I found 1991 cincena radio cassette player model no 261 that looks like the dashboard of a 57 chevy. I want to replace the speakers and restore.how important is matching the same ohms for speakers.don't have originals. I'm giving it as a gift to my mother once it's working. My dad used to own a 57 chevy when they first met, same green
  • 6,771 Answers
It is important, most car speakers are rated at 4ohms, you can run 8ohms but only one per channel, there will be a slight drop in volume using 8ohms but it would fine.
Posted on Mar 06, 2012
What would cause lurching?
Bad coil, bad fuel delivery. Check there.
Mar 08, 2016 | OEM 1991 Chevy K1500 Pickup Radio / CD...
Do I need to drain the oil from my transmission when removing my transfer case?
USUALLY the transfer case is independent from the trani. do they have separate Drain plugs?
Mar 02, 2016 | OEM 1991 Chevy K1500 Pickup Radio / CD...
IT IS A FITTED RADIO CASSETTE PLAYER IN A FIAT PUNTO 2000.
The radio SERIAL NUMBER is required for a code First remove theradio from the dashboard. Then post the radiomake+model plus all the letters+numbers on any labels,barcodes or stamped in themetal casing. This information canthen be used to see if a code can be calculated
Apr 20, 2011 | Car Audio & Video
Makes a wining sound but plays no music on any
Hi, check to see if you have any surpressor fitted to the alternator?
Jul 14, 2009 | 1991 Chevrolet Corvette
Clock and radio/cassette player
i have the raidio casset player if you want it $25
i live in utah just so u know my cell is 801 669 0286
Jul 10, 2009 | 1991 Toyota Corolla
I don't know how to connect the wires from my JVC car stereo
Radio wire colors:
P o w e r Memory (+12v Constant) Yellow Ignition (+12v Switched) Red Ground (-) Black Dimmer Pink/White (Alpine only) Power Antenna Blue Amplifier Turn-on Blue/White Phone Mute Light Blue (Sony only) S p e a k e r s Right Front (+) Gray Right Front (-) Gray/Black Left Front (+) White Left Front (-) White/Black Right Rear (+) Violet Right Rear (-) Violet/Black Left Rear (+) Green Left Rear (-) Green/Black
1991 Oldsmobile Cutlass Supreme Car Stereo Wire Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6′ x 9′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
window.google_render_ad();
Jun 03, 2009 | JVC KW-XC777 CD / Cassette Player
1991 corvette stereo is not working correctly. When you turn it on it cracks & squeeks. CD players will not take a CD & the cassette players keeps kicking it out. What is the best & fasts way to find out...
I assume you have the bose system. The crack and squeek is caused by the speaker amps going bad. You can buy new amps on line. I believe that the amps are plugged in wants the speakers are out. There are people on the net that will repair these radios. You might be able to just find another similiar radio on the net. You have to decide if you want to spend the money to get it working or replace with another system.
Apr 25, 2009 | 1991 Chevrolet Corvette
Blaupunkt miami C90 cassette player codes
The radio will have to be removed from the car dashboard .
Then please quote the MAKE + MODEL of your radio plus ALL the LETTERS and NUMBERS on any LABELS , BARCODES or STAMPED IN THE METAL CASING.
Also quote the MAKE of CAR it is fitted into.
Jun 07, 2008 | Blaupunkt Madrid C72 Cassette Player
Code for c 90 blaupunkt miami cassette player
71 people viewed this question
 Grubhead
Grubhead
