Question about Dell Computers & Internet
My windows vista Dimension E521 is all black, i was just chatting then the computer frozed so i restarted the computer everything was ok the fan and all that was okay but after the boot it goes all black, any solutions ?
  • 21 Answers
Maybe it was corrupted, due to improper shut down. try to remove memory and place it again, then restart,if not you have to reformat it
Posted on Feb 17, 2012
How can I replace the fan on my Dell Dimension E521 desktop? A few days ago, it started making rattling noises. Yesterday it stopped entirely. I shut down, then turned back on and there was a black...
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/parts.htm#wp1461049
Once the cooler is out unscrew the fan and go with it to a pc shop and get an similar one - make sure it has the same number of wires.
Aug 19, 2011 | Dell Dimension E521 PC Desktop
My Dell E521 desktop dvd / dvdrw drives don't work
HI,
These instructions are for XP but it works in Vista too. The difference being how you get to the Command Promp and plus sign (+) vs. arrows.
1. Click Start.
2. Click Run.
3. In the "Open" field type REGEDIT.
4. Click OK.
5. Click "File" in the menu bar.
6. Click "Export" from the drop down menu this will open a new box.
7. Click the down arrow beside "Save In" and select "Local Disk (C".
8. In the File Name field type BACKUP.REG.
9. Verify that under the “Export Range”, that the radio button is beside "All".
10. Click Save.
11. Click the plus sign (+) beside HKEY_LOCAL_MACHINE.
12. Click the plus sign (+) beside System.
13. Click the plus sign (+) beside CurrentControlSet.
14. Click the plus sign (+) beside Control.
15. Click the plus sign (+) beside Class.
16. In the left hand window pane click on {4D36E965-E325-11CE-BFC1-08002BE10318} to select that key.
17. In the right hand window pane select the UpperFilters registry key and press the delete key on the keyboard.
18. Confirm with an OK.
19. In the right hand window pane select the LowerFilters registry key and press the delete key on the keyboard.
20. Confirm with an OK.
21. Click the "X" in the upper right hand corner of the Registry Editor window to close it.
Restart your Computer in order for the registry - fix to work.
Please leave me comment, if you need further assistance
Thanks for using FixYa
Rnj VinodKumar
Mar 10, 2010 | Dell Dimension E521 PC Desktop
SCREEN HAS GONE BLACK ON MY DELL DIMENSION C521 PC, AFTER IT FROZE AND I SHUT IT DOWN BY PRESSING THE BOTTON. TRIED ALL SORTS OF
hello if your screen goes black and you press down this combination keys together window +Alt + delete and still it did'nt restart itself so you can use it then check your monitor cable that enters the back of your system. If the problem persist then you will have to reload your system operating system put in the window Xp or Vista CD and follow the command giving to you then if you are sure that the monitor is not the problem may be it has completely get fault that will need for another monitor
if you need more assistance pls get to us ok
Feb 20, 2010 | Dell Dimension C521 PC Desktop
After installing Vista SP2 update computer wont reboot from HDD or CD w/ vista CD
ok boot the computer and as soon as you see the black screen hit f1
or delete to enter bios go to boot menu and configure the cd-rom to be your first boot option. you can also hit f12 when you first see the black screen to enter boot menu. choose to boot from cd .
ok now install the disk and choose repair system .
Nov 13, 2009 | Dell Dimension E521 AMD Athlon 64 X2...
Windows Vista won't load after a full factory restore on my dell dimension e521 ?
Go into your BIO's at startup and set it to load from the CD-Rom only. Then drop the Vista disk in the CD-Rom and restart the computer. After it loads you will need to go back into the BIO's and set it back to where it was before you made this change.
Oct 10, 2009 | Dell Dimension E521 (D10E16) PC Desktop
Dimension e521 black screen no video signal
if your num lock key responds, you may have to reseat/change the video card (if you are sure monitor is good). else you need to replace your motherboard.
Getback if you need any clarifications
Jan 09, 2009 | Dell Dimension E521 PC Desktop
Main fan on dell dimension e521 on full blast when comp on
Do you have your PC in some sort of enclosed space with little ventilation? If so, the constant fan activity is your PC trying to keep things cool inside. With little ventilation comes great heat, and PCs like it cool.
Dec 27, 2008 | Dell Dimension E521 PC Desktop
Dimension e 521 screen black
I reseated the memory module and the computer booted normally. Your suggestion worked, thank you.
Dec 17, 2008 | Dell Dimension E521 PC Desktop
Computers & Internet Logo
81 people viewed this question
Alun Cox
