Question about Dell Latitude D505 Notebook
I can not get past the blue screen unmountable_ boot_ volume even in safe mode.
  • Dell Master
  • 32,281 Answers
You Dell Latitude cannot detect the hard disk.
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Posted on Feb 16, 2012
  • 148 Answers
SOURCE: computer won't boot into windows
The event of you inserting a DVD is unlikely to have anything to do with this problem. Probably just a coincidence that it happened after you did so. Hard drives die eventually and more frequently so in laptops.  I'm afraid you will have to bite the bullet and replace the hard drive.
Posted on Dec 11, 2008
  • 14 Answers
SOURCE: Blue screen of death
Taken from Microsoft themselves ( http://support.microsoft.com/kb/555302 )
SYMPTOMS
When booting up to Win XP you may get a error that reads "Unmountable Boot
CAUSE
1.The file system is damaged and cannot be mounted.
2.You use a standard 40-wire connector cable to connect the UDMA drive to the controller instead of the required 80-wire, 40-pin cable.
3.The basic input/output system (BIOS) settings are configured to force the faster UDMA modes.
RESOLUTION
If it be the connector cable problem then replace the 40-wire cable with an 80-wire UDMA cable.
If it's a BIOS settings problem then load the 'Fail-Safe' default settings, and then reactivate the most frequently used options such as USB Support.
If it's a damaged file system case then:-
1.Insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3.If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
4.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5.At the command prompt, type chkdsk /r , and then press ENTER.
6.At the command prompt, type exit , and then press ENTER to restart your computer.
This takes a bit longer, but the system should boot back into Windows.
Posted on Jan 26, 2009
  • 33 Answers
SOURCE: Blue Screen of death.
You might try removing the Hard Drive from the machin and slaving it on your other machine. Then running a chkdsk in the command prompt or norton disk utilities. If either fails, backup your data on other machin and reinstall.
RescueTechLA
  • 2653 Answers
SOURCE: blue screen unmountable boot volume
Sounds like a bad hard drive. You can try using a live linux cd like Knoppix or Ubuntu
Ubuntu is easier for most.
That way you'll know whether it's the hard drive or another issue with the laptop.
Posted on Feb 21, 2009
shakeelm
  • 224 Answers
SOURCE: HOW CAN I FIX MY COMPUTER? ITS READING UNMOUNTABLE BOOT VOLUME?
You need your Windows XP cd for this fix.
Boot from the Windows XP CD and at the first prompt, press "r" for repair. Press 1 when asked to choose windows installation and then enter the admnistrator password. If you don;t have one, just press "enter" and it should show you "c:\windows>"
At this prompt, type the following
chkdsk /r
THis should take quite sometime but will fix the problem at the end. when you get the c:\windows prompt again, type the word "exit" and your system will reboot and load windows XP normally
Posted on Mar 07, 2009
I have a blue screen that says "UNMOUNTABLE BOOT VOLUME" And system will not boot up any further?
This means that the hard disk drive has a problem. It could be an electronics failure or it could be a driver problem. Try to start the computer in SAFE mode by pressing the F8 at bootup. This will verify the hardware.
Jul 14, 2014 | Dell Inspiron B130 Notebook
Unmountable boot volume
Please boot from bootable disc and repair the OS.
Mar 19, 2012 | Dell Computers & Internet
How to remove the unmountable boot volume 1525 dell inspirion be cuz i have the blue screen, try go to the safe mode but freeze after it shows all the hard drive data its a stand still
if you can boot normally i suggest going to filehippo.com or cnet and download a free disk partioner and it will remove the boot volume for you. under run, msconfig, there is a boot option select the boot mount you want that may fix it let me know
Mar 15, 2011 | Dell Inspiron 1525 Notebook
Unmountable boot volume means your hard drive has gone out...You will need to replace it.There is no way to fix this this.
Apr 24, 2010 | IBM ThinkPad T22 2647 Notebook
My laptop is giving me blue window with a message Unmounted boot volume? I don't have a boot disc to boot from the drive, I also don't have Floppy drive only CD Drive. Can you tell me what should I do. I...
It sounds like your hard drive has gone south for the winter.
You will need to reload your operating system and programs.
If your unit was hit or dropped while in operation, you may have dammaged the hard disk.
Sep 28, 2009 | Dell Latitude D600 Notebook
Jan 26, 2009 | Dell Inspiron 1501 Notebook
Hi there
"Unmountable Boot Volume." means that the system 32 folder has become corrupt and probably you will have to recover the system.
If you have XP CD for a clean install, you have to change the boot order from within the bios (F2 on boot up) and tell it to boot from CD.
This will change the boot order and allow you to reinstall the OS.
Be warned that you WILL loose data if this is the only option open to you.
Good luck
Blue screen during booting
Yes, unmountable boot volume usually means you need a new hard drive. However, if you have a windows xp cd, you can boot to the recovery console (press R at the first prompt) and try running a chkdsk /f command. Sometimes that will help. Thanks and good luck! Oh and if you could remember to give this solution a rating of fixya. Thanks!
Jan 18, 2009 | HP Pavilion ze2000 Notebook
Dell Latitude D505 Notebook Logo
76 people viewed this question
Alun Cox
