Question about Ovens
Whirlpool Oven Control Panel Thermal Fuse
You nicely described removing the trim to reach the control board. How to determine whether the thermal fuse; where is it - can it be replaced? Also if the panel needs replacment to you need control panel, membrane and touchpad or is it typically the control panel cirquit board?
  • cattledoglov Oct 30, 2008
    I guess we figured it can't be the fuse since after power off the board will reset although not for long, the display will disappear and beeps happen but the oven does stay running although we never chanced it for any length of time since with blank display don't know if it is controlling or not.
    What to change out the control panel, control assembly, control board or membrane switch or even have part called control elctronic??
  • 447 Answers
If the display is totally out it is likely the thermal fuse this is located where the wire connectors plug into the board it looks like a small resistor in a platic shrinkwrap type sleeve. test it with a continuity meter.
Posted on Oct 27, 2008
  • joey  shearer
    joey shearer Oct 30, 2008
    try and remove the main control (computer) off the console and look if the display panel is part of that computer or is part of the console. If its part of the board i would start by replacing that computer. If the display board is on the console and attaches to the other board in the previous step via a ribbon connector i would replace the console/membrane/control panel (should come as complete assy) although i dont know your exact model #
Whirlpool self cleaning oven Model RBD245 door will not open after self cleaning cycle
Whirlpools are notorious for tripping the thermal fuse on the back of the oven but there is a thermal fuse to the control board also on most electronic control models. It is a good chance you will need to replace both fuses.
Oct 04, 2014 | Ovens
Free fuse box diagrams
Parts #: W10317343
Substitution: WPW10317343 $145.98 at sears
Parts #: W10354052
Substitution: WPW10354052 $125.92 at sears
Part #: W10317347 front LED board $230 at sears
Many ovens have a bi-metal thermal fuse-also called a thermal limit switch-that protects the oven from overheating. The oven thermal fuse trips when the temperature in the oven gets too hot. After the thermal fuse trips, the oven won't heat. If the thermal fuse trips after the self-cleaning cycle, try resetting the fuse by turning off electricity to the oven, removing the exterior back panel, and pushing the reset button. If the fuse tripped during normal operation, replace it. If the problem persists, the electronic oven control board might require replacement. Reset the thermal fuse after replacing the control board.
Jul 15, 2014 | KitchenAid Ovens
Clean mode electric current went off was off 10mentis when it came back on oven didnt
I have a whirlpool double oven too and replaced the control board last year the problem started with a F06 code and would reset when I power cycled for a while until it completely quit. Changing the control board fixed that problem. I just used my self cleaning cycle recently and the oven went completely blank on the control panel. Power cycle didn't do any thing. I checked 2 of the thermal cutoff fuses that are shown on most of the parts listing but the problem was with one that is not shown. The link below will get you to the part I replaced it's the power feed to the control board. Turns out that the worst thing you can do to your oven is use the self clean feature. Oven Thermal Fuse
May 29, 2014 | Whirlpool GBD307PDS Electric Double Oven
Kitchenade
Kitchenaid is made by Whirlpool. They have had a problem with the self clean getting too hot and shutting down the control board thermal fuse. If you can access the control board. (power off) there should be a small inline thermal fuse attached to a connector usually on the far right of the control board. It is encased in a clear plastic tube. Test this for continuity. If it is bad replace this fuse and the display should come back on. They also have a thermal fuse on the back of the oven that usually goes out at the same time. If the oven and broil don't work after fixing the control board thermal fuse. then you will have to pull the oven out enough to take the back panel off and check this fuse.
Feb 09, 2014 | Ovens
Whirlpool oven stopped working after self cleaning
If the display still works but neither the Bake or the Broil elements wont heat up, it's likely that the Thermal Cutoff has opened and has not reset itself. This is a common problem after self Cleaning.
The fix is to replace the Thermal cutoff which requres you to pull the oven and remove the back panel to get at the thermal cutoff.
What happens is that in Self Clean, both Broil and bake elements are used and the oven gets so hot that the middle skin (between the oven liner and the back panel, where the thermal cutoff is mounted gets so hot the thermal cutoff operates. It should reset itself but sometimes doesn't and then you have to replace it.
Nov 17, 2009 | Whirlpool RBS305PD Electric Single Oven
How do I get into the fuse to change it on my whirlpool GBD307 PDQ7 oven? Where is it located?
There are different fuses, a fuse is located on control assembly board, a thermal fuse is accessible removing a panel at the back of the oven, or inside the oven.
Enter here to find assembly diagrams and parts for your model.
Contact the seller by phone if part is not listed on the website.
Jan 02, 2009 | Whirlpool GBD307PDS Electric Double Oven
Whirlpool electric oven problem
thermal fuse to board blows, relays turn fans off, the thermal cut out on rear of oven kills element. change both fuses, install new style oversized blower.
Sep 22, 2008 | Ovens
Whirpool rbd275yPDT11 no power after auto clean
I printed down the installation sheets. I could not locate the thermal fuse on the control panel (which was the easiest to get to without removing the oven) so I went ahead and removed the oven. The upper and lower thermal fuses were fine. I put in back into the wall and my husband found the control panel thermal fuse--it was in-line--so we tested it and it was bad. I could not find anyone online that carried this fuse-or even knew the name of it. After much hard work we finally got the info off it--Microtemp KLBALY G4A00 TE 110C. Nowhere could I find a replacement except for something I am hoping is comparable online at Goodman (?). So while I am waiting for the fuse, I went to Radio Shack who had a thermal inline fuse rated at 128C for coffee pots and hair dryers. Also got some fully insulated crimp on connectors. Hooked it up and it works--havent cooked yet--to do cookies soon to test it. So far it seems like everything is running ok. I WILL NOT EVER USE THE AUTO CLEAN again. I dont get why the company has let it lie without helping unknowing consumers
Jul 05, 2008 | Whirlpool GBD307PDS Electric Double Oven
Control Panel
Yes actually i do..... open the lower oven door next to the hinges are 2 small phillips screws, securing two long metal side trim pieces. remove trim. Exposes two more phillips screws Control lifts up and off then Make sure unit has been powered down !!!!!!!!! If the old control is totally blank there is a thermal fuse that has gotten too hot. PLEASE rate my solution...Thank you
Oct 02, 2007 | Whirlpool RBD245PDS Electric Double Oven
Ovens Logo
2,161 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
