Question about Bernina Sewing Machines
Bernina matic 910 - Bernina Sewing Machines
Here is a Link for a free download I got the PDF from Bernina and I will share it for free http://www.filedropper.com/910
Posted on Jan 05, 2013
Berninamatic 910 is frozen. Where can I find manuals so that I can service it?
Ken--
May be difficult to find for your machine because of its age.
Something may be close on this Bernina site (the 910 looks a lot like the 930 without the basting stitch, perhaps the needle up/down function, and fewer decorative stitches):
https://www.bernina.com/en-US/Support-US/Out-of-Print-Manuals/BERNINA-manuals/BERNINA-Sewing-Systems
BERNINA MATIC 910 ELECTRONIC SEWING MACHINE MANUAL CD
Most likely the machine has seized due to lack of fresh oil. The old oil has solidified and turned to glue and has stuck the moving parts together. Do not force it!
Remove the free-arm cover.
Open the top. (There is a metal peg on the top left with a screw slot in the center. Turn this screw 1/4 turn. Now lift the bobbin winder and you will see another METAL screw. Turn that 1/4 turn. Do NOT mess with the plastic screw unless you want to mess up the winder.) Now you can gently lift off the top. Pay particular attention how it fits as you will need to jimmy it a bit to get it back on without bending anything!!!
Now you can remove the cover on the left side over the needlebar.
Pick up a bottle of liquid Tri-Flow Synthetic Lube (hardware store or bike shop) with the small plastic tube dispenser. Gently rock the handwheel and apply a couple drops of Tri-Flow every place that metal rubs on metal. Do NOT oil the white nylon gears, the cams, or the belt!!! If you look closely, you will most likely see some small holes that are actually oil ports. There is a large one just on the inside of the case (left of the belt) that is part of the handwheel mechanism. This is probably where your problem exists. Do NOT over-oil or you'll be cleaning up oil for a long time and it could get into the electronics.
Work your way across the top of the machine. Be sure to move the stitch selector levers, the buttonhole knob, stitch width dial, etc and get oil into those metal mechanisms as well. There are 4 or 5 oil ports on the needlebar knuckles. Be sure to get those--one or two may be hidden so you'll need to rotate the handwheel and use the long tube to get to a couple. Oil the needlebar where it goes through the case, be sure to hit the presser foot lever mechanism.
Work your way down to the bobbin area. Be sure to get the oil port at the very back of the feed dogs next to the case (this is a very important one!). Get oil on all the metal moving parts and be sure to toggle the feed dog knob and get that mechanism too.
Now, take a handheld hairdryer and direct hot air into the internal mechanism of the machine. I've gotten the metal so warm it was difficult to touch. You may need to alternate between oil and heat, but if there is nothing mechanically wrong with your machine, this will get it running smoothly again. I've used this method on several seized mechanical Berninas and it has never failed unless a nylon gear is cracked or there is something else mechanically awry.
For sure, every time you start a project, apply a couple drops of oil where the hook and shuttle rub together (see the bottom photo below, the very bottom arrow on the left) or see page 45 of the Bernina 930 manual (Maintenance section).
Be sure to lube your machine often. Once you are familiar with the sound of a smooth-running machine, you will recognize by its sound when it needs some TLC. Other than that, plan to lightly oil every 40 hours of sewing. If in storage, every 6 months whether in use or not.
The photo below is actually a Bernina 830, but the mechanism is fairly similar to the 930/910.
Oct 09, 2016 | Sewing Machines
I have a 910 bernina which will not wind a bobbin anymore, what should I do?
Which question are you asking? How to wind a bobbin or how to install a bobbin?
BERNINA Sewing Systems
Sep 11, 2016 | Bernina Sewing Machines
Bernina manual
Winder rubber is likely needing replacement
Feb 20, 2014 | Sewing Machines
Bernina Matic 802 not zigzagging
Always try cleaning first. If it still doesn't work, take it to a sewing machine repair shop.
Oct 26, 2013 | Bernina Sewing Machines
Zig zag problem on Bernina 910
Have you rethreaded the machine, making sure to get the thread between the tension discs?
Jan 31, 2013 | Bernina Sewing Machines
BerninaMatic 910 Electronic machine. The foot control has broken
Bernina foot controls cost a fortune, have a look on ebay you find someone selling spares, other than that it will mean going to a Bernina dealer
Nov 03, 2009 | Bernina Sewing Machines
Manual for Bernina 910
Try here
http://www.everysource.net/search.aspx?qrt5=sewing%20machine%20manuals
Jan 23, 2009 | Sewing Machines
Bernina 910 sewing machine extension table
Hi Phoebe,
What you have is the extension table for the 830 and the 830E Bernina models. What you need is part number 301 276 100. This table looks a little different as it has a small see-through window in the bobbin area and also, it has no clamp (it has push-in pins). Ebay or a site like SewItsForSale is your best bet. I doubt the dealer could get one but if they could, it'd be likely around $100.
Jan 17, 2009 | Sewing Machines
Sewing Machines Logo
597 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
