Question about Dell Computers & Internet
No mice will work in my computer - Dell Computers & Internet
  • Dell Master
  • 27,725 Answers
Make sure the battery is good ((has full charge))also you make sure the usb device for the mouse is inserted correctly into the usb port (if applicable) or if its a lead
make sure the lead from the mouse has a secure seating and the lead is not bad/faulty
((if applicable)) if this fails to fix the problem you could try it in safe mode
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
click start control panel administrive tools computer management device manager scroll to mice and other pointing devices you might see a yellow exclamation mark ! or question mark ? or a red x right click to update driver
if your computer came with a motherboard disk the driver could be on it
hope this helps you
Posted on Feb 17, 2012
My computer cannot find driwer for my SIGMA SCM13 so how can i downoad them manualy
Visit the system manufacturer web site. Make sure you have noted the Model Number (or serial number) of your system to speed up finding the right drivers for you.
You should try first the "Chipset Drivers" for your system to properly identify and detect your hardware.
Jul 24, 2014 | Computers & Internet
Mouse quit working
Logitech wireless mice operate in a slightly different technological sphere to wired mice.
Wireless mice need batteries, they need to be turned on and they need an interference-free radio environment.
One advantage of wireless mice is that they tend to function with laser or optical parts rather than a ball and wheels, so there are fewer moving parts to go wrong.
However, optical and laser wireless mice have considerations to take into account.
Change the batteries in the mouse if the mouse doesn't work.
Remove the battery cover and insert new batteries.
On the underside of the mouse could be plastic sticker with a phillips head screw (star) under it
Turn the Logitech wireless mouse on with the switch on the mouse.
Plug the USB receiver into a USB jack on the computer.
Try to use a free jack that's actually on the computer rather than one that's in a hub.
Test the jack first.
Try plugging in a printer and see if the printer is recognized--that way you know the USB jack is good.
USB jacks are notorious in that you frequently get a bad jack on a computer.
Turn off devices that are in the same frequency range as the mouse.
Logitech wireless mice operate at 2.4 GHz, which is in the same area as Wi-Fi routers and older cordless phones.
Start by turning those devices off and see if you can eliminate any causes of interference.
Test with wireless speakers too, then computer power supplies, monitors, cellular telephones and garage door openers.
Place the mouse on a flat surface that doesn't reflect. Avoid metal surfaces too.
Apr 21, 2013 | Logitech Cordless Mouse
How do yoou connect a wireless mouse to your computer
Connecting a wireless mouse to your computer is a great way to reduce clutter around your workplace.
Also, it is an alternative to using your laptop's directional pad.
Wireless mice work just as well as wired mice for most computing needs.
The only detail that wireless mice lack compared to wired mice is the DPI (dots per inch) and the frequency rate, which is essential to the "fast twitch" movements in gaming.
However, most people do not need highly responsive mice; therefore, wireless mice are perfect for any other computing activity other than gaming.
Insert batteries into your mouse.
If your mouse is rechargeable, charge it in the docking station provided with the mouse.
Buy a wireless adapter that works with your mouse. If your laptop is enabled with wireless technology or Bluetooth, skip to the next step.
Install the drivers for your mouse.
Reboot the computer to apply the changes.
Power on the mouse and let the computer recognize the new hardware. If you are using a mouse that requires software to run, enable the mouse in the software that is provided to you.
Hope this helps
Nov 04, 2012 | Computers & Internet
Wireless mouse works on different computers at same time
i had this problem once. i had to use different brands. Also some brands offer different channels but usually they dont. Read the manuel and see if there is different channels. if not then i would go with different brands on each pc. thanks
Steven.
Apr 02, 2010 | Logitech Cordless Mouse
Optical mouse malfunction
try to restart one computer without a mice, and after this take a shutdown. When your pc is off, connect one mice and start your computer. Try all of your mice, if this is not work, then you should go to buy another mice.
Mar 04, 2010 | Dell Dimension 3100 PC Desktop
USB mouse doesn't work.
Some USB devises are not compatible with USB hubs. They usually specify that they must be plugged into a main USB. This may be the case with your mice.
Nov 06, 2009 | Belkin OmniView PRO2 4-port KVM Switch
Please introduce HP wireless Mouse and how to work
The mouse is an extremely popular technology to interact with your computer. While the majority of mice are connected directly to the computers peripheral input via a cord and are powered by the computers main power, wireless mice are becoming extremely popular to give computer users cordless accessibility to their mice and to interact with their computer.
Wireless mice usually work via radio frequencies commonly referred to as RF. RF wireless mice require two components to work properly a radio transmitter and a radio receiver.
RF- Radio Frequency
Jun 23, 2009 | HP Wireless Optical Mouse
No mice work on my computer!I installed a wireless mouse, and now no mice work, the wireless, and normal keyboard does. How do I fix the mouse socket?
if it is PS2 then you need to reboot your computer in order for the computer to detect the PS2 device ( the PS2 device needs to be plugged in before rebooting )
If USB then try a different USB port and also check bios settings to ensure all usb keyboard and usb mice settings are all enabled.
You could go into device manager and delete usb hub etc and let windows re detect and re install otherwise go to
http://www.usbman.com/WinME%20USB%20Guide.htm
His site has lots of other useful info
May 10, 2009 | Socket Communications Standard Keyboard...
Mouse does not work
did u try 2 other mice ?
Mar 31, 2009 | Computers & Internet
Computers & Internet Logo
20 people viewed this question
Alun Cox
