Question about HP Pavilion Computers & Internet
HP L1910 OSD main menu pop up
OSD main menu interferes with Monitor functions
  • 9 Answers
SOURCE: problem on hp monitor
I have a Dell E171FPB monitor that had the same problem with the Main Menu coming up and I thought I would tell you what I did to fix the problem.
1. I shut down the PC.
2. I removed the power cable and video cable from the back of the monitor.
3. I removed the four screws that hold the stand for the monitor and slid the stand off.
4. I then removed the 5 screws that hold the back cover on the monitor.
5. I took two flat blade screw drivers and carefully removed the back cover.
At the bottom of the monitor case, there is a small circuit board the holds the 6 switches for controlling the display.
6. I located the button that calls up the Main Menu. It is the second switch from the left as you are looking at the monitor from the rear.
7. I used a small solder iron and heated up the four prongs in sequence while holding the switch with a pair of needle nose pliers. I had to rotate this process from one prong to the other while all the time applying slight pulling pressure on the switch pulling it away from the circuit board.
8. Once the switch was removed, I put the cover back on and tightened up the five screws.
9. Then I slid the base back in the slot it came from and tightened the four screws.
10. I connected the video and power cable and turned on the PC.
With the switch removed the Main Menu never popped up again and I am so very happy.
Posted on May 30, 2008
chinna_1977
  • 65 Answers
SOURCE: osd lock
To replace Micro switches in the Front pannel (4 switches)
Posted on Oct 10, 2008
  • 62 Answers
SOURCE: OSD LOCKOUT
1. Replaced the Micro switchs.
2. press the menu switch 15 to 20 secunds.
Posted on Nov 03, 2008
  • 899 Answers
SOURCE: HP pavilion vf15 monitor (OSD lockout)
this could be a bad button connection or the osd IC chip is failing for some reason that would need to be tested to determine why.
so if you can take it apart then clean the button and the plastic of dirt , and check the contact button to see if it looks faulty or check it to see if it is making contact all the time
if those are not the problem then it is the IC chip and will need testing to find the culprit
electech
Posted on Nov 22, 2008
SOURCE: osd main controls locked/unlocked pops up every 5 seconds
Estava também com o mesmo problema de voces, já estava irritado, então abri o monitor e desconectei a ligação com a placa de controle dos comandos dos botoes do menu. é fácil fazer. Só que não vai funcionar mais os botoes. pelo menos essas mesagens não vão mais incomodar.
Posted on Jul 18, 2009
How to unlock buttons?
Not sure if this is exactly the same as yours your model hard to find I had 2 similar monitors at previous employer and they both operated the same way Taking a Look 1. Power Switch Pressing this button turns the display system power on or off. 2. Menu/Select ? Pressing this button pops up the OSD menus on the screen, and used to select ("Up" direction) the OSD control options on the screen. ? This button is used to select ("Down" direction) the OSD control options on 3. Select the screen. 4. + This button is used to increase the value of the selected OSD control option. 5. 0 This button is used to decrease the value of the selected OSD control option. Quick Adjustment Function When the OSD Menu is not active, the following functions are available for the quick adjustment. Pressing ? button once pops up the OSD Function Main Menu . Pressing ? button once pops up the small Brightness icon. Use +or 0button to adjust the Brightness level. Pressing + button once pops up the small Volume icon. Use +or 0 button to adjust the Volume level.
Apr 17, 2016 | Princeton Digital VL173 Monitor
When i press the power button to turn off monitor, i get a power button lockout message. how do i unlock the power button
I did not see anything regarding to the Power locked out function, may be it's time to call HP. Please post back what you find out from HP.
I look at HP WEBSITE: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01632269&tmp_track_link=ot_recdoc/c01643091/en_us/c01632269/loc:1&lc=en&dlc=en&cc=us&product=3770762
Locking OSD settings
When the OSD is locked, settings cannot be changed in the OSD menu. The OSD functionality is enabled or disabled by pressing the Menu button and holding it for 10 seconds. Upon disabling the OSD, an OSD Lock-out message is displayed for 10 seconds. When the OSD is locked and an OSD menu button is pressed, the OSD Lock-out message is displayed for an additional 10 seconds. When the OSD is locked, pressing the OSD menu button for 10 seconds unlocks the OSD and displays the main menu. Identifying monitor conditions
Special messages display on the monitor screen for the following monitor conditions:
  • Input Signal Out of Range : Indicates the monitor does not support the input signal because the resolution and/or refresh rate are set higher than the monitor supports. Recommended refresh rates are as follows:
    • For the w1858 monitor: 1366 x 768 @ 60 Hz.
    • For the w2338h monitor: 1920 x 1080 @ 60 Hz.
  • Monitor Going to Sleep : Indicates the screen display is entering a sleep mode.
  • Check Video Cable : Indicates a video input cable is not properly connected to the computer or monitor.
  • OSD Lock-out : When the OSD is locked, the warning message OSD Lock displays for 10 seconds.
  • No Input Signal : Indicates the monitor is not receiving a video signal from the computer on the monitor video input connector. Check whether the computer or input signal source is off or in the power-save mode.
  • Auto Adjustment in Progress : Indicates the auto-adjustment function is active and in process.
May 13, 2010 | Computers & Internet
CANNOT REMOVE THE OSD MAIN MENU FROM MONITOR SCREEN
The problem of OSD Menus popping up automatically are usually caused due to a faulty switch in the Menu button which is getting switched on automatically.
This menu will not harm the computer but constant OSD menu will most probably lead to permanent damage to the pixels in the LCD screen plus it is a constant irritation to your eyes which are most precious.
This problem can be rectified by replacing the faulty menu switch. Hope this solves your problem Thanks.
Jul 23, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
OSD main menu pop-up will not go away
Please try to Turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This should unlock your OSD menu and remove that message from your screen. best regards
May 19, 2009 | HP Pavilion F1703 17" LCD Monitor
My computer screen has a blue box that pops up and say "Controls locked". I am assuming that the buttons on the bottom right hand corner of my moniter is what it is talking about because when I hit the...
This is from the user manual for the monitor. You can download a copy from hp here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=324216&os=228&lang=en&
Click on the "monitor user's guide" link to download.
There are four adjustable options on the OSD settings screen: Lock OSD settings, Timeout, H Position, and V Position.
To change OSD settings:
1 Open the OSD setting screen under the Advanced menu. See
“Using the On Screen Display” on page 25.
2 Press the Browse buttons to select the option you want to adjust.
3 Press the Select button to check the option.
To change OSD lock setting:
1 Press the Browse button to select yes (lock) or no (unlock). The
setting is automatically saved when you change the value.
2 Choose Exit sub-menu and press the Select button to return to
the OSD Main Menu or press the Menu button to exit OSD.
NOTE: Once OSD is locked, all OSD functions including the
shortcut buttons are disabled. If OSD is locked, pressing
any button on the monitor directly opens the Lock OSD
settings window so that you can unlock OSD.
Dec 02, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
OSD Main Menu
because of moiture pushbutton switch were conduct there for replace pushbutton switch and see result
Aug 15, 2008 | HP Pavilion F1703 17" LCD Monitor
Osd main controls locked
that depends on the brand and model of monitor ,
it normally takes 2 buttons pushed at same time to unlock it.
if you have side buttons its normally them.
May 12, 2008 | Gateway FPD2275W LCD Monitor
Computers & Internet Logo
50 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
