Error code 583 on ir8500 - Office Equipment & Supplies
4 Suggested Answers
  • 86 Answers
SOURCE: IR8500 giving E000830-0000 Error code
i know what the problem is call 07764303923
Posted on Feb 14, 2008
spinal
  • 287 Answers
SOURCE: Canon IR8500 showing a E000013-0010 error code
Hello x,
I have to admit I do not have the exact manual for the 8500 but I do have the manual for the Ir105 which is basically a faster version of your device, as they are of the same family and were released as such. Canon is very good about maintaining the integrity of their error codes thru models and even thru the years of their models. They tend to merely make distinctions (as technology changes) with the suffix (the 4 digit add on, as in your case 0010 which means you followed the instructions in the display and turned the copier off and back on and the copier could not recover). E13 means that the waste toner delivery system has a problem. Let me elaborate as I am full of hot air. In an ideal world all of the image that is developed in order to make the copy you requested is transferred from the drum and to the paper. In truth a small portion of the image(toner) remains on the drum and must be removed to make the drum ready for the next image or you would see Aunt Helen's chili recipe faintly on the next copy. That "waste toner" is removed by using a a rubber squeegee (cleaning blade) that presses against the drum. Then the accumulated waste must transported away and deposited into the waste toner bottle. This is done via a relatively long tube that is the path between the image area and the waste toner bottle. There is an auger/long coiled screw within the tube that makes sure the toner carried to the waste toner bottle. The toner is so "fine" that without the stirring of the auger( which maintains fluff and flow) it could easily turn into a rock hard mass. But, if the waste toner bottle gets full and the waste toner delivery system continues to shove toner into a confined area, it will become obstructed which trips a sensor that is sensitive to even the smallest amount difficulty. I don't recall the exact verbage but i know that the copier will warn you in the display that the waste toner bottle is almost full before you get this code because the sensor once triggered begins a count sequence. So, make sure the waste toner bottle is empty. But at this point, you probably have to remove the back cover and locate the aluminum tube that delivers the toner to the waste toner bottle and "TRY" to remove the now concrete that has formed within the tube. This will require removing the tube and manually cleaning all that **** out. I dont think you have to go into srvice mode to reset this code once you have freed the system up. But if you complete the afore mention process and the code remains then press "additional functions" then press 2 and 8 at the same time , the press additional functions again. Press copier, then functions, then error, then clear, then at the lower right corner press ok. Power off and power on. Sorry to rattle on so much but i wanred to be as helpful as possible. GFL/. SPINAL......
Posted on Jul 22, 2008
  • 58 Answers
SOURCE: ir8500 error code e000020-0010?
you have to clear this error by doing the following press additional function(*) and 2,8 together) then press additional functions (*)again (you have to do this quickly to get into service mode then you press copier
then you press function
then you press clear
then you press ERR
then you press ok
then turn off the machine and then back on
this is a low toner level detection code
do you have a new toner in the machine?
Posted on Aug 07, 2009
Error Code 000320 in iR8500 Cannon Copier machiner
It appears to be LOW TONNER LEVEL DETECTION CODE.
then you press ERR
then you press ok
then turn off the machine and then back on.
However the error code will re-appear and you will need to refill the tonner
Jan 27, 2016 | Cannon Office Equipment & Supplies
What does the Canon IR8500 error code E000222-0000 means?
There's no code like that in my manual.It's220-001 means lamp inverter PCB faulty,or reader controller PCB faulty. There's also a E 225-000 error which mean scanning lamp(xenon tube) is faulty,or inverter or CCD
Oct 14, 2014 | Canon Office Equipment & Supplies
E350-3000 or e350-0002 this error code ,how to solve the error
under ir8500 I can't find the error 350, so exact solution It can't be recommended...
But generally error of 300 type are related to problems with dc controller pcb and only solution is to reconnect the connectors or replace dc controller ( main pcb ).
Sep 15, 2011 | Canon imageRUNNER 8500 Copier
Hi, I get error E249-0001 on my canon ir8500
This error code relates to a problem between the scanner and the reader board the connector looks like and old printer connector (parallel) try unplugging and reseating this should resolve it.
Mar 04, 2010 | Canon imageRUNNER 8500 Copier
Ir8500 error code e000020-0010?
then you press ERR
then you press ok
Aug 05, 2009 | Canon imageRUNNER 105 Copier
Error code e824-000
E824 indicates an error in the primary charge fan.May be tough to access on an IR8500.Good luck
Apr 06, 2009 | Canon imageRUNNER 8500 Copier
Error Code E000 583-0001
it's a finisher related code,
there are tray motor or sensor is faulty in the finisher,
clean the sensor & check the tray motor rotation.
Feb 17, 2009 | Canon IMAGERUNNER 8070 Copier
Canon e000020-00010 error code on my IR8500
toner problem , either not getting toner to dev. unit or not reading potenial differential from drum , turn of potential control to isolate issue
Aug 17, 2008 | Office Equipment & Supplies
Having trouble with my IR8500 getting Error code E000218-0000. Any Suggestions? Thanks
Nov 30, 2007 | Canon imageRUNNER 8500 Copier
123 people viewed this question
k24674
