Question about SIM2 Grand Cinema C3X1080 3 Chip Full HD 1080p DLP Multimedia Video Projector Projector
How to reset sim2 c3x lamp
I replace the lamp and i want to reset
2 Suggested Answers
SOURCE: Replacing the lamp in SIM2 ht-200
OPen top case with four screws, two on back of the unit and two on the bottom. Remove six screws on lamp cooling fan, unpluf lamp (Brown Connector) unscrew lamp.
Posted on Dec 06, 2008
How to reset lamp hours on Sim 2 Domino 18
I am not familiar with your brand in particular but they are all pretty much the same. In the menu under settings you should be able to scroll to lamp settings. Under that category or something like that will be where you can reset the hours.
May 20, 2014 | SIM2 Office Equipment & Supplies
How to change lamp timer on sanyo plvz4
Hello
* Turn the projector ON, and press the MENU button to display the on-screen Menu. Select the 'setting' menu with point UP/DN button. Press '>' button to acess sub menu items.
* Select the Lamp Counter reset and press the OK or '>' button. "Lamp replacement counter reset?" will appear. Select "Yes" and then press OK or ">" button
8 Another confirmation dialogue box appears, and select "Yes" to reset lamp replacement counte.
** Do not reset the lamp replacement counter without implementing lamp replacement. Be sure to reset the lamp replacement counter only after replacing the lamp.
Dec 17, 2011 | Sanyo PLV-Z4 Multimedia Projectors
Replaced main bulb in front but lamp button on front of tv is still blinking and tv won't show picture
The lamp timer on the Hitachi projector must be reset whenever the lamp has been replaced. The "Lamp" indicator on the display will light red or the "Change the Lamp" message will display when the lamp timer needs to be reset. Hitachi recommends that the lamp timer never be reset without replacing the lamp and to always reset the timer when the lamp is replaced. The message functions of the projector will not function properly if the lamp timer is not correctly reset.
  • Turn the power on. Press the "Reset" button for three seconds until the "Lamp xxxx hr" message appears on the lamp timer on the bottom of the screen.
  • 2
    Press the "Menu" button on the remote control while the lamp timer is displayed.
  • 3
    Press the left arrow button. Select "0" and wait until the timer display clears.
  • If this was helpful a vote on the thumbs up for the free advoce would be greatly appreciated. Thanks
    Apr 04, 2011 | Hitachi 60V500 60" Rear Projection...
    We have a replacement bulb and I don't have a trap door to remove the old and install the new.
    WARNING! Sim2 does does not recommend that you change the lamp, they recommend that you contact a local dealer for service. PROCEED WITH CAUTION!
    If you still wish to proceed. This instruction is available at avsforum
    http://www.avsforum.com/avs-vb/showthread.php?p=17983282
    There are 2 recessed screws on the bottom near the front of the projector (really deep cavities). There are 2 on the backside of the unit. Remove all those and the top cover comes off. Inside you will see a fan held on by 3 screws (you will know it because there are 4 holes, but only 3 screws...that is normal). Remove those and take that fan module off. The lamp is then accessible.
    Good luck! __________________
    Jason C. Turk
    Consultations, Installations and ISF Calibrations
    585-671-2968
    jason@avscience.com
    Available for scheduled consultations...please contact the main office for details!
    Mar 31, 2011 | SIM2 HT380 Grand Cinema DLP Projector...
    How do you reset the lamp timer on a Sim2 Domino 60.
    I would need to know the serial number of the unit.
    You need to press 2 buttons on the remote then enter a five digit number to enter the service menu to reset the lamp counter.
    Mar 16, 2011 | SIM2 DOMINO D80 DLP Projector
    Our projector indicates that the light bulb needs to be replaced after replacing the light bulb once it still indicates that it needs to be replaced.
    This is the excerpt from the manual on how to reset the lamp life timer.
    Turn on the projector and use "Lamp Reset" after the lamp module is replaced.
    Lamp Reset: (i) Press "Menu" ?§ (ii) Select "Options" ?§ (iii) Select "Lamp settings" ?§ (iv) Select "Lamp Reset ?§ (v) Select "Yes".
    Jan 12, 2011 | Optoma HD65 DLP Projector
    Canon LV-S3 how to check hours on the lamp? do I have to have unit hooked up to an input source?
    Lamp Replace Counter
    Be sure to reset the lamp replace counter after Lamp Assembly is replaced. When the lamp replace counter is reset, the LAMP REPLACE Indicator stops lighting.
    Note : Do not reset the Lamp Replace Counter until after the projection lamp is replaced.
    1. Turn projector on, press MENU button to display the On-Screen Menu. Press Point left or right button(s) to move the red frame pointer to the Setting Menu icon.
    2. Press Point down button to move the red frame pointer to "Lamp counter reset" and then press SET button. The message " Lamp replace counter reset? " is displayed.
    Move the pointer to [Yes] and then press SET button.
    3. Another confirmation dialog box appears and select [Yes] to
    reset the lamp replace counter.
    This projector uses a high-pressure lamp which must be handled carefully and properly. Improper handling may result in accidents, injury, or create a fire hazard.
     Lamp life may differ from lamp to lamp and according to the environment of use. There is no guarantee of the same lifetime for each lamp. Some lamps may fail or terminate their life in a shorter period of time than other similar lamps.
     If the projector indicates that the lamp should be replaced, i.e., if the LAMP REPLACE INDICATOR lights up, replace the lamp with a new one IMMEDIATELY after the projector has cooled down.
    ( Follow carefully the instructions in the LAMP REPLACEMENT section of this manual. ) Continuous use of the lamp with the LAMP REPLACE INDICATOR lighted may increase the risk of lamp explosion.
     A Lamp may explode as a result of vibration, shock or degradation as a result of hours of use as its lifetime draws to an end. Risk of explosion may differ according to the environment or conditions in which the projector and
    lamp are being used.
    IF A LAMP EXPLODES, THE FOLLOWING SAFETY PRECAUTIONS SHOULD BE TAKEN.
    If a lamp explodes, disconnect the projector's AC plug from the AC outlet immediately. Contact an authorized service station for a checkup of the unit and replacement of the lamp. Additionally, check carefully to ensure that
    there are no broken shards or pieces of glass around the projector or coming out from the cooling air circulation holes. Any broken shards found should be cleaned up carefully. No one should check the inside of the projector
    except those who are authorized trained technicians and who are familiar with projector service. Inappropriate attempts to service the unit by anyone, especially those who are not appropriately trained to do so, may result in an
    accident or injury caused by pieces of broken glass.
    Dec 24, 2010 | Canon LV S3 Lamp
    Need to reset lamp. replaced lamp and installed new lamp.
    Press RESET, <, >, ENTER keys on remote within 5 seconds to reset lamp timer.
    Jul 29, 2010 | Sony VPL-CX86 Multimedia Projector
    Will the bits from the te-c3x fit my te-17
    Yes. New bits will fit old Hilti drills. Old Hilti bits do not fit the new (last 15 years) Hilti drills.
    Apr 07, 2010 | Hammer Set Of 6 Hilti Te-c3x Drill Bits...
    If I reset the timer before replacing the lamp,will the please REPLACE LAMP warning stop appearing???
    Replace Lamp first, then is reset timer come up Go to menu lamp Timer reset.Most of the time TV resets itself after installing New Lamp.
    Sep 21, 2009 | Sharp Televison & Video
    SIM2 Grand Cinema C3X1080 3 Chip Full HD 1080p DLP Multimedia Video Projector Projector Logo
    Top SIM2 Office Equipment & Supplies Experts
    jasbo
    jasbo
    Jerry Umali
    Jerry Kramer
    Jerry Kramer
    Are you a SIM2 Office Equipment and Supply Expert? Answer questions, earn points and help others
