Question about Wharfedale Audio Players & Recorders
How to dismantle wharfedale pro LA-15P
Something loose inside speaker needs to be checked. How does one open the speaker?
3 Suggested Answers
SOURCE: how do i open the mbox 2 pro?
M-Box 2 Pro- 2 small black screws under rubber "feet" on the bottom(back)- 1 shiny screw under "CE" sticker on bottom- 10-12 small black screws under the faceplate sticker= DUMB- then one more small army of small black screws to get the faceplate off the metal casing-(remove carefully as there is a small ribbon connector from the faceplate to the chassis-pull up on small black sides where it connects to the faceplate.)- pop off top- reveals about a dozen small shiny screws holding the two "mother boards" together-left off there because I only needed to get to the volume resistor. good luck with the rest. good design too Digidesign.
Posted on Aug 03, 2009
  • 37 Answers
SOURCE: i want to open the
The speakers on a Laptop are usually inaccessible. You'll have to take it to a PC shop to get it changed.
Posted on Sep 17, 2011
Ok..... I have some Wharfedale Modus 8s. My question is, is that the base speaker is crackling a bit. typically when you don't have enough power the tweeters will clip first and go out. perhaps i did...
Dunno how old they are, but I just had an 11-year old pair of woofers re-edged because the foam surround and the adhesive had deteriorated. Upon close inspection the foam surround was noticeably pulled away from the cone in a few spots. Unfortunately, if there is an age-related issue with materials beneath the surface that you can't see, you'd have to pull the driver to check it out.
It wasn't until I turned my bass up loud that anything sounded wrong, which precipitated looking for the culprit (quickly found).
Nov 08, 2010 | Wharfedale Modus One-Six Speaker
Can't get wharfedale melton 2 tweeter to work. Looked inside cabinet and need advice on internal wiring please. These are very old but one works perfectly and the 12'' bass driver on the problem speaker is...
The tweeter has burned out and cannot be salvaged. I also own a pair of (ex) Melton 2s. In the beginning Wharfedale were good at supplying spares (see www.wharfedale.co.uk for contact info and advice). A few years ago after my cat destroyed the 12 inch unit in one, i invested in new insides, including state of the art 12 inch woofers, 4 inch mid range and 1inch tweeters with a good 3 way crossover. The cabinet is great so consider asking a techie friend to do this for you. Please don't just cut out and connect to amp speaker wires! You will get terrible sound and risk ruining both amp and speakers! Best regards Karl (karl@simpson.nom.fr)
May 12, 2010 | Audio Players & Recorders
Can't get the back off of my Wharfedale Diamond's. Model 7.1
Sometimes the back does not come off, but the speaker comes out from the front...
Mar 22, 2010 | Wharfedale Diamond 8.3 Main / Stereo...
Necesito saber donde está el servicio
en la esquina a la par de la zapateriea
Jan 20, 2010 | Wharfedale Valdus 500 Speaker
I have 1 set of wharfedale speakers valdus 400 .power handling (programme) 150W .normal impedance 4-8ohms.1 of the tweeter is not working .please advise how to repair asap ,thanks
you should first try if the driver is really gone or not, maybe it's just a wiring problem, also there can be something wrong with the cross-over network. Check the tweeter with a multimeter, if you don't see something between 2-16 ohms, you need a new one (or two, you probably won't be able to find the original part, so you'll have to change both left and right channel drivers) but if you see the desired impedance on the meter, check the internal wiring, crossover solder joints, capacitors, etc. I hope this helps.
Jan 03, 2010 | Wharfedale Valdus 400 Speaker
Tweeter "drive" out on wharfedale svp - 15
Hi bertsteenrt
Can you check the resistance of the HF driver(tweeter). If it is open it will need a new diaphragm. Most of these speakers use a lamp to act as protection for the HF driver. Sometimes these lamps fail. You will need to pull the horn out of the cabinet to check, and the rear connection panel off to get access to the crossover where the lamp is located. Get back to me here and I can talk you through fault finding the speaker.
regards
Graeme
Mar 21, 2008 | Audio Players & Recorders
115 people viewed this question
Top Wharfedale Audio Players & Recorders Experts
Matthew Spark
Matthew Spark
Are you a Wharfedale Audio Player and Recorder Expert? Answer questions, earn points and help others
