Question about Toshiba Satellite L505D Notebook
When i restore to factory settings it freezes
I have tried to set back to factory settings but when it gets to config part it freezes
  • warealecia
    warealecia Feb 20, 2012
    yes it worked fine before then i logged on and it started freezeing up thanks
  • 3 Answers
Possible driver problem. If its a laptop check if u have all drivers installed. Graphic driver can cause this as well as possible bad video card. Was it working fine before??
Posted on Feb 16, 2012
ginko
  • 19396 Answers
SOURCE: restore factory settings
You need to do a new windows setup, erasing completely existing system. I do not know if you can do this from Vista upgrade. You may need to install from a bootable Windows setup disk first, and then install vista upgrade. Once you install the system you may need to download drivers. Here is Toshiba drivers page.
regards.
Posted on Mar 04, 2008
rtrahan
  • 741 Answers
SOURCE: how to restore factory settings
Best bet is to do a system restore to a date before you have problems. Go into start>accessories>system tools>system restore. Your computer automatically creates restore points each time you log on..so once you are in system restore just pick a date that was before you had problems and your system will restore itself to that date...if you have any questions let me know..there are other options if that does not work so keep me updated..
Please rate with 4 diamonds.
Posted on Mar 06, 2009
kbdesign
  • 370 Answers
SOURCE: restore factory settings on toshiba satellite S1800-3545 laptop
You can follow LavaTech's instructions to set the machine to boot from the cd, and you can load any retail version of windows. You will have to go to http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Product%20Support
to download and install the device drivers.
Posted on Mar 18, 2009
lukem9962
  • 144 Answers
SOURCE: how do I reset a Toshiba Satellite Laptop to its
you use the backup disk or purchase a windows installation disk please rate if i helped
Posted on Feb 12, 2010
etaf
  • 779 Answers
SOURCE: how do i restore my toshiba p300-172 back to
a couple of ways to do that 1) if you have the recovery CDs supplied with the PC - then you can use these - put the CD into the drive and when it boots follow the instructions 2) If you have a recovery partition on the laptop - have a read here to see if you have one http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/outFrm.jsp?ofId=AskIris&searchString=recovery+to+factory 3) This link shows you how to use the partition http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/bulletinDetail.jsp?soid=2291088&pf=true basically as the PC boots TAP F8 key - from the menu that appears choose "repair your computer"
Posted on Mar 22, 2010
Testimonial: "tnx i just remembered it never came with a recovery cd but it did come with toshiba recovery disc creator, might give it a try wen i get some cd's."
Reset to default config
Try by pushing the reset button behind your router, it will restore to factory level setings.
Mar 11, 2014 | Computers & Internet
How do i restore a diablotek elite atx mid tower to factory settings
Cases don't have "factory settings." This sounds like a problem with the motherboard configuration. Make sure to re-check all your pin connectors leading to USB, Audio, and HD. Also, you may need to remove the MB to check if there's any damage, and to be sure that you don't have a short somewhere.
Jan 14, 2013 | Diablotek Elite 450W PSU ATX Mid Tower...
Whenever i put on my hp mini,it says smart disk error. whenever i try restoring back to factory settings, it freezes up when it gets to 2 percent. after waiting a while it says the system fails to restore,...
Smart Disk Error has something to do with the Hard drive of your computer. I think the reason it's showing the message is that your Hard drive is about to fail. If restoring it to factory settings freezes on the same point every time chances are that part of the hard where the data is stored is busted (unreadable) better do what it says to contact hp so that they can conduct hardware diagnostics on your hard drive. Better yet, have it replaced if it's still under warranty.
Hope this helps!
May 19, 2011 | Computers & Internet
How can i reset Encore enRTR-104 router to default factory settings? When i push the reset button after few seconds begin the light nr. 4 faster to blink. When i release the button - the reset is done in...
I found these instructions for resetting the router to the defualt settings:
Use the "Backup Settings" tool to save the Broadband Router's current configuration to a file named "config.bin" on your PC. You can then use the "Restore Settings" tool to restore the saved configuration of the Broadband Router that you set before. Alternately, you can use the "Restore to Factory Defaults" tool to force the Broadband Router to perform reset and restore the original factory settings.
􀁺 Restore Factory Default
To restore the factory default settings of the Broadband Router, click on the "Restore" button.
􀁺 Backup Settings
Press the "Backup Settings" button to save the current setting in a filed "config.bin" or given filename.
􀁺 Restore Settings
To restore the backup file to the Broadband Router, enter the path and filename on the restore settings.
You can find the manual here:
http://www.encore-usa.com/us/support/ENRTR-104
May 05, 2011 | Encore ENRTR-104 Router
I need to do a System Restore on a Gateway 7322 Laptop
try running this virus FREE prog No cost- removes too...: http://www.f-secure.com/en_EMEA/security/tools/online-scanner/
Jun 29, 2010 | Gateway 7322GZ Notebook
My gateway gt5058 desktop got a trojan virus that caused the computer 2 freeze up.. we keep useing the factory restore setting and not having any luck in getting windows to come back up... we keep getting...
press f8 and go to last good boot up config...if sucessful then run a virus/trojan remover prog....if not sucessfull I would just do a clean windows install gl
Dec 12, 2009 | Gateway GT5058 Desktop PC
How can i format my nokia 6300 (china phone) also memory card?
You may try these.
default user code: 1122, 3344, 1234, 5678
Engineer mode: *#110*01#
Factory mode: *#987#
Enable COM port: *#110*01# -> Device -> Set UART -> PS Config -> UART1/115200
Restore factory settings: *#987*99#
LCD contrast: *#369#
software version: *#800#
software version: *#900#
set default language: *#0000# Send
set English language: *#0044# Send
set English language (new firmware): *#001# Send
Dec 07, 2009 | Nokia 6300 Cellular Phone
DES-3226L A1
Log in to the switch as an administrative user (using the login command).
You can type the following command:
reset {config|system}
If you type "reset config" all of the factory default settings are restored on the switch except for the IP address, user
accounts, and the switch history log.
If you type "reset system" all of the factory default settings are restored on the switch.
If you just type "reset" by itself, the switch’s current IP address, user accounts, and switch history log are retained. All other
parameters are restored to their factory default settings.
Jun 20, 2008 | D-Link DES-3226L Networking Switch
Text freezes
I dont no of this problem and dont really have a official suggestion but .. if you restore factory settings there is a strong chance it will repair it , you can acces factory settings on settings , . the code for it will either be 1234 or 12345 or something along the lines of that,.
Oct 18, 2007 | Motorola Mobility L6 Cellular Phone
Toshiba Satellite L505D Notebook Logo
75 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
