It is the last thing anyone desire to see that his computer runs into unexpected blue screen of death when he boot the computer with a good emotion, I am surely believe that most of you wouldn't be know what to do once the problem occurs to you. And then you have to make a choice, either ask someone others to repair it and pay him money or solve the problem yourself. Maybe you'd like to choose the latter one firstly. By that way ,search online is the most convenient way for you. On the other hand, there are too many solutions to take the appropriate one. If you don't want to waste lots of your time on searching , you should spend a little minute to read what I share with you.1.Spiceworks' Network Troubleshooting Tools is a kind of free software can be used to fix blue screen error , it is obviously that the software owns a big advantage: free. But it also has a fatal disadvantage, its complicated operation interface and unstable performance. So if you don't really know about the software well, I don't suggest you to use it. 2.LiveBoot, it is not a free software. Although it can also help you solve the problem at the end, but I don't think the price of it is appropriate. Meanwhile,th operating interface of it looks a little complicated and you may not able to adapt to it in a short time.3.Compare with LiveBoot, I thinkFix Geniusis much better according to its multifunction and excellent efficiency. One more important factor I choose it is the cheaper price but better performance. You are able to fix blue screen within minutes under the help of it. There is no more than three steps to fix Computer blue screen as follows show to you.
Step 1.Create a bootable CD/USBDownloadFix Geniusfrom the official website and install it on a accessible computer. Insert a CD or USB Device Drive into the computer ,then run Fix Genius to burn it to a bootable one. This can be done in several minutes.
Step 2.Set BIOS boot from CD/USBEnter into the BIOS of your corrupted computer, and choose the CDROM or USB Device Drive for the first option of Boot Device Priority under Boot menu. Then press F10 to save the changes and exit.
Step 3.Fix blue screen with excellent toolInsert the CD/USB into the computer and reboot. You will enter into a WinPe system in a minute and the follow move is to double click the "Fix Genius" icon on the desktop. When it starts run you will the operation interface like the below picture shows. Choose proper solution according to your the problem of your computer and start to rescue. Your computer will be OK less than some minutes at the end.
It is my experience on fixing blue screen on boot, it is so easy and convenient. Maybe there exists some better way I haven't gotten yet, but I insist that this is one of the most acceptablesolutions to fix blue screen error . Fix Genius is available for windows 7 blue screen, xp blue screen, vista blue screen, windows 8 blue screen and so on. I hope what I share can be useful for you and best wishes to your computer.
Http://pcunleashed.com/errors/blue-screen-of-death/?gclid=CJ-hjcexoq4CFVMNfAod8Wy8mw
Sounds like you have the blue screen of death...
I hope this site will help
SOURCE: Blue screen of death
Taken from Microsoft themselves ( http://support.microsoft.com/kb/555302 )
SYMPTOMS
When booting up to Win XP you may get a error that reads "Unmountable Boot
CAUSE
1.The file system is damaged and cannot be mounted.
2.You use a standard 40-wire connector cable to connect the UDMA drive to the controller instead of the required 80-wire, 40-pin cable.
3.The basic input/output system (BIOS) settings are configured to force the faster UDMA modes.
RESOLUTION
If it be the connector cable problem then replace the 40-wire cable with an 80-wire UDMA cable.
If it's a BIOS settings problem then load the 'Fail-Safe' default settings, and then reactivate the most frequently used options such as USB Support.
If it's a damaged file system case then:-
1.Insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3.If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
4.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5.At the command prompt, type chkdsk /r , and then press ENTER.
6.At the command prompt, type exit , and then press ENTER to restart your computer.
This takes a bit longer, but the system should boot back into Windows.
SOURCE: startup repair won't repair
It sounds like your leaving your Installation Disk in the drive. Take that out and run safe mode, then just plug in your flash drive as normal and it should detect it and you can copy your files to it. If not, use s CD and burn the files you need on them then you can proceed with Wiping the drive. If this fails, Install XP but there is a option to not have the drive formatted thus this keeps all files in tact. Reinstall XP like this, take the files you need and then reformat and reinstall XP and you should be fine. After doing all this, run a virus scan and have it run regularly because it may have been a virus that caused the problem to begin with.
Hope This Helps
SOURCE: Can't 'Launch Startup Repair' when Vista boots on Evesham Laptop
when you restart try to press F11 while booting..check
SOURCE: the laptop wont start, just getting blue screen
If you are getting a Blue screen repeatedly and you can't start up towindows in any custom setting ( from f8 start up menu ) one way tosolve the problem is to Use the restore disc or windows installation cdor dvd to installwindows into the computer or perform a repair installation if a windowsalready exists on the computer and the setup can find it.
how to perform a repair installation
this is for xp, but its similar on 2000 and on vista.
insert your Windows XP Setup CD, and restart your computer.
1.Whenthe Press any key to boot from CD message is displayed on your screen,press a key to start your computer from the Windows XP CD.
ifnot then the computer is not set to start up from a cd, you can eitherenter the setup / bios to change that setting OR right when you powerup the computer look at the screen it will say what button to press inorder to enter boot menu or bios, it will very likely be button F12 or similar, it should say on the screen when you power on.
if it doesn't, then you need to go into the bios and change the boot order so that the computer starts from the CD first.
after that you should be able to start from the cd and install the OS (Operating system, eg.Windows)
here's some info on how to work the bios: http://www.whitecanyon.com/how-to-change-boot-order.php
Repeat step 1 when you have changed the boot order.
2.Press ENTER when you see the message To setup Windows XP now, and then press ENTER displayed on the Welcome to Setup screen.
3.Do not choose the option to press R to use the Recovery Console.
4.In the Windows XP Licensing Agreement, press F8 to agree to the license agreement.
5.Make sure that your current installation of Windows XP is selected in the box, and then press R to repair Windows XP.
6.Follow the instructions on the screen to complete Setup.
7.Oneswindows is working you will need the drivers for your computer, theyare at the makers website, for hp and compaq. www.hp.com for acerhttp://support.acer-euro.com/drivers/downloads.html for all otherbrands go to google and write Brand drivers. Should get you to theright place. Dell is most likely www.dell.com and so on.
SOURCE: Cannot start up
Try this: Reboot and select Recovery Mode, then from the c:\windows prompt type: chkdsk
Let it run through checkdisk then try it should boot up.
