Question about HP Computers & Internet
I need a scanner that will scan 10X14 pictures
  • bellshop Oct 26, 2008
    These are Currier & Ives Calendars pictures, approx 200 of them, 9x14 inches would be glass size needed.
  • Susan
    Susan May 11, 2010
    HI,
    Is this one photo that you need done, say for a antique family photo ?
    Thank you . *s*
    Scholar:
  • 40 Answers
I found some scanners for you listed below but,
You can also scan large pictures in sections, and then use a program like STITCHES. Basically you scan it in quarter sections and then create a working board in your photo program and then you copy and paste each section into that board and line up the edges.
This is what most people do rather than buy a very expensive large format scanner.
Some large companies also have large scanners for maps etc. If you know someone who works for a very large company or one that does surveying etc. They may do this favor for you.
Though copy stores may have the size you need, copywrite issues will be asked about.
Here is the list.
large format scanners http://www.microtekusa.com/lf.html
Microtek ScanMaker 9800XL Scanner
Price: $1,038.31, 12-by-17-inch tabloid size bed
Mustek Scan Express A3 1200 Pro USB Large Format Scanner
$154.69media_size_maximum: A3 (11.7 in x 16.5 in)
http://www.contex.com/english/scanners/sd_series_scanners.aspx
Maximum Scan Width 44in.
http://www.xerox.com/digital-printing/large-format-printers/large-format-scanners/enus.html
Input Size:Min: 4.5" x 5.5" Max: 42" x 100'
Thank you and good luck.
Posted on Oct 27, 2008
Best way to scanner pictures
Margie, if you only have to scan real pictures, almost every scanner will do. If their size is big enough, then there is no need to buy an expensive scanner. If you still have the negatives of the same pictures and you want real quality, it is a complete different story. Even from old negatives you often get a lot more detail and contrast as from the pictures. But having pictures, say 3 x 4 inch. 7,5 x 10 cm.
If you scan at 1200 Dpi, and every modern scanner can, you get pictures sized 3600x4800 pixels that is 17 Mega pixels. A size most modern cameras can't produce.
The only reason to buy a scanner and not an all in one could be, you have more possibilities with a real scanner. But you need a computer.
The not so expensive Epson V370 could scan to 4800 dpi, giving you a 16 times bigger picture. Don't use that for real photos, because you end with 280 Mega pixel pictures. No computer could handle that. It has this resolution, because it also can scan negatives and slides. But it can get the maximum out of you pictures.
If you only once need to scan 100 pictures and after that never use a scanner. I'm not sure the "better" result on a real scanner is really important. And if you also need a new printer to print the pictures you could be better of with a all in one. It is cheaper, and you could use the printer later for everything else you need to print. Most all in ones, cost the same or even less than a V370. I'm sure Canon and HP do have good scanners to. I use an Epson V700 for years, and it is still supported for the new operating systems. I often use it for pictures, negatives and slides and I'm pleased with the results. I digitised hundreds and hundreds slides and negative and lots of pictures of which I don't have the negatives. (I also have a Canon all in one, but only use it to make a one to one copy on A4 plain paper, without the use of a computer. )
i hope op ei did not complicate this matter.
Success
Jun 30, 2014 | Computers & Internet
Am I able to scan a picture into my computer. I have windows 7, the model is a mfc-5440cnz and do you need ink to do this? thank you for help
The best way to scan images to save on yourcomputer is to use the scanner software on the computer. Not the scan functionon the scanner.
You don't say what type of scanner software you have but usually scannersoftware works this way:
1) Place photo on scanner
2) Open scanner software
3) Using the software, Initiate scan
4) Name the Scanned item and save it to your desired location/folder
Note: some applications will automatically save to --My Documents--My Pictures
5) Repeat process for each pic to be scanned
Also, if you are just scanning, it should not matter what the ink situation is.
May 01, 2011 | Brother MFC 240C All-In-One InkJet Printer
Hi how are you? i am trying to scan by graduation pictures to my computer but it was unable to do that i dont know why it was woring perfectly fine.. it says INIT UNABLE HELP ME
if ur using windows xp then u can scan ur pictures from my computer. if ur scanner is properly installed then u can find scanner or camera device on ur my computer screen. u jst need to right click on that select 'get picture from scanner or camera wizard' . here u will get the scanning option.
& if u having widows vista or windows 7 then u can scan ur pictures from 'paint'. u will find scanner or camera option in file menu.
Dec 20, 2010 | Brother Office Equipment & Supplies
I need to scan pictures into my email so I can send them out to family members
Hi, callie45
You need to have a scanner first to scan the pics you have to send to your family members be sure to check the specifications of the scanner you are buying, the higher the dpi the better the quality of the pictures.HP scanners provides the most quality.
Thanks,
Banaple
Sep 01, 2010 | Office Equipment & Supplies
How do i scan a picture to go on my computer
To be able to scan a picture from your printer, your printer I suppose has a scan. Connect the printer to your system and power on the printer and system. I also want to assume that the printer driver and scanner software have been install. Face the picture you want to scan down on the scanner bed, lunch the scanner software and save the picture to the folder provided of choose a location to save the picture. If you can see the scan software and you are using windows 7, go to devices and printer and luch the scanner from there or you can click start, all prorams, windows fax and scan.
Jul 05, 2010 | Office Equipment & Supplies
The scanner on my PSC1610 HP printer, scanner, copier is only scanning about one-tenth of the picture and the rest of the picture scanned is black
open the scanner in preview and select all the picture you want to scan by stretching the frame around the picture then scan.
Dec 27, 2009 | HP PSC 1610 All-In-One Printer, Scanner...
HP Scanjet 2400 scanning picture green and backgroud green
go to scanning software in ur computer change color section and remove this problem
regards
john
Nov 03, 2009 | HP ScanJet 2400 Flatbed Scanner
Lexmarkx125 will scan larger pictures but smaller ones.
Here are some instructions from the Lexmark X63 which was similar to the X125.
The Lexmark X63 uses a sheet fed scanner, intended to scan 8 1/2 x11 inch paper.
  • To scan a document between 5 1/2 inches and 8 3/4 inches wide, center the document between the paper feed guides leading into the scanner and make sure the document is held straight,. Do not bend the document as it is fed into the scanner.
  • To scan photos or pictures that are 5 1/2 inches wide or smaller, you will need to use a flatbed scanner, or "mat" the image into a regular letter-size paper and scan the entire page. When the scan process is complete, crop out the picture using the AUTO CROP option in the Scan and Copy Control program or the photo-editing software.
Feb 27, 2009 | Lexmark Pro X125 All-In-One InkJet Printer
Driver scanner benq 3300u
If you have a BenQ Scan to Web 3300U, just plug in the scanner to your USB port on the computer and plug the power into the power bar. XP will recognize that you have connected the scanner to your pc. It will install the scanner immediately.. Go to MY PICTURES. The top option on the left hand side of the screen will be "to obtain pictures from a scanner or a camera". Click on this.. It will tell you that you have a flatbed#23 . Click on next. Using the preview button, scan the document. Using your mouse, make the scan box fit your picture or document. Then click on scan. Save your scan job . You can then view your scan job.
Dec 24, 2008 | BenQ Scan to Web 3300U Flatbed Scanner
How to get my scanner to scan only the photograph
When you scan the picture, make sure you do a preview of the scanning surface in the scanner software first, then select the region corresponding to the picture only, after that, select "scan" in the scanner software.
May 20, 2008 | HP PSC 750 All-In-One InkJet Printer
Computers & Internet Logo
80 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
