How do i change batteries for a Panasonic Inverter remote control model A75C3427
5 Suggested Answers
SOURCE: Changing the battter of the remote control
Slide the cover down as far as it will go. Now using your fingernail, gently lever the cover off from the base, it will click out without much force. This is a stupid and confusing design and should be changed.
Posted on Apr 09, 2010
  • 6 Answers
SOURCE: How to change panasonic inverter
Slide the cover all the way down until it stops. Then using gentle pressure push the low half of the cover down to lever the top edge over the two small lugs.
To put the cover back on after changing the batteries, apply the same technique to slide the cover back over the lugs.
Posted on May 09, 2011
Therinnaiguy
  • 1420 Answers
SOURCE: How do I change the battery in the remote control
slide the cover of the remote up higher. It is hiding the batteries.
Posted on Nov 26, 2009
MOTORWIZJ
  • 1339 Answers
SOURCE: Remote control of my Panasonic
try ebay. do several searches and use the save this search button , and soon as one gets listed. you can bid or buy it now, but that depends on the listing style. i done this for years and it has saved me big money.. some remotes can cost well over a $100.00, that's not for me, and i doubt you want to spend that kind of money ?
jay the pool pump motor repair guy longwood Florida
Posted on Aug 01, 2011
Panasonic microwave convection oven model NN-CD997S works normal but stop heating
Judging from the model and without looking it up I expect that unit has an inverter. If it is not the Switches and you have replaced the mag, the inverter is the power supply for the mag to work so either mag not getting power from inverter or inverter not getting signals from main PCB Timer board.
Jul 03, 2017 | Panasonic Microwave Ovens
How to change batteries on the remote control of my Panasonic air conditioner Model Number CU_RE24LKR
  • Remove battery compartment cover
  • Observe battery orientation and polarity
  • Remove old batteries
  • Install new batteries
  • Test operation
  • Install battery compartment cover
Aug 30, 2016 | Panasonic Heating & Cooling
My panasonic inverter 410a has remote control problem. we already change indoor unit pcb . but doesn't work.so what to do?
SERVICE MANUAL Inverter Split system Air - Thermospace ...
www.thermospace.com/shinco/Inverter_Service_Manual.PDF Panasonic(rotary type. DC INVERTER). Refrigerant. R410A(pre-charged). R410A(pre-charged). R410A(pre-charged). R410A(pre-charged). Cooling. Capacity.
Jul 12, 2015 | Panasonic Heating & Cooling
Panasonic inverter air conditioner remote control wont work, it will not turn on and there does not seem to be an override switch on the actual unit?
to replace your battery have 2 AAA batterys and slide down the front cover and pull the cover of the remote you will find the battery compartment underneath the slide.
Dec 31, 2010 | Panasonic Heating & Cooling
Feb 28, 2010 | Panasonic Heating & Cooling
How to change battery for aPanasonic Heat pump remote control ?
Here is a link to a panasonic remote control. It appears the two AA batteries are located under the cover found just below the buttons on the front of your remote. Look at the link below and see if this remote looks similiar to yours.
https://support.panasonic.co.nz/docstore/CSA24%20book.pdf
I hope this helps. Good Luck!!!!
Feb 07, 2010 | Panasonic Heating & Cooling
Panasonic Inverter CS-E12EKU timer indicator blink. The unit not work at all, I follow the manual instructions using the remote control but the instructions are not clear. Using other similar Panasonic...
Today I install a new unit Panasonic CS-S13KKP also have a same problem timer blink and the outdoor unit wont start. Error code is 11. after checking the problem, can not using a 3 cable cord, solve the problem using 4 Cable cord and its run !
Victor
Aug 21, 2009 | Panasonic Heating & Cooling
Heating & Cooling Logo
77 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
