Question about TallyGenicom 6306 Matrix Printer
I have error massage ribbon fault...what are can i do...is it the hardware problem
  • syahrir Feb 17, 2012
    Can i know how to clean the ribbon mask and ribbon motion sensor...any part i has pull out or how..TQ for your answer
  • 140 Answers
It could be the problem with your Ribbon cartridge, Ribbon motion sensor & Dust contaminated in ribbon mask/Hammer. Replace the ribbon cartridge with new one, Brush the ribbon mask & clean ribbon motion sensor with IPA. This will solve your problem. Let me know for further assistance.
Posted on Feb 17, 2012
DE error massage on lg fuzzy logic 8.2 kg 8071TTP
The dE error or fault code indicates that the door is not latching properly. Check the lid or door operation to be sure it's not binding and that the door alignment is correct. Also, check the door/lid hinges to be sure they're not binding. Finally, make sure the door catch is in place and not broken. You may need to replace the door hook/catch or the door lock assembly.
Jun 22, 2015 | LG Washing Machines
Ribbon fault error
First of all sorry for the problem.
It seems to be a logic card problem . Kindly contact with lipi for replacement of the logic card.
Aug 16, 2012 | Tally T6215 Matrix Printer
Showing Ribbon Fault
hi
clean the ribbon then if still same error chang the ribbon
Jun 19, 2011 | Tally 6312 Matrix Printer
I have a Tally 6212. I'm using non Tally ribbons which is producing a ribbon fault. I'm told by my ribbon supplier that there is an override to keep the ribbon from causing the fault. Can you...
If the ribbon is causing the Ribbon Fault, they would not be very well made compatables I would suggest changing to one of the other brands available. I belive the T6215 senses the ribbon turning by having a silver strip stuck on a rotating disk on the back of the ribbon, if this strip is not present or is not being detected it will display a Ribbon Fault. You can check the ribbon to ensure it has a reflective strip by manually winding the ribbon and looking at the back side of the ribbon, you should see a rotating disk which is half silver and half black. If this disk is not present the compatable ribbons would not be that compatable. The T6215 does to have a fault over ride for the Ribbon Sensor on its own, you can only over ride all faults this may cause other problems as Paper Out, Paper Motion errors are also overridden. You can enable fault override in the following way; Press and hold down LINE FEED and ENTER for about 5 seconds untill the printer bleeps. Press and Hold down FORM FEED and ENTER for about 5 seconds untill the printer bleeps. The above actions enabls Fault Over rides temporarily if the printer is powered off or reset Thai setting will be lost.
Apr 21, 2011 | Tally T6215 Matrix Printer
My printer is showing eror 11
Error 11 means ribbon feed error. Please check ribbon feed motor, ribbon feed driver motor and main board to locate the fault.
Jan 01, 2011 | Epson DFX-9000 Dot Matrix Printer
49.2F9D ERROR Power off then on i have reciave this massage in my printer
Hello, 49 Error, relate to an internal critical error, either hardware or software applications can cause this eroor, for more information nd troubleshooting tools, follow the posted link.
Support 49 Errors CLICKHERE
Oct 15, 2010 | HP LaserJet P3005 Printer
Persona C25 Thermal Printer: I have a Fargo DTC520 that suddenly shows ERROR NO...
Without looking at it, I would have to say the ribbon sensor needs replacing. We do repairs if your interested, located in CA.
May 14, 2010 | Fargo Persona C25 Thermal Printer
S4M .how to do when it show alert massage
Are you using a ribbon? If so, then the ribbon is not loaded correctly passed the ribbon sensor. Or, the media is loaded in this position. Check the diagram on the inside of the door to make sure labels and ribbon are installed correctly. If you are not using ribbon, then you need to set the printer to direct thermal in the front panel and/or the software.
Oct 13, 2009 | Zebra S4M Thermal Label Printer
Tally T2250 showing an error..
when power on the printer the printer coming leftside and showing hardware alarm
check ribbon
+0306ne -007 000
000000128 +0304
error in display. how to rectifie the problem
Jan 29, 2009 | Tally T2250 Matrix Printer
Nikon colpix S9
This is either an internal camera fault, in which case you might like to try and get it sorted under warranty if there is any left or its an actual lens error (normally caused by it being bumped) and would be costly to fix. If it has been dropped/bumped it may be covered under your household insurance, worth checking.
Jan 24, 2008 | Nikon COOLPIX L3 Digital Camera
TallyGenicom 6306 Matrix Printer Logo
402 people viewed this question
Top TallyGenicom Office Equipment & Supplies Experts
Kolbrun...
none
Raj Patel
Are you a TallyGenicom Office Equipment and Supply Expert? Answer questions, earn points and help others
