Question about Samsung SCX 4521F All-In-One Laser Printer
Recently i found there are some problem with my all-in-on system. receiving incoming fax in the memory, displaying
  • 360 Answers
Problem is your toner level is very low.replace new cartridge or refill it.
Posted on Feb 19, 2012
3 Suggested Answers
SOURCE: samsung scx-4521f fax memory received but never print out.
I am having the same problem, the manual says it should print out itself. However this is not the case... I installed the disc that came with the machine, however no luck. It appears we may have to take it to the repair facility.
Posted on Oct 25, 2007
Evildice
  • 222 Answers
SOURCE: recently i found there are
you have to enter in Tech mode to fix this
type "Menu" + # + 1394 in row.
Then use arrows to enter fax settings and print all your faxes
Good Luck!
Posted on Jun 30, 2010
MY FAX MACHINE CAN NOT RECEIVE FAX FROM OTHER, THE DISPLAY IS FAX MEMORY FULL, HOW TO SOLVE?
This means that your fax is only storing into its internal memory and not printing all incoming faxes, therefore it has no more space for more incoming documents, you should print the documents and maybe you'll need to clear the memory, depending on fax machine, this is done automatically when the documents are printed, and of course, set the incoming faxes to print not to store, this feature is supposed to be used only when the fax has no paper to print.
Mar 15, 2011 | Computers & Internet
HP laserjet 1020 fax incoming fax, machine
hp laserjet is not a fax.It is only a printer.
Dec 09, 2009 | HP LaserJet 1020 Printer
On my Canon MX310, the display says "Waiting for Report". Fax Memory is clear, but the In Use/Memory light stays on.
Try this step ... found it on Canon's website
Issue: ERROR LCD: WAITING FOR REPORT
Solution: Set [AUTO PRINT RX] to ON (MX300 / MX310)
AUTO PRINT RX When [AUTO PRINT RX] is set to [OFF], incoming received faxes will be temporarily stored to memory and transaction reports (TX, RX and Activity) remain in memory. The default setting is [ON], which means incoming received faxes and transaction reports will automatically print. The fax machine will not automatically print a received fax and will store it in memory in the following conditions.
  • Ink is low or has run out
  • The paper size and type is not set correctly
  • Paper has run out
  • The Output Tray is closed
To set AUTO PRINT to ON, please follow these steps.
  1. Press the <FAX> button to enter the Fax menu.
  2. Press the <Menu> button. [FAX SETTINGS] is displayed
  3. Press the left or right arrow button to select [RX SETTINGS] , then press <OK> two times.
  4. Press the left arrow to select [ON], then press <OK>.
    Note: When AUTO PRINT RX is set ON, a sub-menu will appear to PRINT WHEN NO INK.
  5. At sub-menu PRINT WHEN NO INK, decide if you'd like the machine to continue to print incoming received faxes if ink is low.
    CAUTION: When this option is set ON, the fax machine will not monitor the ink level of the ink cartridges. If ink is low or out, received faxes will print with streaks or blank. Furthermore, once the fax is printed, it will be deleted from memory.
    1. To print received faxes when ink is low or out, press the left or right arrow to select [ON] and then press <OK>.
    2. To store received faxes in memory when ink is low or out, press the left or right arrow to select [OFF] and then press <OK>.
  6. Press the <Stop/Reset> repeatedly to return to Fax standby mode.
Nov 17, 2009 | Canon PIXMA MX310 All-In-One Printer
CAN THE MEMORY BE LEAGNTHED ON HP1020 TO HOLD IN MEMORY MORE FOR INCOMING FAXES OR ELIMATE HOLDING RECEIVE FAXES AND PRINT PAGES AS THEY ARE RECIEVED INSTEAD.
I found the manuel on line and found out how to print the faxes in memory to release the memory. So next time a big fax comes thru I will try to print and release faxes from memory.
Nov 13, 2009 | HP 1020 Plain Paper Thermal transfer Fax
How can i generate incoming call report ?
To print a report:
  1. Press the [Menu] button on the Control Panel, until Reports is displayed on the top line of the Display Screen. The Phone Book menu item will be displayed on the bottom line.
  2. Press the right or left arrow button to scroll until the report or list you want to print is displayed on the bottom line.
    • Phone Book: Phonebook list
    • Sent Report: Sent fax report
    • RCV Report: Received fax report
    • System Data: System data list
    • Scheduled Jobs: Scheduled job information
    • MSG Confirm: Message confirmation
    • Junk Fax List: Junk fax number list
  3. Press [Enter] to print the selected information.
Your machine can print reports containing useful information. The following reports are available:
  • Phonebook List: This list shows all of the numbers currently stored in the machine's memory as Speed Dial and Group Dial numbers. You can print this phonebook list using the [Phonebook] button.
  • Sent Fax Repor: This report shows information of the faxes you recently sent.
  • Received Fax Report: This report shows information of the faxes you recently received.
  • System Data List: This list shows the status of the user-selectable options. You may print this list to confirm your changes after changing any settings.
  • Scheduled Job Information: This list shows the document currently stored for Delayed faxes or Toll Save faxes. The list shows the starting time and type of operation.
  • Message Confirmation: This report shows the fax number, the number of pages, the elapsed time of the job, the communication mode, and the communication results. You can set up your machine to automatically print the message confirmation report after each fax job.
  • Junk Fax Number List: This list shows up to 10 fax numbers specified as the junk fax numbers by using the Junk Fax Setup menu. When the Junk Fax Barrier feature is turned on, incoming faxes from those numbers will be blocked. This feature recognizes the last 6 digits of the fax number set as a remote fax machine’s ID.
  • Multi-Communication Report: This report is printed automatically after sending documents from more than one location.
  • Power Failure Report: This report is printed out automatically when power is restored after a power failure, if any data loss occurs due to the power failure.
NOTE: The lists you have set to automatically print out will not print out when there is no paper loaded or a paper jam has occurred.
Aug 04, 2009 | Xerox PE120i Laser Printer
When i receive fax,my samsung 4216f didn't print it just save it in momery
receiving incoming fax in the memory, displaying "memory received" but never print out.
I wonder if there is a way to retrieve fax from memory and print out manually?
Feb 22, 2009 | Samsung SCX-4216F All-In-One Laser Printer
Samsung scx-4521f fax memory received but never print out.
In 3 second make combination on you Samsung 4521F 'Menu'-#-1-9-3-4. You will enter in tech menu. Select 'toner'-new toner-yes. You will receive faxes. It really works.
Oct 24, 2007 | Samsung SCX 4521F All-In-One Laser Printer
Receiving faxes
The memory may be corrupted which is affecting the it receiving incoming faxes - to clear the memory: 1. Press the Menu/Set and Fax Resolution keys in this order. 2. Press the 0 key. 3. Press keys 91 (Parameter Initialise will appear in the display)
Sep 07, 2007 | Brother MFC-3220C Plain Paper Inkjet Fax
Samsung SCX 4521F All-In-One Laser Printer Logo
97 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
