Question about Epson Stylus Pro 7880 InkJet Printer
Service call error 00010000 - Epson Stylus Pro 7880 InkJet Printer
    Top Expert:
  • Epson Master
  • 74,383 Answers
Hello
Try these links.
www.americaninkjetsystems.com/epson...printer.../Epson_4000_field...
www.largeformatrepairs.co.uk/technical-large-format-pro-series.htm
Posted on Feb 16, 2012
Error code 00010000
What is this happening on?
Nov 01, 2013 | Computers & Internet
Service call error 00010040
Common Error Codes
00000101 The CR Motor reached it's end of life. 00010000 PF Encoder Check Error. 00010005 CR Motor is out of step. 00010014 Pressurising failure. 00010027 Pressure pump micro air-leak error. 00010040 Printing position error. 0001002D The cleaning unit reached it's end of life. 0001003F The Pressure Motor reached it's end of life.
Servicing Levels
Three levels of servicing are available and detailed below:
  1. Basic 0040 or 0001002D maintenance procedure: This will return your printer from either the 0040 or 0001002D error to a working state by replacing only the relevant maintenance items.
  2. Advanced 0040 / 0001002D maintenance procedure: As well as replacing the parts relating to the maintenance error additional adjustments such as bidirectional/unidirectional alignment, 980mm feed adjustment, firmware updating and a general clean will be performed.
  3. Overhaul: All maintenance items as well as the PF, CR motor and belt, cutter cap, pressure assembly and cutter solenoid will be replaced. A check for any design defects such as a defective cutter cap and a defective pressure lever will be performed and any parts will be replaced if necessary. All head and feed alignments will be performed as well as any required software updates and sensor verifications. A thorough clean will also be performed on the carriage area and the print head. When the procedures are complete a survey will be performed to better understand your requirements and any recommendations will be brought forward.
info.gifIt is recommended that if you have recently come into ownership of a second user Epson Stylus Pro 9800 then you should assume that the counter values or service life levels are incorrect and choose the most thorough procedure detailed above. The reason for this is an increasing number of printers being "reset" without the actual parts being replaced or inexperienced owners trying to repair or replace parts incorrectly. In one such case a part was removed and replaced incorrectly causing a serious ink leak which was luckily caught early due to the undertaking of an thorough maintenance procedure, but unfortunately extensive damage had already been caused to the chassis and maintenance tank area.
I copied the error code and put it in the search bar in a web browser and came up with the answer. In the future just google the codes and see what comes up. Also you can download a Field Repair Guide PDF and a Manual PDF from Epson's website too.
Jan 25, 2013 | Epson Stylus Pro 9800 InkJet Printer
Laser scanner unit error. Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative....
Turn off the printer, and then turn it on again. If the same error occurs, turn off the printer, then contact the store you purchased the printer, or a service representative. When contacting the service representative, inform them of the error code displayed and symptoms.
Error Code: E100 0000
Mar 26, 2012 | Canon LASER SHOT LBP-2900 Printer
Error call service 4000:00433933
The codes on this model are the same as on the Kyocera Mita copiers.
ie: 4-digit codes
Call service 0150 engine pcb EEPROM error
Call service 0420 option paper feeder communication error
Call service 1010 lift motor lock error
Call service 1140 lift motor going up error
Call service 1150 lift motor going down error
Call service 2000 main motor error
Call service 2200 drum motor error
Call service 4000 laser scanner unit (polygon motor) error
Call service 4200 laser scanner unit (pin photo sensor) error
Call service 5100 short-circuited main charger output
Call service 6000 broken fuser heater lamp M wire
Call service 6020 abnormally high fuser thermistor M temperature
Call service 6030 broken fuser thermistor M wire
Call service 6400 zero-crossing signal problem
Call service 7000 toner motor lock error
Call service 7410 drum unit non-installing error
Call service F000 communication error between the main controller board and operation panel board
Call service F010 main board (system DIMM board) checksum error
Call service F020 main or expanded memory error
Call service F030 general failure
Call service F040 communication problem between main board and engine board
Call service F226 main pcb video data control error
May 18, 2011 | Kyocera FS-3900DN Laser Printer
Computer shows no display
did you try installing newest drivers from intel/gigabyte website? what you described looks to me as a overheating problem. try running the game with case open. are you running on the integrated GMA graphics or PCI-E graphics card(like geforce, radeon)?
Jul 02, 2009 | Gigabyte Computers & Internet
Erorr 00010000
This phone is beyond ecconomical repair. I have seen this error before. A Microprocessor Failure.
Water in the phone or dropped.
AL
Nov 28, 2008 | Sony SPP-A2780 Cordless Phone System
Error=00010000
Try resetting the phone.
There is a pinhole in the back of the phone to reset it, you will need to use a pen or skewer to depress the button. If this does not work please let us know.
May 01, 2008 | Sony SPP-A2780 Cordless Phone System
Error c0998
That what service manual says:
Service Req xyyyy
A Controller error or print engine error detected. Turn off the printer. Wait at least 5 seconds and then turn it back on. If the error message still appears, write down the error number listed on the LCD panel (xyyyy) and turn off the printer, unplug the power cord, and contact a qualified service representative
Apr 29, 2008 | Epson Aculaser C1100 Printer
Epson Stylus Pro 7880 InkJet Printer Logo
646 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
