Question about Air Purifiers
Technical manual for pharmacia biotech ultrospec 2000
All i need is the technical manual of the said machine
My pharmacia biothec ultrospec has no carousel rotating which i got only from an auction, is there really any model with only one cuvette slot and which does not rotate? if not, where i can but this carousel type accesories for the said spectrophotometer, any technical manual pls?
Posted on Aug 25, 2012
Bought a 2000 grand am, need to change spark plugs. any help appreciated
Frankie, See how to change the plugs on your Grand AM. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Spark Plug Wires Remove Replace How to Pontiac Grand Am
remove and replace spark plugs
How to change spark plugs on 2000 Grand Am ShopYourWay
List Spark Plug 2000 Pontiac Grand Am Reilly Auto Parts
Jul 11, 2016 | Spectre 2000 Pontiac Grand Am - 2.4L...
How to replace the rear parking brake cables
remove the old ones with care and then put the new ones in place . this is not an easy task suggest you buy a repair manual before starting so you have guide when needed
Jun 29, 2015 | Spectre 2000 Ford Econoline - E250, 5.4L...
Kenmore Sewing Machine
What machine do you need a manual for? I have several manuals and may have what you need.
Mar 06, 2014 | Kenmore 85254 Air Purifier
Oreck Air 12GU Instruction Manual
First of all, thank you very much Joe for choosing FIXYA today for your online technical support needs.
Here is a direct link to the ONLINE USER'S MANUAL for that model:
http://www.oreck.com/PUG/Air-ProshieldPlus-AIR12GU-userguide.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted section of text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Jan 31, 2012 | Oreck XL Professional Air Purifier
Can I get an owners manual for Hunter 30525 air purifier?
Yes, manuals are available from Hunter Air Technical Support. Call: 888-830-1326
Be sure to have the correct Model Number handy, when calling. As some models have been discontinued, but are still supported by Hunter Air.
Hope this helped you.
Apr 21, 2011 | Hunter HEPAtech Air Purifier and Ionizer -...
I cleaned my Flair air purifier, The motor turns on but not the fan even after lubricating the fan shaft and giving the fan blades a little push. Any suggestions on how to get this going?
The Flair is no longer manufactured nor serviced by EcoQuest, and the company is now Vollara. If what you're hearing is the fan motor (there is no other motor associated with this machine), it might mean that either it's totally seized up, or that the oil just has not penetrated deeply enough.
1) Turn the machine over and remove the large screw in the bottom. The chassis will then slide out (I assume you've already done this in order to reach the fan shaft.)
2) Firmly pull on the fan blades near the center in order to pull them free of the shaft.
3) Turn the chassis on its back, so the fan shaft points up. Drip a small amount of lightweight oil (sewing machine, hair clipper, 3-in-1) on the shaft and turn it manually to work the oil down the shaft. Continue doing this if you feel the shaft loosening up.
4) Set the chassis upright, tilt it forward, and drip a small amount of oil on the rear opening to the fan shaft. Continue manually turning the shaft and tilting the machine to work the oil in.
5) Replace the fan blades and turn on the machine, depressing the safety switch manually, to see if the fan will begin to turn.
If it won't turn, it might mean that the fan motor is entirely seized up. You may be able to find a local small appliance repair person who could replace that motor.
Your other option is to call Vollara customer service at 800-989-2299 and ask them to explain your options. Use #16618 if you need a dealer referral number.
Feb 11, 2011 | Ecoquest Flair Air Purifier
I replace my uv bulb and now have no power
Some connection has not been firmly made, or the little safety switch at the back of the machine was accidentally pushed.
1) Check the back plug and make sure it is inserted FIRMLY. Does the machine work now?
2) If not, check the little switch in the back with the 0/- markings. Make sure it is depressed to allow power to the machine (try it after checking the plug.)
3) Check the fuse.
4) Unplug the machine and go back in to make sure the UV bulb is firmly inserted. It needs to be turned so that it "clicks," or "seats" correctly at both ends.
If none of these steps work, go through your Owners Manual step by step, checking all connections and wires. Make sure nothing is visibly loose, corroded, or broken. An owners manual is available at http://www.vollara.com or call Vollara customer service at 1-800-989-2299
Jan 29, 2011 | Ecoquest Fresh Air Living Air Purifier
I took it apart nd cleaned everything. I turned it on and it has been running on maintenance since this afternoon, at least 8 hours. I don't think it finished. There were only 2 bars showing. I tried...
Owners manuals are available from Vollara (the new name for EcoQuest). Call the company at 1-800-989-2299.
Maintenance means that something needs to be done to make the machine workable. It doesn't "maintain" or clean itself up over a period of time. Evidently some part was not replaced or was inserted incorrectly.
"Add plate" means that the machine needs the 4" square white plate with the screen center inserted into the machine. It needs to be put in so the top and bottom of the plate follow the "tracks" or slots, into the machine. It may be inserted incorrectly so the machine does not detect it. That would appear to be the problem.
Jan 22, 2011 | Ecoquest Fresh Air Air Purifier
UV100E Ultraiolet system. Noticedbulb not coming
Honeywell has a great team of technical support personell, just call the number on your owners manual.
Jan 14, 2010 | Honeywell Enviracaire Elite F300E-1019 Air...
My front control will not function. I have lost my remote. I have serviced, cleaned the unit several times but the unit always comes bak on and tell me it need normal cleaning . I cannot clear the display....
If the front control does not function, you can not clear the perform cleaning message from the display.
Contact the dealer whom you bought the machine he/she should be able to help you. The machine has a 3 year warranty.
Otherwise, contact the manufacturer EcoQuest at 1-800-989-2299 and choose technical assistance from the menu. You will be guided through some trouble shooting and if needed you will get an RMA number so you can send your unit in for repair.
Nov 11, 2009 | Ecoquest Fresh Air Living Air Purifier
Air Purifiers Logo
516 people viewed this question
Top Air Purifiers Experts
Are you an Air Purifier Expert? Answer questions, earn points and help others
