Question about Brother MFC 6490CW InkJet Printer
Brother bootloader firmware
I need the firmware that I can use with FILEDG32.exe and the bootloader driver to flash a brand new mainboard. Does anybody know where i can get this?
How can I unlock my phone
- Unlock all Sony Xperia 2010 Year (under test, private only)
- Unlock all Sony Xperia 2011 Year( with Test Point) (under test, private only)
- Flash All Sony Xperia/ Sony Mobile Android based mobile phones
- First in the World: Read Trim Area from Running OS via ADB( Android Debug Brigde, ADB - included)
- First in the World: Write Trim Area from Running OS via ADB (Android Debug Bridge, ADB - included)*
- Trim Area Backup Read using ADB/BootLoader(for test or Security reason)*
- Trim Area Backup Write using ADB/Bootloader**
- Single Trim Area element Read/Write*
* Not all TA elements can be written or read and not all Platforms support it.
** Not all TA elements can be written or read.
!!!Software require Internet Connection for all operations!!!
download tool
http://www.mediafire.com/download.php?7gede2no6nsccvd
Usage:
!!!IMPORTANT!!! Before any operation with any new phone - Back it UP! Later
you can restore it if somethings gone wrong.
A) To read/write Trim Area
using ADB:
1. Connect your phone to PC using USB Cable.
2. Enable USB-Debugging in Settings->Development menu
3. Install drivers
4. Go to TA work tab, click ADB in the software and press Connect.
If you need to Cancel you can click cancel to stop operation
5. Wait software to check root in your phone and try to root it.
6. If your phone is not rooted you recieve a message how to root
your phone.
7. Click Backup TA. All your TA will be backed up and saved in new
folder, same as your imei number
8. If you need to restore phone - click Write TA from Backup
9. If you need to read/write single element: enter element number in
heximal (for example 7da) and press read/write
9a. Upon write operation you will be asked to open the file to
write, so please be ready for this file to open.
using BootLoader:
1. Training: Connect phone in Flash mode (Hold the back (or the
Volume down in new 2012+ phones)) key and connect the USB cable.
2. Install drivers (x64 or x86)
3. Check if driver install ok
4. Disconnect phone
5. Go to TA Work tab and click Bootloader
6. Click Connect button. If you need to cancel you can click cancel
to stop operation
7. Connect phone in Flash mode (Hold the back (or the Volume down in
8. After successfull connect Click Backup TA (for your security)
9. If you need to restore click Write TA from Backup
10. If you need to read/write single element: enter element number
in heximal (for example 7da) and press read/write
10a. Upon write operation you will be asked to open the file to
B) To flash a S1_Boot android phone
1. Go to Flasher tab
2. Follow the procedure 1 of the read/write TA using BootLoader
(Traning)
3. Click Open firmware (acceptable formats: zipped firmware bundle,
with loader.sin inside), file format - zip or 7z (7-zip)
4. Select files to flash(eg. 1 file or All files)
5. Connect phone in Flash mode (Hold the back (or the Volume down in
6. Install Drivers (x64 or x86 - according your system OS)
7. Stand by, software detect phone and send the loader.sin from the
archive
8. Click Flash when phone is connected and software hint says "You
can press the Flash button now"
8a. Keep in mind, the system.sin takes longer at 99%, this is ok,
need wait.
C) To unlock phone
without Test Point (2010 phones only):
2. Install Drivers (x64 or x86 - according your system OS)
4. Disconnect phone
5. Enter your user id and password
6. Click unlock
8. Follow the on screen instructions (some phones require one or two
reboot).
with Test Point:
4. Disconnect phone
5. Connect the Test Point.
7. Keep the Test Point connected
8. Click Unlock
9. Stand by.
9a. Longer in description faster in process about 20 seconds.
Apr 19, 2016 | Sony Ericsson XPERIA X10 Cell Phone
Change language mfc J4510DW
Nope, language does not change that easily.
I've changed my printers language, but it's a lot of work.
Here are the steps needed:
1. You need to download the Filedl32.exe (brother's tool for uploading firmware to the printer) and the brothers Maintenance mode drivers. These can be found here: http://downloadcenter.mustek.co.za/list.php?dir=Repository%2FPrinters%2FBrother%2FOther%2F
2. You need to enter maintenance mode on the printer. To do this, follow the steps below:
  • Press and hold the Home Icon on the printer's screen
  • After you see the firmware info, press and hold the last box (which is empty) until a menu appears
  • Within 3 seconds type the following *,2,8,6,4 (without commas)
  • If you did everything correct you should be in Maintenance mode
A video showing the above can be found here: https://www.youtube.com/watch?v=zt2FlT-qulw
3. Now you need to change language. To do this, type 74 and press set mono. In the language menu change the language from 0003 (Germany) to 0001 (USA) then press set mono again. Now the printer will set the language to English and will prompt you with Please DL Rom
4. With the printer in maintenance mode, connect it via USB to your PC in which you already have installed the Maintenance drivers. The PC should recognise the brother printer as Maintenance Brother Printer
5. Now comes the tricky part, you need to get your firmware file, which is not easy. My solution was based on this post: http://pschla.blogspot.gr/2013/08/resurrecting-brother-hl-2250dn-after.html
My issue though was finding the correct values to post to Brother, as my printer was differently. Unfortunately using SNMP didn't help as none of the parameters did show up on snmpwalk.
So I did another trick, since I also have a Mac. I did use a proxy (Charles) and run the firmware update jar file. Now initially I failed, since Brother is using SSL, which made it impossible to get the post data, but I was able to change in the updater tool the BrUpdSys.xml file and change the file URL (FileGet XML node) to something random, http://www.google.com, which allowed me to get finally the post XML data.
Using those and posting those with CURL I finally got my firmware, which I installed.
The firmware request file of mine look like this:
<REQUESTINFO>
<FIRMUPDATETOOLINFO>
<FIRMCATEGORY>MAIN</FIRMCATEGORY>
<OS>MAC</OS>
<INSPECTMODE>1</INSPECTMODE>
</FIRMUPDATETOOLINFO>
<FIRMUPDATEINFO>
<MODELINFO>
<SELIALNO>E71359M3F391200</SELIALNO>
<NAME>MFC-J4510DW</NAME>
<SPEC>0001</SPEC>
<DRIVER>Brother MFC-J4510DW</DRIVER>
<FIRMINFO>
<FIRM>
<ID>FIRM</ID>
<VERSION>M1405200717:EFAC</VERSION>
</FIRM>
</FIRMINFO>
</MODELINFO>
<DRIVERCNT>1</DRIVERCNT>
<LOGNO>2</LOGNO>
<ERRBIT />
<NEEDRESPONSE>1</NEEDRESPONSE>
</FIRMUPDATEINFO>
</REQUESTINFO>
So as you can see it's quite different than the one on the blog post.
Anyway, after posting this I got the firmware URL for the english firmware which is this: http://update-akamai.brother.co.jp/CS/LZ4228_M.djf
Note, the above is for the model MFC-J4510DW ONLY. so don't use it in another model.
Note 2: If you want to change the language to something else (not English), you'll need to change the 0003 to 000X in the printer's maintenance mode and also in the <SPEC> XML node above.
You can see the country list codes in this pdf: http://support.brother-usa.com/Virdata/Content/en-US/MFC/Technical/ServiceManual/SM_MFC_J280W_J425W_J430w_J435W_J625DW_J825DW_J835DW_EN_5063.PDF
If you scroll to 1.4.26 EEPROM Customizing (Function code 74)
6. After you have the file, just open the Filedg32.exe, locate the Brother Maintenace USB printer icon and drop it there. It will upload the firmware to the printer and the printer will reboot. After reboot your printer should have finally an English menu!
Good Luck and remember you are responsible for what you do.
To help you I have also uploaded my firmware file on dropbox, so you can use that one and skip the curl steps, if you like!
My firmware file: https://db.tt/5WvbcRyl
My request.xml file: https://db.tt/EUJ74ttI
I've also uploaded the driver and filedg32.exe files in case you can't find them anymore in the website I did provide: https://db.tt/sUgqYP53
Mar 10, 2014 | Brother MFC-J4510DW All-in-One Inkjet...
Blue screen, says Bootloader USB Init at bottom, won't restart with power key
1.go to http://www.modmymobile.com
2.download p2ktools zip file
3.extract zip file
4.down firmware for motorola razr v3 zip file
5.extract razr v3 zip file
6.open p2ktools extracted folder open p2ktools exe file
7.read help how to flash your motorola razr v3
Aug 24, 2011 | Motorola Mobility RAZR V3
Not able to write dvd using sony dvd drive dru-840a
Take it !!! the link of firmware drivers utilities and firmware
Here is the two different Firmware for SONY DRU-840A
Click the link and download
http://codeguys.rpc1.org/firmwares/sony/dvdrw/840A.SS01.patched-fb-fr.rar
http://codeguys.rpc1.org/firmwares/sony/dvdrw/stock/840A.SS01.stock.rar
And Here is the two Different Firmware Flash Drivers Utilities Link
http://www.samsungodd.com/KorLib/File/tsdnwin.exe
http://www.samsungodd.com/KorLib/File/sfdnwin.exe
Enjoy
you will flash your DVD Drive. May be this will solve your problum enjoy
May 18, 2011 | Sony DRU840A DVD-RAM Burner
I need a subsidy password for my razorv3
hey there welcome to fixya
I think that all you need to do is put a new firmware on the phone.
This will enable you to use the free "moto unlock 2005 software" with your USB lead to unlock ur V3
This did take me about 5 hours to find all the info admittedly but it's all out there - Ignore all those trying to charge £10 to change 32 bytes of code - forums and torrent trackers are your friends!... Use them...
....V3 ONLY (as far as I know)...
1. First thing to do is to check your firmware. Turn your phone off. Hold down the * and # keys, and press the ON key. Should be a black screen displaying a few characters.
If it says bootloader 7.D0 you are in luck. Go to step 4, then step 10
2. If it says 7.E0, or 8.23 you can go here
http://www.motox.info/showthread.php?t=7411
and grab the (unlockable) bootloader 7.D0 and apply it with Smartmoto or similar flashing app. Then see step 4.
3. If it says 8.26 you will need the bootloader downgrader here http://rapidshare.de/files/13848110/scotty2_8.26_downgrader_v2.zi...
so you can taste the sweet freedom. There are instructions in that link
4. Put the 3 driver files on your hard drive (USBMOT2000.INF, P2K.INF, P2k.sys)
5. Turn your phone on. Connect it to your computer. Windows should recognise it and ask for drivers. Point it to the drivers u just put on. When it has finished, your V3 will charge via USB.
6.Run Smartmoto. Windows should recognise some extra parts of your phone and ask u for drivers. Point it to the same drivers.
7. Once Windows has finished installing these drivers close Smartmoto, and reboot your computer. Put the phone on flash. When windows has loaded again open up smartmoto. Connect your phone, and set the box in the top left of smartmoto to "computer USB Port". Hit the "search" button and smartmoto will find your phone.
8. click on PC Flash at the bottom left. Click where it says "browse" and find the R374_V3BL_07.D0.shx file from your harddrive. Click on "write flash"
9. When it is finished it will ask u if you want to flash another phone. Hit "no" and close smartmoto. Turn your phone off, and put it into flash mode once more. Don't worry if the flash screen now looks different - this is normal.
10. Now you can run the Motorola_unlocker_2005_free and this time it should work. When it has finished your phone should be unlocked!!
i hope this was of great assistance to you
please remember to rate this solution thankyou
regards
magical ink
Jun 10, 2010 | Motorola Mobility RAZR V3x Cellular Phone
Show me the way to restore bootloader for v3i.
Your phone has become a brick and needs professional attention to restore the firmware. Note that it's not always possible, and on an old phone like the v3 it may be cheaper to replace the phone completely.
May 13, 2010 | Motorola Mobility RAZR V3i Cellular Phone
I replaced screen on samsung eyernity. i put it back together and a message densbl boot loader for msm6290 poped up. how to fix
Sound like your phone is in bootloader mode. This is for updating the firmware. Pull the battery and try turning the phone on.
If this does not work you will need to update the firmware to send the reset signal to your phone
Check out Howardforums for firmware and updating instructions
or Samsung flash world
If the bootloader is damaged your phone may be cooked
Dec 04, 2009 | Samsung Eternity Cell Phone
V3a stuck on bootloader usb init screen'
flash your phone thru RSDlite and it be ok.
download rsdlite here:1.http://www.motorolafans.com/forums/a1200-applications/13457-rsdlite-download-here.html
download firmware here:2.http://rapidshare.com/files/62231936/MPC_V3A_01.1F.01R_PRInn22217_MONSTER_01.rar.html
after download complete install rsdlite to your computer.run rsdlite and plug your phone while in bootloader mode.if phone ask a driver,go to program files,rsdlite,p2k driver.after installing driver,flash your phone...
Jul 19, 2009 | Motorola Mobility RAZR V3a Cellular Phone
Bootloader usb init
This means that the phone firmware is corrupt - you can try to reflash it using Motorola software update, but it might not work for a phone stuck in bootloader mode:
https://rsddownload.motorola.com/download/Motorola_Software_Update.exe
Jul 01, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Motorola l6i
first you need is a RSD lite program or flash and back-up to flash or reformat your Motorola,
to enter the bootloader
hold * then the # then power button, your phone will boot to bootloader, and you will see there the flash program of your phone,
start the program rsd lite or flash and backup
then connect it to your computer VIA usb, automatically the program will detect your phone,
i prefer that you first buck up your firmware by using F&B (Flash and backup) then use RSD lite to flash your Motorola,
RSD lite its much easier to use than F&B, but for safety backup first your firmware,
gudluck
Aug 28, 2008 | Motorola Mobility L6 Cellular Phone
Brother MFC 6490CW InkJet Printer Logo
282 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
