Question about Kitchen Ranges
How to change the red bulb on a Challenge 2kw black micro stove
2 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: light does not work even after changing the bulb
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or stuck in "night light" mode. Sometimes this will similarly affect the fan operation or inside light, too.
NOTE: The FixYa system is not currently notifying me when folks reply to my posts, so please contact me directly for more information or to arrange repairs.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 11, 2009
How do I make my low tire light go out? I have had sensors changed, tires changed and aired up. have had reset several times, but light still stays on. how can I make it stay off?
Small piece of black electrical tape carefully located is the easy way, or if you like a challenge you could remove the offensive bulb.
Jan 30, 2015 | 2010 Ford Focus 2.0
HOW TO REPLACE BULB ON DIMPLEX CLUB STOVE HEATER
On the back of the stove, you will see a rectangular access panel near the bottom of the stove. If you remove that, you will have access to the bulbs. They are 60 watt, small base chandelier bulbs.
Hope this helps you change the bulbs.
Mar 28, 2011 | Heating & Cooling
I have an electric stove that has 1 black, 1 red
Since 1996, the NEC has required that all stoves and dryers be wired with a 4 wire configuration; 2 hot wires (red/black - supplies 240 volts), the bare green ground wire and a white neutral wire. Before you do anything, review this article which speaks to the 3-wire/4-wire arrangement. Good luck!
http://www.hammerzone.com/archives/elect/appliances/range1/cord/4_wire.htm
Mar 09, 2010 | General Electric Stove/Oven/Range Chrome...
Stoves precision 1100 operators manual
I need to change the bulb in the fan part of my Precision 1100 Stoves oven but I have lost the manual. How do I get access to change the bulb?
Sep 15, 2009 | Stoves 1000DFDLm Gas Kitchen Range
I need to install a kenmore range. the wires coming from the range are red, white, black, and green. The wires coming from wall are black, white and copper. How do I connect the wires?
Hello, Here's how to hook it up:
Black from wall to black at stove.
White from wall to red at stove.
Copper from wall to white and green at stove.
Hope this helps. --W/D--
Jul 31, 2009 | Kenmore Kitchen Ranges
Just purchased new electric stove. The old stove had been hard wired. Black, white and copper. The new stove is asking to connect red, white and black. what should i do ?
Normaly black, white, copper (ground) is a 2-wire 110 volt, black white, red, copper is a 3-wire 220volt circuit. You must have a 3-wire cicuit run from circuit breaker box to stove connector.
Apr 28, 2009 | Kitchen Ranges
Cooktop WIring
To complying with changed Codes (effective in 2002 ) regarding stoves, ovens and dryers. You will need a 120/240 volt 4 wire 40 amp and 50 amp circuit. This
Decades ago it was permitted to use a 3 wire system (having two 120 volt hots (Black and Red) and 1 combination ground/neutral wire) (green and white) to serve stoves, cooktops, ovens and dryers.
The Code change now requires all stoves and dryers in NEW construction to have the 4 wire set-up (now having two 120 volt hots, 1 white neutral and one green or bare wire ground).
Existing wiring is grand-fathered under the Code change.....I advise you to change the feed wiring over to the the 4 wire set-up...
because - as with ALL Code changes in the past...it will eventually become mandatory for all stoves, ovens and dryers as the grand-father clause drops off. By complying now...
BUT the wiring will need to change to 8/3 with ground. (having 4 wires inside one outer jacket).This is the primary reason for the Code change....to provide a greater margin of safety to the user.
I can NOT recommend the 3 wire hook-up...the 4 wire provides a seperate ground and neutral -
which makes the chance of a user shock when touching the metal frame (from an internal fault in the oven) much less likely then the old 3 wire set-up....
which did NOT have the seperate ground and neutral.
Krazytech
Apr 05, 2008 | Whirlpool 30 in.GJC3055 Electric Cooktop
Kitchen Ranges Logo
20 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
