toshiba satellite p300 shutdown
You also should change the thermal paste. If you want to play games, please choose normal PC. I think you are asking too much from your laptop.
Apr 15, 2013 | Toshiba Satellite Computers & Internet
Notebook Crashes to PowerOff state when lid is closed
Running intense program with the lid closed will cause a sharp rise in temperature making the laptop hotter than it should be leading it into a shutdown. The second issue, windows should be shutdown properly rather than closing the lid, this makes the operational system unstable and will cause files to corrupt eventually.
May 23, 2012 | ASUS N82JQA1 14 HD Notebook Intel Core...
My laptop randomly shuts down when I'm using it. I've tried restoring it to the manufacturer's settings but that did not help. Also I cannot connect to the internet at times. I try...
How old is this laptop? What conditions have you been using it in? It is quite possible that the fan intake and also the internal vents have been clogged because of dust, this causes the laptop to be unable to sufficiently cool itself, thus causing thermal shutdowns. Check the vents and try spraying some compressed air in from the exhaust vent.
For the wireless problem, while the computer is starting up, rapidly press either Del, F10, or F2 to enter the BIOS setup. The correct key to press is actually displayed briefly on startup, before windows begins to load. In the BIOS, follow the guidelines given at the bottom of the screen and navigate to an option where you can select the default state of your wireless adapter (i.e. on or off). This is usually different for each computer, so clarifying and telling me your model would also help.
Jul 04, 2011 | Computers & Internet
Starts up not all the way then shuts down thermal shutdown put in new power surply
You didn't give us much detail but is the CPU fan running at all? This can also be caused by the lack of silicone heat-sink compound between heat-sink and cooling assembly. Over-clocking can also cause thermal problems.
May 01, 2011 | Dell Computers & Internet
The computer will just randomly do a windows shutdown and then restart. Cleaned, changed the power supply and still does it.
Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage. If the smart person keeps turning the computer back on and figures out a way to foil the protection, the unit is probably doomed. Once a unit shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot. The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated unit is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down. Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning. Check the CPU fan if it is spinning and also the CPU itself put thermal paste. So that the heat from CPU will absorbed by the heat sink.
Jan 19, 2010 | Dell Dimension 2400 PC Desktop
I have a lenovo laptop, 3000 G410. Recently it has a problem which it shut down by itself after I use it for 20 minutes. After the shut down, I turn it on and this time it work only 2 minutes and shut down...
This sounds like a overheating problem (a CPU thermal shutdown).
This is caused by a faulty fan or the heat-sink and fan is clogged with dust. Check the fan to see if it spins freely, if not replace the faulty fan. Check the fan/heatsink assembly and remove/vacuum the dust from these components.
Nov 08, 2009 | Lenovo 3000 Y410 Notebook
ACER ASPIRE 3000 gets power off after some time automatically
If the laptop shuts down by itself and deosn't boot up again after some time, then the problem could be an over heating problem. The CPU shuts down when it overheats (thermal shutdown) and it is usually caused by a faulty fan and or the fan and heat-sink is clogged with dust.
Check the fan and if it does not spin freely then replace the fan and or remove the dust from the fan and heat-sink assembly.
Oct 12, 2009 | Acer Aspire 3000 Notebook
Hp laptop random shutdown - overheat?
Your CPU is likely overheating. Very likely the thermal conducting material between the CPU chip and the heatsink may have shrunk and now impeades the thermal transfer.
You may need to remove the heatsink and put new thermal paste and perhaps copper shim to restore the thermal contact to the heatsink.
Jan 04, 2009 | Everex StepNote XT5000T Notebook
Computers & Internet Logo
David Payne
David Payne
