Question about Dell Latitude C800 Notebook
My dell leptop refus starting i got message : Primary hard disk drive not found , CDBOOT ; Memory overflow error
  • Dell Master
  • 32,281 Answers
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Posted on Feb 16, 2012
  • 3940 Answers
SOURCE: primary hard disk drive 0 not found
The first thing to try is removing and reseating the hard drive. Sometimes the drive just looses it's connection with the motherboard, reseating can resolve that.
If that doesn't work, you can get a 2.5 in USB hard drive enclosure, and see if you can read the drive in another system, and recover you files that way.
Most likely though is the hard drive has failed. If this has occurred, then your options are limited. You can contact a data recovery service, but that is expensive. Http://www.ontrack.com or http://www.drivesavers.com are a couple options. You can contact them and get an estimate of the cost if the other options do not work.
Posted on Jun 08, 2008
Exidous
  • 63 Answers
SOURCE: D6000 DELL LAPTOP
Do you have any flash drives or external drives connected? If so unplug them and try to reboot. If not check to see if the hard drive is firmly in place sometimes they can come un hooked and that error will appear.
Posted on Oct 03, 2008
GregL
  • 49 Answers
SOURCE: UNABLE TO BOOT DELL D600 - FAILURE TO DETECT HARD DISK
If you press F12 during bootup, you should get the boot menu. Run the hard disk diagnostic. If the hard disk is bad, you will get a DST Short Test Error code.
Replacing the hard disk in a D600 is a piece of cake though so if you need a new HD, it's easy to do. The tedious work will come afterward.
Posted on Dec 31, 2008
  • 3940 Answers
SOURCE: Primary Hard Disk Drive Not Found, Fixed Optical drive Not found
Reseat both the Hard Drive and Optical drive and see if they detect. If they do not, then a HDD failure is most likely. The I8000 is quirky in that if the HDD fails, the Optical drive will not work.
If reseating doesn't resolve, Replace the HDD and the optical drive should work. (Controller is a serial design and neither drive will function if the other fails)
Posted on Jan 22, 2009
  • 13433 Answers
SOURCE: No bootable devices-strike F1 to retry boot,F2 for setup utillity
Is there a hard disk installed inside the computer? try reconnecting it.
The motherboard, the hard drive, or the connector could be faulty in this case.
Remember to unplug and remove battery if you open the laptop, the hard drive is in most cases in the bottom under a cover with few screws or in some dells its on the side with few screws and comes out from the side instead from the bottom.
Posted on May 22, 2009
Dell inspiron 5150 primary hard drive disk 0 not found
You may find that either the cable is not connected properly or is faulty, or the worse case the mother board has problems (driver, chips, breakages)
May even be a power supply problem, as the power supply has many output points and different voltages that the HDD power out may have blown. If it has then the rest of the system will appear to be ok.
So first off, check the cables connections on the motherboard, and look for any breaks in the cables, and if you have a power meter of some sort check the power connection, or plug in another power connector, the ones with the same end are generally the same power outputs. The ribbon cable for the HDD should have 2 sockets for HDDs and you must connect your HDD to the end one.
May 14, 2009 | Dell (U0614) for Inspiron 5150 60 GB Hard...
Problem booting "cdboot memory overflow error"
your ram or memory controller may be bad, try taking out one of the ram chips or swapping them with each other. try running memtest86 (you can google and download it) to check for memory errors.
Dec 29, 2008 | Intel Desktop Board D845GERG2 Motherboard
CDBOOT: memory overflow error.
Hey there,
At first you need to tell me whether ur hard drive is sata or pata.
If u r having Sata drive then this error occurs due to absence of SCSI Controller driver.
Else if u r using PATA Drive then Try change the bios ssetting.
Go to advanced --> Sata Configuration --> and then disable SATA native mode.
Try out above mentioned solution it'll surely help you.
Thanx.
Gimme your acknowladge by rating my solution.
Romy
Dec 24, 2008 | Intel Desktop Board D845GERG2 Motherboard
Dell Dimension 8250
Yes you need a new hard drive
Dec 09, 2008 | Dell Dimension 8200 PC Desktop
D6000 DELL LAPTOP
Oct 03, 2008 | Dell Latitude D600 Notebook
Dell Latitude C600 Laptop
Did you try to boot into the BIOS and load the default settings?
Pls check if the hard drive is recognized in the BIOS first.
Sep 02, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
Laptop won't boot..
try new hard drive 1st ok
Jan 30, 2008 | Dell Inspiron 8500 Notebook
Dell Latitude C800 Notebook Logo
149 people viewed this question
Alun Cox
