Question about York Fitness Exercise & Fitness
York t101 treadmill whats the distance calculated in
Please can you tell what is the distance calculated in miles or kms
5 Suggested Answers
SOURCE: distance screen on treadmill
It's in Miles The treadmill goes a max of 14km an hour - if you increase the speed it only goes to 8 - 14km per hour is 8.4 miles per hour and I've been running between 5.5 and 6.5 and covering 3 miles which would be about right :) Hope this helps
Posted on May 27, 2009
SOURCE: york t101 treadmill ls error
York treadmill T101 will not run has a error L5
Posted on Feb 20, 2010
SOURCE: I have a reebok edge
I had this very same problem. I sorted it out this way: the information that Argos supplies says the speed starts at 0.8 kph with a top speed of 14 kph. If your Reebok Edge starts at a speed of 0.5 and has a top speed of 8.8, then the speed and distance is measured in mph, rather than kph. You can check this yourself with the following online speed converter:
http://www.eforecourt.com/mph_kph_speed_convert.htm
Posted on Feb 22, 2011
tunde007
  • 2382 Answers
SOURCE: i have a york heritage
Hi, L5 or LS is short for Low Speed error. It basically means that the speed sensor is not picking up a signal. Unfortunately its a pretty vague error code and can be caused by several different problems. First you have to determine whether or not you have belt movement. If you have a LS with belt movement you know that it is related to the speed sensor itself (or the MCB motor control board - the part of the MCB that handles speed sensing function). If you are getting an LS without belt movement you have to check to see if you have power output from the MCB. If you have no power output, check fuses, if fuses are good, you will need the MCB replaced. If you have sufficient output its drive motor related. Aside from a problem with the drive motor, it is possible that another factor is stopping the motor from turning (ie locked up roller bearing, foreign debris, etc.) If it is a case of
faulty electronics the next question is, is to figure out what caused it to fail. Most MCBs don't fail on their own, something else usually causes them to fail. The bottom line: The LS error can be
complicated and should really be inspected by a professional to full assess the issue. What I am saying is call the manufacturer and if it is under warranty send the treadmill back.
Posted on Apr 24, 2011
97 Hyundai lantra loses power after traveling a short distance
the coolant temperature sensor is the better bet as to a problem sensor
however having the fault codes read at a professional service centre will save lots of money and time
Feb 11, 2017 | Hyundai Cars & Trucks
How much fuel is in the reserve?
It is about half a gallon (about 2 liters). I wouldn't risk any more than 20 miles (32 Kms). Running on reserve is not enjoyable when you push the distance. Every stutter or noise makes you think "oh no, that's it"
Sep 16, 2015 | 2005 Triumph Speedmaster
What is the midpoint between Cedar Park, TX and San Angelo, TX
Here is a great site for calculating distances quickly.
Cedar Park to San Angelo is 195 miles
Cedar Park to Voca is 105 miles
Cedar Park to Pontotoc is 88 miles
Texas Distance Calculator Driving Directions Distance Between Cities...
Jan 28, 2015 | Cars & Trucks
KMS OR MILES FOR DISTANCE
It depends on which system you are familiar with. If in the US miles is Canada or GB KM. Find settings and change accordingly.
Jan 23, 2014 | Exercise & Fitness
Change speedo from miles to kms on 2008 HD Ultra Classic
Hi Anonymous, for more information about your question please visit the websites below. Good luck and have nice day.
Controls and Indicators
Feb 25, 2013 | 2008 Harley Davidson FLHTCU Ultra Classic...
Inverse cos of 52 degrees
The cosine of 52 degrees is about .6157 . The inverse cosine of .6157 is 52 degrees.
52 degrees is a measure of an angle. .6157 is a distance. The cosine of an angle results in a distance, while the inverse cosine of a distance results in an angle. There is no such thing as the inverse cosine of an angle, just as there is no such thing as the cosine of a distance. It's like asking "How heavy is one hour?"
If you're asking how to calculate a cosine or inverse cosine on your calculator, please specify the make and model of the calculator.
Jan 08, 2013 | Office Equipment & Supplies
Need to know how often to add antifreeze
Anti freeze changing is usually based on distance traveled and depends on the quality of the product used some could be every 10,000 Km,s roughly 6500 miles roughly or 60,000 kms around 40,000 miles roughly . Good Luck John
Oct 12, 2012 | 2000 Toyota Avalon
10,000 miles converted to k/m
1 mile = 1.609344 kilometers This being the standard defined value of a mile. 10,000 miles will equal 16,093.44 KMs
Jul 06, 2011 | Office Equipment & Supplies
If a car travels at 55 mph and another car leaves 2 hours later at 75 mph how long until they meet?
In two hours the first car will have traveled 110 miles. The second car closes the distance by 20 miles every hour, so it will need 5.5 hours to close the 110 miles.
Jun 26, 2011 | Texas Instruments TI-89 Calculator
How many knots in 1 degree?
Knot is a unit of velocity equal to one nautical mile per hour, degree is an angular measure. There is no conversion between them.
One degree of longitude at the equator is approximately sixty nautical miles, but one still can't convert a distance to a velocity without knowing the time it takes to cover that distance.
Feb 27, 2011 | Texas Instruments TI-83 Plus Calculator
Exercise & Fitness Logo
488 people viewed this question
Top York Fitness Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a York Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
