Question about Mercury P4VM800M7 Motherboard
TK66 PRO (MS-6300) MSISock AVT866 Motherboard Drivers
CD & DVD do not work
  • Mercury Master
  • 27,725 Answers
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
or
or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
hope this helps
Posted on Feb 17, 2012
Need scsi/raid drivers on floppy to install winxp pro (at f6 prompt)
Hello the drivers can be downloaded here:
http://www.tyan.com/support_download_drivers.aspx?model=S.S2865
You need to unzip the file before you install the driver.
It should not be nessesary to install drivers before installing the windows system.
Check your bios boot settings to boot from the cdrom or dvd drive.
The cd or dvd drive must be the first boot device in order to boot from the windows disk.
Install windows with only one harddrive.
You can also add a harddrive later, when the installation is done and all drivers is installed.
Good luck
Jun 20, 2013 | Tyan Tomcat K8E Motherboard
Diver/K7T266 PRO (MS-680) MSI Socket A VIA VT8366 motherboard
if these units are pata ( parallel ATA) units, make sure they are set as masters or slaves which do not conflict with any other items on the same bus or cable.
If you have the hard drive on the same bus, make sure it is set to master and the optical drive is set to slave.
If these are SATA units, try swapping them onto another drive bus.
If this fails, have the units checked on another PC. This will confirm that the units are good and working, if they are not detected on another PC, then they may be faulty.
If you are using Windows 7, check for an updated driver and install it as W7 has a habit of ignoring older peripherals.
Feb 14, 2012 | MSI K7T266 Pro MS6380 (MS-6380 V2.0)...
How do I get the drivers needed to make the DVD Movie Write DC3000 work on Vista?
HP does not make a Vista driver for your device. Here is their driver page for you unit:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=228&lc=en&cc=us&dlc=en&sw_lang=&product=327406
When you plug it into your PC, it should auto-discover it. While connected to the internet, reply YES to let windows search for a driver at MS. If it finds one, you should be ok. If it can't find one, I'm afraid it's not going to work.
There are drivers only for Windows XP and Windows 2000 Pro.
Dec 03, 2010 | HP DVD Movie Writer Dc3000 DVD+RW Burner
Does the Benq i221 have an inbuilt CD/DVD burner?
dear friend i did't see and cd/dvd burner. only these feture are present.
  • 21.5" 16:9 widescreen display
  • AMD Sempron 210U processor (1.5GHz/L2 256k)
  • Windows XP Home Edition or Linux Lite OS
  • ATI Radeon X1200 graphics
  • Memory: 1GB or 2GB (DDRII-667)
  • Hard drive: 120-250GB or 4GB-16GB SSD
  • Wireless LAN: 802.11b/g
  • 1.3MP webcam
  • Card reader: 4-in-1 (MS/MS-Pro/SD/MMC)
  • Optional keyboard/mouse & nScreen handset
  • Dimensions & weight: 454 X 361 X 61.37 mm, 4.6Kg
  • Jan 30, 2010 | Computers & Internet
    Sata on k7vt4a-pro. wont boot into windows with any dvd drive in sata plug.does motherboard support sata dvd drives
    not usually No.
    You need to setup the Pc with an IDE drive First. Then load The Sata drivers, usually on the setup CD. ( obtained with motherboard )
    Alternative, is to create a SATA/Raid boot Disk et,c.
    Mike @ compurepair.
    Nov 04, 2009 | Asrock K7VT4A-Pro Motherboard
    Drivers for Toshiba satellite A75-S226
    here ya go
    http://www.officialdrivers.net/toshiba-drivers.php?gclid=CJip5OKvpJsCFQ4MDQodWCAtCg
    Jun 25, 2009 | Toshiba Satellite A75-S226 Notebook
    Ms-7142 ver:1 audio driver i want a free download
    I've tried to find your driver but without results.. :/
    better try some professional tool like this one: Driver Update Software for XP Vista 7 8
    used it many times, and it's awesome.
    wish you best of luck
    Brian
    Aug 04, 2008 | MSI K8MM-V Motherboard
    I lost my installation CD! What Can I Do?
    Hi DUMi56, loacated somewhere on your case is a Microsoft CD key & the version of windows. You can use anyones windows CD that matches your version. Ex: Window XP home editio, XP pro edition or Media Edition. When it comes time to enter the cd-key you use your key printed on the MS sitcker. As far as drivers go Gigabyte only provides the needed *.inf files since windows supplies the rest. You can download all your driver software from the link provided below.
    http://www.giga-byte.com/Products/Motherboard/Products_Spec.aspx?ProductID=1385
    If you have a CD or DVD burner I suggest you burn the driver/inf file, manual & bios files incase you ever need them again.
    If I can be of more service, just ask.
    Good Luck & have a Great Weekend!
    Mike
    Mar 29, 2008 | Gigabyte GA-6OXT Motherboard
    Mercury P4VM800M7 Motherboard Logo
    41 people viewed this question
    Top Mercury Computers & Internet Experts
    Mark Gough
    Alun Cox
    vsri9
    Are you a Mercury Computer and Internet Expert? Answer questions, earn points and help others
