Question about Minolta Office Equipment & Supplies
Minolta di552 copier error message c0210
Error appears in the process of making a copy, mid way into the machine by the drum sction
  • Minolta Master
  • 6,161 Answers
Directly below the drum section is a assemble called the transfer/separation assy. the purpose of this unit is twofold. (It houses to very thin gold plated wires) One wire is what helps the transfer of the image from the drum to the paper. Since the paper goes between this wire and the drum, the second wire prevent the paper from sticking to the drum during the transfer process. The code you have been getting means either wire might be broke, or has to cleaned (because of all the toner on it from the drum assy. which need to removed and cleaned. Or The end blocks that hold the wires are getting old and allowing the High Voltage that is applied to the wire during the copy/print process are breaking down allowing the high voltage to ground. Open close the front door to clear. If it comes back have qualified tech look at it. Try web site below for place to start for parts
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Posted on Feb 20, 2015
SOURCE: changing the drum
I fixed the problem (following the user's guide).
1. After reinstalling the new drum unit into the printer, keep the front cover open.
2. Press "Clear/Back" on the machine
3. Press "1" and when the LCD shows "Accepted", close the front cover.
Posted on Aug 07, 2008
HobbesVT
  • 3 Answers
SOURCE: Drum life low replace soon Error Message
I already answered this at some other place here - but just to make sure the word gets out there:
There is a little special (white) gear on the outer left side of the drumkit - a little bit below where the toner sits. That gear joins with toner assembly - and you can rotate it counterclockwise all the way back. This should reset the drum counter - worked for me!
I hope it also does the trick for you ;-)
Posted on May 04, 2009
Cogz
  • 1326 Answers
SOURCE: The copies are coming out smeared and with lines. I wiped the (drum?) off?
What did you wipe the drum off with???? That is why you have this problem. You may want to try recleaning the opc with a dry soft rag, also you may want to clean the drum blade... If that dose not solve your problem, you may need to replace the opc & blade... Have you tried to stop the copy before it gets to the fuser unit.. If so, are the marks there???
Posted on Jun 03, 2009
SOURCE: Minolta 1030
ecrie probleme j3
Posted on Nov 27, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: I have a Minolta cs pro 2080 copier, shading on copies
3 possible causes:
1) The optics are dirty thus making your copy darker. The test for this is to manually lighten the copy using the exposure control on the panel of your copier. Lighten the copy several positions and see if the copy gets better. If it does then the optics need to be cleaned.
2) The copier is overtoned. This means that the toner to developer concentration is to high. This will require a trained technician to lower the toner ratio and then recalibrate the toner/developer ration using the F8 mode.
3) If the shading gets much worse as you run say 10 copies in a row then the drum cleaning blade would be the cause. So run 10 copies of something and compare the first copy out with the tenth copy out. Do you see a dramatic difference in the amount of background or "shading"?
Good Luck and thank you for using Fixya.
Posted on Mar 16, 2010
Error code c0200 minolta EP 4000
Sir, right below the drum area when you open the machine front door is a assy. with two very fragile gold plated wires that transfer the image from the drum to the paper. The paper moves over this wires during the copy process. They mite have broken giving you a C0200. Or the same type of wires are above the drum on the drum unit which must be removed to see them mite be bad. did you open close the front door to see if the machine will reset?
Jun 25, 2014 | Minolta EP4000/5000 CS/PRO Copier
ERROR CODE C 145 E FOR MINOLTA DIALTA
Sir, You have this problem listed under Di183 , Di3010 and Di552 First two have no code C145E Never heard of a Di552
Please give the Model number and code again does this have Fax option?
Apr 11, 2014 | Minolta Di3010 Copier
C220 error code& solution
C0210
Abnormal image transfer voltage
- The image transfer voltage remains more than 100 V continuously for a given period of time while the PC Drum remains stationary.
Mar 01, 2014 | Minolta bizhub 180 Black and White Copier
C0210 minolta di 450
Directly below the drum section is an assemble called the transfer/separation assy. the purpose of this unit is twofold. (It houses to very thin gold plated wires) One wire is what helps the transfer of the image from the drum to the paper. Since the paper goes between this wire and the drum, the second wire prevents the paper from sticking to the drum during the transfer process. The code you have been getting means either wires might be broken, or has to cleaned (because of all the toner on it from the drum assy. which needs to be removed and cleaned. Or two white end blocks that hold the wires are getting old and allowing the High Voltage that is applied to the wire during the copy/print process to leak to ground. Open and close the front door to clear. If it comes back have a qualified tech look at it.
try this site for parts
Feb 13, 2014 | Konica Minolta Office Equipment & Supplies
Hw do i fix error code c0210 on my minolta dialta di 552
Directly below the drum section is assemble called the transfer/separation assy. the purpose of this unit is two fold. (It houses to very thin gold plated wires) One wire is what helps the transfer of the image from the drum to the paper. Since the paper goes between this wire and the drum, the second wire prevent the paper from sticking to the drum during the transfer process. The code you have been getting means either wire mite be broke, has to cleaned (because of all the toner on it from the drum assy. which need to removed and cleaned. Or The end blocks that hold the wires are getting old and allowing the High Voltage that is applied to the wire during the copy/print process are breaking down allowing the high voltage to ground. Open close the front door to clear. if it comes back have qualified tech look at it.
Mar 09, 2013 | Minolta Office Equipment & Supplies
How to fix the C0210 Error on minolta dialta di1610?
The C0210 error code deals with the Primary charge unit... It is part of the drum unit. It may not be installed correctly or it is not in all the way..... Good Luck
Jun 06, 2012 | Office Equipment & Supplies
Error code c0210 on minolta 6001
The Transfer separation assy. Located below the drum has two fine wires in side of it that apply several thousand volts to the paper as it goes above the wires and below the drum to transfer image on to paper the second wire prevents the paper from sticking to the drum. Remove assy. see if they are broken or then the end blocks (white) need to be replaced because after a while the plastic breaks down an the High Voltage go thru the plastic to ground. Clean the wire very, very carefully with pencil earser if never been replace go to the web site below for corona wires don't lose those small springs at one end.
Apr 11, 2012 | Minolta Office Equipment & Supplies
ERROR CODE C0210
Below the drum is assy. that houses two very fine gold plated wires that do two things since the paper goes between these two wires and the drum the first is transfers the image on to the paper from the drum, the second one prevent the paper from sticking to the drum. One is or both are bad, BROKEN? Remove the assy. and replace both. They are very fine and fragile do not lose the springs. If that does not work you might have bad ends on the assy. after a while the plastic breakdowns and allow the voltage to go to ground. The wire carry around 2000 volts during the copy process. None during power off :) Open close the front door resets the code. if need new wire chk this web site
Jul 03, 2011 | Minolta DiALTA Di520 Laser Printer
We have a Minolta Di552 copier with an error message C-0F24 on the display panel. What is the problem?
Has the developer been replaced? If not reset counter for developer without replacing the developer is not good. Because the copier works based on the counters. If you reset the counters without replacing the require items then the copier will adjust certain voltages to certain items such as the drum and developer system as those they are new because you reset the counters when in fact he developer is old and so might be the drum which can cause codes and image problems. If the developer was replaced where the counters cleared !ST!!!!!!!!!!!!!!! and was the required F8 checked run? after installing. Also was the drum removed and the sensors cleaned by brush NO Vacuum cleaner. Static Electricty can destroy the the sensors.
Dec 22, 2010 | Minolta DiALTA Di350 Laser Printer
We have an error - C0210
k Normal 0 false false false MicrosoftInternetExplorer4 Transfer roller voltage problem
Jun 08, 2010 | Konica Minolta Di1610 Copier
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
