Question about Maytag Neptune MDE5500AY Electric Dryer
Squeelling I have a 4 yr old electric dryer, it just started to squeel a little. Also when you open the front door it has a slight burning smell. I don't know if this is normal , but there seems to be excess play in the drum. Thank You Shawn
  • 67 Answers
Your belt is bad. good news though, it is easy and cheap to replace. first, using your model number, order a new one online. there is many sites and it should cost around 15 bucks. to open your dryer, there is a panel on the bottom of the front that needs to come off first, there is usually 2 screws holding it on. then, you can get to the front panel to remove it. now, with a flashlight, look inside the bottom of the dryer to see how the belt is on (so you can get the new one on properly) and reach in and take the belt off the motor, there should be a tension pulley holding it on. then slide the drum out and out with the old and in with the new. take your time and remember how everything came apart, you should be done in about an hour.
Posted on Oct 28, 2008
My indecit dryer just stopped working. Press start nothing turns, open door can hear a sound of whirring, slight burning smell
This is the forum for questions about Television sets. Try reposting in the section for washer/dryer queries.
Sep 02, 2014 | Televison & Video
There's a slight burning smell coming from the dryer drum.
Some item may have gotten between the drum that rotates and the housing and during the rolling of the drum this item may be heating up from the friction. Check closely to see if you can find anything rubbing on the drum.
Jan 22, 2013 | Maytag PYE2300AY Electric Dryer
Dryer won't start
Obvious stuff: Check main power source. Is the dryer plugged in? Do other electrical things work when plugged in to the outlet? If not, check fuses or circuit breakers. If good, is the timer/cycle control out of the "Off" position? Try several different settings.
Door check: Is the door safety switch closing? If it is or if you don't know if it is, and if you can get to the switch, you can take the wires off the switch and connect them together with a jumper wire ( unplug the machine before you do this!). With the wires clear of any metal, plug the machine back in, then press the start switch (you can leave the door open). If the machine starts, the door switch is defective.
Sound check: Do you hear a motor running when you press the Start button? Listen carefully; electric motors are very quiet. If the motor is running, your drum belt is probably broken or has come off the idler pulley. If you can take the front (sometimes the back) off the machine, this is an easy fix. Just put the belt back on the pulleys and around the tumbler drum, Note: there is a reason the belt came off if it's not broken. Look for loose or damaged pulleys or springs, including on the motor.
Do you hear a hum without the motor running? If so it indicates wearing of the motor bearings, brushes or the stator. Brushes can usually be replaced easily, but other motor problems require professional repair or replacement.
Smell check: Any unusual odors when you try to start the machine? A hot rubber smell means belt trouble. Check the belt as above. An electrical burning smell means motor or other electrical failure. Call a repair man unless you know what you are doing.
Electrical check: If you can read an electrical schematic (usually on a sticker inside the dryer cabinet or in the owner's manual) and you can use a multimeter, check continuity in the timer/cycle control, relays and switches. If you don;t understand electricity, don't mess with it! It can kill you, especially if your dryer power is 220VAC.
Mar 17, 2012 | Dryers
Motor Pulley Squeeling - Maytag MDG5500AWW
try spraying wd 40 on the motor ends to see if it will stop if not try the rollers normally they go bad and make the belt squeel.
Jun 18, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer stopped working after working w/door open or closed
Sounds as if the door switch/latch had stuck.the smell was probably a small short. try unplugging unit. But I would imagine you need door latch/switch replaced
Feb 06, 2009 | Malber TD700 Electric Dryer
Burning smell
you can unplug the unit , and reomve the lower aces panel (3 screws along the front bottom of unit) youll probalby see an excess of lint built up in which case you can vacuum it out, and then check/clean and or replace your dryer vent
Nov 16, 2008 | Kenmore Elite HE4 Electric Dryer
Squeelling
It sounds like your belt is starting to go out. You might google the repair forums or check this site out. http://fixitnow.com/2003/11/appliance-tip-of-day-dryer-disassembly.htm
Oct 29, 2008 | Dryers
HOW TO FIX A NO HEAT ON A GE ELECTRIC DRYER OVER 10 YEAR OLD
Either one of 2 ways to get to the thermostat on a GE dryer.....
depending on your model, you will have an access point on the back of the dryer to get to the heating element which has attached to it, the thermostat.
If there isn't an access point on the rear of the unit, open the front door of the dryer and remove the 2 screws in the top of the door opening. Using a small prybar, slightly apply pressure prying up the lid. On the inside of the face of the dryer in the corners will be 2 more screws, remove those and pull the face of the dryer outwards to you to about a 45 degree angle. From there, you will be able to lift off the face. Be cautious to unplug the wires for the door switch before pulling the face all the way out. There isn't much to a 10 yr old dryer, just take your time, study the parts and put it back just as you took it apart. For the replacement thermostat or heating element look at
www.marcone.com
www.partstoday.com
Good luck and let me know if there is any more trouble I can help with.
Mar 17, 2008 | GE DCSR483EA Electric Dryer
Dryer
Open dryer's cover and look that the belt is OK and in place (over the tub and the motor) Try to find out from where the burning smell comes from. Does the motor spin ? Let me know with your results and I will do my best to assist you with your problem.
Aug 02, 2007 | Amana DLE330RAW Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
62 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
