Question about HP PSC 1210 All-In-One InkJet Printer
Software is installed but printer won't print
I have windows xp and the sotwared says it was succussfluly in stalled but it won't print. when i click on printers and faxes it says hp deskjet 12 c/ps 2 ready
what am i missing
In control panel check that 1) you have a check mark next to the printer you have installed so it is the default printer. 2) If this is set up correctly I'd uninstall the printer and reinstall the software and drivers again. Some times we click next before really reading what its asking. Hope this helps
Posted on Oct 27, 2008
It print all color blue
use the printer utilities
Using the Printer Utilities
how to
Accessing the printer software You can access the printer software from most Windows applications, or from the Windows Start menu.
When you access the printer software from a Windows application, the settings that you make apply only to the application you are using.
When you access the printer software from the Start menu, the settings that you make apply to all of your Windows applications.
Refer to the appropriate section below.
From Windows applications
Follow the steps below to access the printer software.
Click Print or Print Setup on the File menu. In the dialog box that appears, click Printer, Setup, Options, or Properties. (Depending on your application, you may need to click a combination of these buttons.) The printer software opens.
From the Start menu
For Windows Me, 2000, NT 4.0, 98 and 95 users, click Start, point to Settings, then click Printers.
For Windows XP users, click Start, then click Control Panel, then click Printers and other hardware, then click Printers and Faxes.
For Windows Me, 98, and 95 users, select your printer, then click Properties on the File menu.
For Windows XP and 2000 users, select your printer, then click Printing Preferences on the File menu.
For Windows NT 4.0 users, select your printer, then click Document Defaults on the File menu.
May 13, 2015 | Epson L210 - multifunction printer /...
Printing failed
This is usually caused by corrupted printer drivers. It's most often seen after an upgrade from a previous operating system when the printer was kept connected and turned on during the upgrade.
Solution: Completely Uninstall and Reinstall your Printer and 'force' XP to see new drivers:
Step 1
Disconnect the printer from the PC
Step 2
Go to the Control Panel and click on Add/Remove Programs. Highlight any Printer Software that is listed here. Select Remove.
Step 3
From the Control Panel, click on Printers & Faxes. Right click the printer in question and select Delete
Step 4
Look at the Toolbar. Select File, then Server Properties. Look in the Drivers tab. Highlight the printers drivers listed here and click on Remove for each one.
Step 5
Reboot the PC. Do NOT reconnect the printer!
Step 6
Go to the website of your printer manufacturer. Look for new XP drivers for your model. Download the correct software. If there are no Windows XP drivers for your printer, try looking for ones for Windows 2000. In most cases these will do almost as well.
Step 7
Run the exe file you just downloaded. It should auto-start the installation program
Step 8
The software will tell you when to connect the printer.
Step 9
Once the software is installed and the printer connected, try a test page. Top printer service
Smooth Printer Service
Dec 17, 2012 | Monarch Paxar 9416 Printer
Print spooler error in windows xp sp2 & sp3
Click on Start -> Run ->Type: services.msc and click OK, this will bring the services window up. Scroll down to print spooler, turn on then double click on the Print Spooler Service and set start up type to Automatic, then click OK. Restart PC. Now, you have to reinstall the software (if you can't find it, please tell me your model so I can search it for you) If this won't work, completely uninstall all the software and again, reinstall it. Click on Start -> Run ->Type: Control Panel in the dialog box and click OK. Click on add remove programs and uninstall the software for the printer.
Then check Under the Printer and Fax to see if it was uninstalled. If not then just delete it. Printer and Fax is located in Control Panel. Once it's completely uninstalled you have to reinstall the software for the printer.
May 12, 2011 | Computers & Internet
Printer is not scan but some problem she has. Error in scannor Turn off scannor and follow instructions ni manual. Scannor drive will closed. Code : 61,213,0 I want to new setup Canon PIXMA MP160...
  1. Select 'Program' (for Windows 2000/Me/98), or 'All Programs' (for Windows XP) from the Start menu.
  2. Select the name of the printer model to remove and select 'Uninstall.'
  3. When the MP Drivers Uninstaller window is displayed, click 'Perform.'
  4. When the confirmation window is displayed, click 'Yes.'
  5. When the Uninstallation Complete window is displayed, click 'Complete.'
  6. Reinstall the drivers.
Reinstall the Drivers
Note:
  • The MP drivers can be installed using Easy Install or Custom Install.
    Easy Install automatically installs the software which is in the CD-ROM.
    This method is recommended for first-time users.
    Custom Install allows you to select the software programs from MP Drivers, Application Software, and On-screen Manual.
  • Login as a user with Administrator privileges to install on WindowsXP/2000.
  • Close any antivirus software that may be running prior to installing the drivers.
  1. Turn off the printer and disconnect the cable connecting the computer and the printer.
  2. Insert CD-ROM in the computer. (The CD-ROM will start automatically and the following window will be displayed on the screen.)
    1. If setup does not start automatically, click 'Start' and then 'Run'.
    2. At the Run window, type x:\msetup4.exe (where x is your computer's CD drive) in Open box and then click 'OK'.
  3. At the main installation window, click 'Easy Install' or 'Custom Install'.
    When selecting Easy Install:
    (A) Click 'Easy Install'.
    (B) Click 'Install' in the following window.
    * Display varies according to the printer model.
    When selecting Custom Install:
    (A) Click 'Custom Install'.
    (B) When the following window is displayed, click 'MP Drivers' and the application software to be installed, and then click 'Next'.
  4. When the License Agreement window is displayed, read the content carefully and click 'Yes'.
  5. The installation will start.
    Messages may be displayed during the installation of the application software.
    Follow the instructions on the window and continue the installation.
  6. When the Printer Connection window appears, connect the printer to the computer and power on the printer.
    Note: If the installation cannot proceed even after 2 minutes, stop the installation by following the procedures below and start from the beginning again.
    1) Click 'Cancel' at the Printer Connection window then click 'Start Over' at the Installation Failure window.
    2) At the window to install the driver / applications appears, click 'Back' then click 'Exit'.
    3) Restart the computer.
    4) Install the printer driver again.
  7. For Windows XP, at the Welcome to the Found New Hardware Wizard dialog box, confirm Install the software automatically (Recommended) is selected, then click 'Next'.
    Note: The Welcome to the Found New Hardware Wizard dialog box may be behind the Printer Connection window.
    In this case, click 'Found New Hardware Wizard' button on the task bar to display the window.
  8. After the files are copied automatically and the dialog box Completing Found New Hardware Wizard window appears, click 'Finish'.
  9. If the Welcome to the Found New Hardware Wizard dialog box appears again, click 'Finish' again.
  10. At the Print Head Alignment window, click 'Execute'.
    Note:
    * The Execute button may not appear for all models. In that case, skip to step 13.
    * The Print Head Alignment can also be done after the installation of the printer driver.
  11. When the Start Print Head Alignment window appears, load one sheet of A4 or letter size plain paper in the sheet feeder and click 'Print Head Alignment'.
  12. At the Do not start another operation until current one has finished dialog box, click 'OK'.
  13. When the pattern is printed, click 'Next' at the Print Head Alignment dialog box.
  14. At the Installation Results dialog box, check the content then click 'Next'.
  15. At the Installation completed successfully dialog box, click 'Exit'.
    Note: When the Restart button appears, confirm that Restart the system now (recommended) is checked then click 'Restart'.
Dec 04, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Lexmark z45 not working with windows xp. i installed a lexmark z45 on my laptop that has windows xp and it will not print
Check the printer status:
1 Click Start > Control Panel > Printers and Other Hardware > Printers and Faxes.
2 From the Printers folder, double-click the Lexmark Z45 printer icon.
3 From the Printer menu, make sure:
– Default Printer is selected.
– Pause Printing is not selected.
Check the printer port:
2 Click the Ports tab.
3 From the list of ports, select the USB printer port. If the USB port is not listed, uninstall and then reinstall the printer software.
4 Click Apply.
5 Click OK.
Make sure you have not installed multiple copies of the printer software:
Windows XP: From the Start menu, click Control Panel Printers and Other Hardware > Printers and Faxes.
In the Printers folder, make sure there is only one Lexmark Z45 printer icon. If you have installed multiple copies of the printer software, uninstall each copy. Then restart the computer and reinstall the printer software.
If the printer port is incorrect or you have installed multiple copies of the printer software, uninstall and then reinstall the printer software:
1 From the Start menu, click Programs or All Programs Lexmark Z45 Uninstall.
2 Follow the instructions on your screen to uninstall the printer software.
3 Restart your computer.
4 Reinstall the printer software
Oct 27, 2009 | Lexmark Color Z45 InkJet
Need software
Try this site - use the search bar to narrow the models displayed
http://www.driversearch.com/cgi/advsearch.cgi?q=veo&ul=&ps=20&o=0&m=any
Sep 10, 2009 | Veo Connect Webcam
My computer stopped recognizing my hp psc1350 and it won't print
If this is not hardware problem then most probably the driver is corrupt.
First uninstall the printer completely using the procedure below (taken from HP website).
Uninstalling the software
Use the following steps to uninstall the software:
1.Disconnect the USB or parallel cable from the all-in-one.
2.Click Start , click Programs (click All Programs in Windows XP), click HP , select the all-in-one product folder, and then click Uninstall . Follow the directions that appear.
The basic device drivers have been removed after completing this step. If you were having problems with connectivity or the basic print or scan drivers, you may reconnect the all-in-one at this point to reinstall it. If the problem is not corrected or if you had other problems, continue to the next step.
3.Open the Windows Control Panel by following these steps:
* Windows 98, Me and 2000: Click Start , click Settings , and then click Control Panel .
* Windows XP: Click Start and then click Control Panel .
4.Click Add/Remove software (click Add or Remove Software in Windows XP).
5.In the list of installed programs, locate and select HP Photo and Imaging 3.0 or HP Image Zone , and then click Remove . Restart the computer after uninstalling if prompted.
6.In the list of installed programs, locate and select HP Software Update , and then click Remove .
7.In the list of installed programs, locate and select Memories Disk Creator 2.0 , and then click Remove .
Reinstall using updated drivers from the link (for XP)
ftp://ftp.hp.com/pub/softlib/software4/COL8901/mp-23606-2/gc_w01_ENU.exe
If windows vista then it will install the drivers automatically on connecting the printer
Jul 28, 2009 | HP Office Equipment & Supplies
Pixma IP3000 will not print
try to do this set of instruction & solution:
  1. Go to Start | Control Panel | Printers And Other Hardware | Printers And Faxes. Double-click the icon for your printer to open the Documents window and clear any pending print jobs by selecting Cancel All Documents from the Printer drop-down menu
  2. Try printing a test page from the printer, not from Windows XP. Most printers have a built-in test function that's activated by holding down one or more buttons while the printer is starting up. Check your printer's user manual for instructions. If this page prints successfully, you know the problem is either with your connection or with the software in your computer.
  3. Check your printer's USB or parallel connection.
  4. Try printing something simple from Windows' Notepad. To open Notepad, go to Start | All Programs | Accessories | Notepad, type a few lines of text in a document, and try printing it. If it successfully prints, the problem is with the software program you originally tried to print from.
  5. Try printing using Windows XP's generic printer driver. Open and run the Add Printer Wizard. When you get to the Install Printer Software screen, select Generic under Manufacturer and Generic/Text Only under Printers (see Figure 2).
  6. Select No for Do You Want To Use This Printer As The Default Printer? (see Figure 3). Click Next.
  7. When prompted on the next screen, tell Windows XP to print a test page. If the page successfully prints, then you probably have a problem with your installed printer driver. Either update or reinstall the driver.
Sep 16, 2008 | Office Equipment & Supplies
Printer will not print
And.....
How about telling is what the make and model of the printer, what operating system you have, any error messages that pop up etc etc etc
1020 PRINTER DRIVER HP
There are no drivers for fixya but I have found a workaround by some anonymous poster
Xp software&drivers will work in Vista after a little tweaking in printer properties.
1)Install the CD-Rom HP Software/Drivers that came with your Printer at the time you purchased it. These Xp software&drivers are Vista Compatible after tweaking the Printer Properties. Reboot after installing.
2)Goto Start/Printers. Right click HPLaserJet1020 then Left click Properties. An HPLaserJet Properties window should have popped up.
3)Click the Advanced Tab. Click the Print Processor button located at bottom of window.
4)Select print processor as>>>IMFPrint. Then Select Default Data Type as>>>RAW. Click OK.
5)Now return to the Main HPLaserJet Properties window and click the General Tab. On the Bottom of that window; Click the Print Test Page Button. Finished! A test page should be printing out if you adjusted the printer properties correctly. Enjoy!
optionally you may have to disable print spooling
Quote "This did not work for me until I changed the option in that same window (advanced settings) to "print directly to the printer". Spooling does not work. "
Jul 14, 2008 | Office Equipment & Supplies
HP PSC 1210 All-In-One InkJet Printer Logo
22 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
