Question about Eureka Altima Upright Vacuum Model 2996AVS Vacuum
No manual how do i change the belt and the link is broken is there a new one for the manual
    Scholar:
  • 55 Answers
Take the hood off of the unit, and remove the brush roller and belt. Wrap the new belt around the shaft of the motor and slide the brush roller inside the loop of the belt. Use the brush roller as leverage to stretch the belt out and slide the brush roller back into the roller housing. Once you have it installed correctly, make sure the roller and belt are free, by spinning it by hand. If that belt is pinched it will just burn it up when you turn the unit on.
Good luck
Posted on Nov 24, 2008
I want to see a pictute of the bottom of the vacum cause is not working
Hello! If the brushes are not spinning your belt may be broken or stretched out. I have included steps to checking and replacing your belt. There is also a link to the owner's manual attached that shows you illustrations on how to change the belt.
  • Lay the cleaner flat and flip it to expose the nozzle base. Remove the 5 screws.
  • Pull and lift the nozzle guard off.
  • Inspect the belt for damages. (nicks, cuts, broken, stretched)
  • Replace the belt with a Dirt Devil style 15 belt.
  • Slide new belt onto motor-shaft.
  • Place belt on area of brushroll with no bristles.
  • With new belt in place, pull and slide brushroll into nozzle making sure that the brushroll end caps are in the correct orientation.
  • Reattach nozzle guard.
  • Secure by aligning the 3 tabs in the base slots.
  • Replace all 5 screws.
http://dirtdevil.com/file/956/
Hope this helps!
Oct 06, 2014 | Dirt Devil Easy Lite Quick Vacuum
Broken belt on infinity vacum
You may find the belt for your vacuum through the link below. Unfortunately the only way that Shark sells this belt is with both belts as a set, you can not purchase each indiviudal belt separately.
I have also uploaded the instruction manual for your vacuum in a .pdf file on Fixya. Please note that it may take sometimes up to 24 hours for the manual to show up. Please check the following link over the next 24 hours. This instruction manual gives you step by step instructions on how to replace the belt, and also contains diagrams that will help you follow along.
Here's the link where the instruction manual will be downloaded. The belt change instructions are on page 15:
http://www.sharkclean.com/manual/NV31_REV_0706.pdf
Here's the set of belts that go on the Euro-Pro Infinity Upright model NV31, Shark Part Number 1085F:
http://www.govacuum.com/eushrebesetf.html
I hope this was helpful to you in solving your belt problems. If this was helpful please rate the repair helpful by clicking on the thumbs up icons in the top right hand corner of the repair.
Thank you very much,
Chris Jones
GoVacuum
Mar 25, 2010 | Euro-Pro NV31 Infinity Vacuum
It won't pick up. I cleaned all of the filters. what next?
I would try changing the belt. A worn, stretched or broken belt can cause the vacuum to not pick up well. Here is a link to the belt you need and the manual which has instructions:
Bissell Lift-Off Revolution belts and manual
Nov 17, 2009 | Bissell LiftOff Revolution Pet Vac 37602...
Replace a broken belt
Here is a link to the owners manual which has instructions and a link to the belt you need.
Eureka Altima Owner's Guide
Eureka Altima Replacement Belts
Nov 15, 2009 | Vacuums
Not sucing
The reason it is not picking up is probably because the belt is stretched, worn or broken and is not turning the brush the way it should and therefore not picking anything up. You should change the belt on your model at least once a year. Here is a link to the belt you need and a link to the owners manual which has belt changing instructions:
Eureka Capture Replacement Belts
Eureka Capture Owner's Guide
Nov 08, 2009 | Eureka Capture Upright Vacuum Vacuum
Not picking up. suction okay on tools. I think belt is broken but how to get to it and change it?
Yes, you probably need to replace the belt. Below I have listed a link to the owners manual which has instructions on how to change the belt and a link to the replacement belt you need. Hope it helps you!
Nov 01, 2009 | Eureka Capture Upright Vacuum Vacuum
The brush is not working anymore
Your drive belt is probably broken. They usually need to be changed every 6 to 12 months. If you haven't replaced the belt recently I would try that. You can get the belts you need through this link and also view the manual which has step by step instructions on how to change the belt. hope this helps!
http://www.vacbelts.com/bissell-lift-off-revolution-pet-vacuum-belt-.htm
Oct 25, 2009 | Bissell LiftOff Revolution Pet Vac 37602...
Changing of belt
Step 1: Lower handle to floor to change belt
Step 2: Remove the two screws from the top hood on the foot
Step 3: Lift hood to remove
Step 4: Lift right end of brushroll (the belt end)
Step 5: Remove and discard belt.
Step 6: Place new belt around motor shaft.
Step 7: Place new belt around brushroll pulley.
Step 8: Align left end cap with base. Push end cap securely into
place. Make sure the square on the brushroll cap is in
place
Step 9: Pull right side of brushroll to stretch belt. Secure right
end cap into base.
IMPORTANT
Step 10: Rotate brushroll by hand several full rotations to properly
position belt.
Step 11: Place hood back on cleaner. Replace and tighten
two screws.
Step 12: Return vacuum to upright position.
You can also download your user manual here which has instructions on how with diagrams
Dec 24, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Eureka Altima Upright Vacuum Model 2996AVS Vacuum Logo
99 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Irene Tulloch
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
