Question about HP Pavilion VF51 15 in. Flat Panel LCD Monitor
Hp pavilion vf51
I have a problem with a 15" flat screen vf51. There is power, the green light comes on and a message 'signal out of range'. Then power light goes orange. I can just see a faintmessage box but cant read it. This is my mums, I took it to get it fixed for her. I need to know what is wrong with it so I dont get overcharged. Can anyone help please. How much should I expect to spend? If it is the lamp or bulb? If it is Inverter circuit? If it is a video circuit?
  • 472 Answers
It is the inverter board that is causing the screen to be feint. But is was the video resoloution being set too high that made it give the "out of range" message.
It's not easy to get anywhere to repair LCD monitors, and the prices could be well out of scope to bother with the repair.
Having said that, you can now call a few TV repair centres close to you and ask for a quote based on repairing the inverter circuit.
Hope that helps =)
Posted on Apr 11, 2008
How do I retrieve photos on my hp pavilion 325c? When I try to turn the desktop on a light blink under the power button
The light blinking under the power button is Hard Drive activity which is normal. Do you have the monitor plugged in and switched on?
Nov 01, 2017 | HP Computers & Internet
Tip
Fixing 'Out of range', 'Format not supported' message
When the video card signal exceeds the frequency allowed for the monitor, the following error message may occur:
Sync out of Range, Out of range, Format not supported
SOLUTION (FROM HP):
To avoid the message, lower the resolution or vertical frequency of the video card.
Reboot the system and use the VGA mode to force the video card driver to lower its resolution. Follow these steps.
1. Shut down and restart the system.
For consumer systems such as HP Pavilion desktop PCs, push the Power button once.
For commercial systems such as HP business desktop PCs, hold down the Power button for five seconds.
2. Immediately after seeing the HP/Compaq logo screen, press F8 at system startup to initiate the bootup menu.
3. Scroll down to highlight Enable VGA Mode , and press ENTER .
4. After Microsoft Windows completes its bootup process, access the Display Properties and select a desired resolution, which is compatible to the connected monitor. Reboot
Resolution adjustment:
From Microsoft: http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/display_change_screen_resolution.mspx?mfr=true
and here:
http://www.helpwithpcs.com/tipsandtricks/changing-screen-resolution-win-xp.htm
and here:
http://www.videojug.com/film/how-to-change-screen-resolution-in-windows-xp-and-windoiws-7
on May 21, 2010 | Computers & Internet
No vga input on working monitor
Turned on computer (Pavilion a1657c), HD light operates, Monitor has little window saying:
HDMI Input: No Input Signal
VGA Input: No Input Signal
Recommended Settings: 1920x1080 - 60hz
Changed from the monitor that came with it (HP f2105 digital ouyput) to my Samsung analog and same message comes on dark screen.
Hope It's resolve all Your Computer Problem,
Or
Still having Problem Then follow Us For Computer Support
Mar 21, 2014 | HP Media Center m7657c home PC - RC640AAR...
Blue screen and power button red
protron pltv-27 cm screen lights up then green comes on and turns red no signal.
Sep 27, 2012 | Protron PLTV-32 Television
I plugged in my tower and i heard a loud high pitch beeping sound the green led light in the back was on but the power button turns green and the green led light in the back turned off there is no signal...
the green led light is it beside the network cable connector. if it is so, then it is always meant to be like that when you power up your computer. it is not something serious and it is normal.
Aug 18, 2010 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
I have a HPvs17 flat screen monitor connected to a hp pavilion a520n. How do I turn on the speakers?
jcdiekfuss, First verify that you have audio signal coming out of the light-green audio-out "jack on the PC!! Use an external pair of "wall-wart" powered speakers to verify. Notify me of result. You can also try to "feed" low-level audio from a radio or CD player "ear-bud" jack to the LCD monitor's audio input jack for testing purposes. Good luck. 12fixlouie
Jun 15, 2010 | HP Vs17 17" LCD Flat Panel Monitor
HPL1506 The input signal from pc display foe few seconds and goes off error recommended setting - 1024 x 768 - 60Hz
It can be that your PC video resolution is set higher than 1024 x 768 @60Hz for the monitor to display correctly.
Spec: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00485268&lang=en&cc=us&taskId=101&prodSeriesId=1130384&prodTypeId=382087
Try this per HP:
HP Business Monitors - What Do I Need to Do When the Message Sync out of Range Displays on the Monitor? ISSUE: What do I need to do when the message Sync out of Range displays on the monitor? When the video card signal exceeds the frequency allowed for the monitor, the following error message may occur: Sync out of Range SOLUTION: To avoid the message, lower the resolution or vertical frequency of the video card. Reboot the system and use the VGA mode to force the video card driver to lower its resolution. Follow these steps.
  1. Shut down and restart the system. For consumer systems such as HP Pavilion desktop PCs, push the Power button once. For commercial systems such as HP business desktop PCs, hold down the Power button for five seconds.
May 20, 2010 | HP L1506 15" LCD Monitor
Flat Panel Monitor Displays Message about No Signal, Signal out of Range, Sleep, or Power Save
You monitor can't pick the signal from the output video card, you need to remove the VGA cable and again put it back, but make sure that your PC isn't power on. After you have done this, reboot the system. You'll see that there is no more problem with the display. Sometimes this problem is caused by CPU overclocking, if the problem still persists, remove the BIOS battery and leave it outside for at least five minutes and put it back. That'll solve all the problems related to display. Good luck...
May 08, 2010 | HP Pavilion A6430F Desktop PC
Pc entering power saver mde
This message apears when there is no input coming from your computer. There should be a bution you can puch on the monater that would cnahge it from digatail to analog this may be the problem that you are having problems with
May 21, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
Sampo Flat Screen Black unless unplug and plug back in
i had the same problem now my monitor wont even turn on if i do that the power light just keeps blinking maybe its a sign of a dying monitor
Jan 16, 2009 | Sampo PD-70 15" Flat Panel LCD Monitor
Computers & Internet Logo
155 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
