TECHNICS AMP SU-VX920 NOT PUTTING SOUND OUT BUT ON LIGHT WORKING
5 Suggested Answers
megatronix
  • 57 Answers
SOURCE: Technics SU-V2 keeps cutting out
An amp will cut out if the output protection circuit kicks in. This circuit compares output power against the preset level. Each channel has it's own, independent protector. There are calculations that can be done, but for a novice the rule of thumb is to "never use a speaker with a power rating less than the amp AND a lower impedance than stated". Typically using a 4 ohm load on a 8 ohm system is inviting disaster. Even if the system does not become a smoke generator, you might notice that though "louder", the sound quality is deteriorated. Many "audiophiles" often hook up some combinations of speakers to have "surround" without really understanding that the collective impedance actually changes (generally lowers).
Posted on Jan 21, 2008
marsrover
  • 682 Answers
SOURCE: Problem with amplifier Technics SU-V500
it is relay control the output you can changed in near electronic service center.
Posted on Mar 10, 2008
  • 4234 Answers
SOURCE: Technics SU-V98 No Sound
If I understand your posting correctly, the amp works using the Aux In connectors but not using the VCR1 even when VCR1 is selected correct? If that is the case, there is an internal electronic switching IC (TA9263 I think) that may be defective. This is not a complex repair and can be confirmed easily by any shop that does audio repair. They will trace the incoming signal with an oscilloscope to the IC and see nothing come out when VCR1 is selected. The IC costs less than $10.
Dan
Posted on Feb 06, 2009
  • 4234 Answers
SOURCE: Technics SU-G75
Th amp may be in protect mode with the outputs turned off to prevent further damage. These units have an AMP-Pac for the final stages that may be defective. The part number is RSN3306. This is the most likely part and can be purchased for about $60. Also inside is another amp-pac for the center and rear speakers (SVI3204B) which runs about $58. Either can cause the symptom you describe.
Dan
Technics su a900
I have the same TECHNICS SU A900 MKII as you are talking about and it always runs warm I think using 4R speakers instead of 8R speakers should solve the problem and actually I am thinking of switching to 4R as well.
Oct 13, 2013 | Audio Players & Recorders
Technics Amplifier SU-V4
The clicking sound will be a relay for the protection circuit. That could be faulty, but first check out the main devices on the main amp section. Those attached to the big heat sink. If you see a single IC amp that could well be faulty.
Oct 04, 2013 | Audio Players & Recorders
Hello I have a Technics SU-V45A amp, it's about 18
See there is a problem with the volume conroller as it is 18 years old the controller has worn out replace the volume controller with a new one and you will be able to enjoy great sound again
Dec 05, 2010 | Technics SUV500 2-Channel Amplifier
I have a technics su-g91 integrated amp. everything is disconected from it and the yellow over load light is on. What do I do?
hi...i have a electric guitar and i was wondering if i can conect it in my technics su-g91amp?
Nov 24, 2010 | Audio Players & Recorders
I have a Technics SU-G91 amp when I turn it on the over load light lights up and I cannot get any sound from the main speakers
Disconnect the speakers and see how that works out. It's trying to tell you it senses overcurrent or a short on the output.
May 02, 2010 | Audio Players & Recorders
Technics SU-G95 Amplifier and no sound on left speakers
Usually this is a defect in the output amp IC. If you have no experience with repairs of these types of units, have it checked by a service shop. If the output AMP IChas failed, it will cost about $75 for a replacement. This unit uses an RSN3306P IC .
Dan
Mar 14, 2010 | Technics Audio Players & Recorders
Technics SU-G91 OVERLOAD PROBLEM
THe amp has detected a problem and shutdown to prevent further damage. This unit has 2 amp pacs inside and one or both have failed. If you can solder, you can fix this yourself. The main amp pac is an SVI3206 and can be purchased online for about $60.
Keep me posted.
Dan
Oct 17, 2008 | Audio Players & Recorders
Technics su-a808 amp & sh-ge70 graphic equaliser.
connect your media source(dvd-cd player)to equalizer in-connect equalizer out to amplifier line in-or aux in-connect amplifier out to your loudspeaker.
Jun 24, 2008 | Audio Players & Recorders
Technics SU-G91 Left channel bad
Did you ever find the solution to the left channel issue? I have the same problem with mine.
Dec 02, 2007 | Technics SA-AX540 Receiver
124 people viewed this question
 Grubhead
Grubhead
