Question about NCH Software VideoPad Video Editor Professional
Runtime Error floating Point - NCH Software VideoPad Video Editor Professional
I want to know the signification on error9401
Runtime Error Runtime Error 9401 is a common kind of computer error that can be caused by damaged registry files, damaged .log files, faulty program installation and uninstall, serious virus attacks and application confliction. Runtime Error Runtime Error 9401 problems sometimes are hard to detect by Windows operating system itself and you have to restart your computer to get rid of Runtime Error Runtime Error 9401.
Runtime Error Runtime Error 9401 can lead to:
  • Blue Screen of Death Errors
  • Registry errors
  • Obscure computer errors like ActiveX Errors, DLL errors and EXE errors
  • Serious Malware Threats
  • Slow PC Performance
  • Computer & Application Shutdown
Apr 17, 2015 | Cars & Trucks
RUNTIME ERROR,R6002-floating point support not loaded.Unable to download file.Make sure the computer has a working connection to the Internet before trying again. Even i have already connected online.
I would suggest you to consult an experienced technician to resolve your issue.
I had the same issue last month. I got a good assistance fromthebestpcdoctor.com. They got ta toll free number (877- 407-9229 ), I called em ..up and my issue is solved..
Sep 24, 2011 | Microsoft Windows XP Professional
I m start logitech vid upgrade but error in upgrade run time error ROOO6 floating point support not loaded.
only solution i could find on the web http://www.articlesbase.com/data-recovery-articles/runtime-error-r6002-floating-point-support-not-loaded-quick-solution--974414.html. i would suggest running ccleaner from filehippo.com and run the cleaner first that should prob do the trick. let me know.
Mar 15, 2011 | Cameras
Error R6002 floating point not loaded
Causes of Runtime Error R6002
Several causes exist behind this error. One of the most prominent ones is a broken link. This link apart from causing the run time error 06002 can also produce other errors like the computer not responding to any instruction at times. If a software has not been properly installed it can also produce such errors. Apart from that, use of internet without any anti-virus software can make your computer applications get infected with spyware and viruses. Such viruses can produce missing links inside your registry causing such errors.
Why are these errors caused? Many computer users are just not aware of the reasons resulting in these errors and what are the solutions to get rid of these errors. Remember, these errors can be solved very simply, and they are not going to cost you money. Usually many people exercise the option of getting professional technicians to resolve these problems. But this is not necessary. Through following the simple procedures suggested below you will be able to eliminate the error r6002.
If you take time and start noticing, you will find that the runtime errors are due to corrupted or damaged registry. You must know that the registry is the most importance place which is a storehouse of all the data, about both the software and hardware installed in the PC. When you uninstall software or remove a device there may be some traces of such actions left in the registry and manually it will be impossible to remove them. You should be having knowledge of computers to do this, since it is not advisable to access the registry without this knowledge and manually delete these files. A wrong move can result in damaging the PC irreversibly.
Therefore the only method to fix the runtime error r6002, along with many other errors, you should use the registry cleaner. With a registry cleaner you can repair the runtime error r6002 all by yourself, without seeking help of technician. This way you can save money and time, and you will also know the action to be taken next time when you encounter such errors.
Using the registry cleaner should be optimized with the antivirus cleaner, and if you program in such a manner that both the virus scanning and registry cleaner can take place simultaneously, for which purpose you should schedule these activities on the computer, and ensure that at that particular time the computer is switched on, without your botheration of checking them, they will do their job on their own, leaving you to attend to your work.
http://www.registryfix.com/?hop=reviewb
Jun 04, 2010 | Microsoft Windows XP Professional SP2
try using windows 2000 or windows xp sp2 compatablity mode for the executable file that causes the error
Jun 04, 2010 | Sony VAIO® VGCLS1 PC Desktop
Floating point support not loaded
it could be a virus
try to download combofix and run it
Jul 09, 2009 | Computers & Internet
Microsoft c ++ runtime libaray error r 6002 floation point not
IT IS BETER U GO 2 DEVICE MANAGER N DISABLE THE OPTION THAT U R GETNG MSGS
Jul 03, 2009 | Intel Computers & Internet
Desktop runtime error
You need to call the maker of your computer. There is something wrong with the Motherboard of your computer or the hard drive. Call the maker of your computer this would be HP, Acer, Dell, Gateway, or any other maker. Their tech support team will help you. If you have HP go to www.hp.com and speak with a live agent, it helps to avoid a 50 dollar diagnostic fee.
Apr 05, 2009 | Microsoft Windows XP Home Edition
Runtime error
Does the Program issue you the name of the suspect runtime library at any point? If it does, go get the latest version of the runtime from the NET, in a searchengine type the name of the file+ext. download and then copy it in the same direrctory (folder) as the one on your system now. NOTE: I would FIRST rename the one on your system as <currentfilename.current_extention>and then add .OLD to it.
Mar 31, 2009 | Microsoft Picture It! 2002 for PC
Computers & Internet Logo
Top NCH Software Computers & Internet Experts
Lawrence Oravetz
David Payne
David Payne
dhnguyen
Are you a NCH Software Computer and Internet Expert? Answer questions, earn points and help others
