Question about Danby Dishwashers
Danby dishwasher 1899W drain hose extension
I'd like to extend the drain hose, but I cannot find right fitting. For a inlet, thread size is 3/8, but for a drain, it seems a little bigger and not standard size. Please let me know if someone successfully extend the drain hose. Thanks.
SOURCE: Hose sizes
compactappliance.com has stats on the models they sell.   I think this one's hoses were 4 feet long.
Posted on Oct 15, 2007
meBNme
  • 334 Answers
SOURCE: Danby portable dishwasher 1805W hose
Lowes.
You can buy a brass nipple that will fit into the end of the hose, put a clamp on it. Put the now hose on, put a clamp on it.
You may also consider just replacing the entire hose from its original connection with a longer hose.
Lowes, HD should have whatever type of hoseing you need.
Posted on Dec 04, 2008
SOURCE: my danby countertop dishwasher won't drain
the problem has not been resolved. does not drain.
Posted on Jan 18, 2009
SOURCE: dishwasher stops after 10 minutes inlet/drain light flashing
I had the same problem on a 5 year old model. It was the main pump leaking from a perished seal causing the water protection microswitch to trip. This gives the symptoms you describe exactly. Parts cost from Miele was about £60 for a new seal. Fairly easy to fit.
Posted on Jul 21, 2009
  • 115 Answers
SOURCE: How to extend the drain hose Siemens SL34A006UC/22 Dishwasher
get another hose same diamiter and two hose clamps and a splice nipple from hardware store, cut hose to lenght with some extra insert nipple into both hoses and clamp with hose clamps make sure you get them tight.. use a metal nipple as a plastic one may crack when you clamp hoses
Posted on Dec 13, 2009
How to fit Inlet hose and Water discharge hoses online manual not clear enough
the hose connections should be 1/2 : NTP thread ( normal 1/2 tap and garden hose fittings ) the inlet hose comes from a pressure source so it will be a screw on fitting at each end
Y fittings are available from a hardware shop if you want to run hot water as well as cold but some machines heat their own water to near boiling for better hygiene and drying of dishes
next the same screw on fitting ( as on a tap)) should fit on the pump outlet
as the pump discharge is low pressure the fitting can have a hose tail ( plain piece with a barb at the end that the hose pushes over)with the hose pushed on and held in place with a hose clamp
the same for the other end but the tail should be part of the sink drain ( all fittings can be from a hardware shop in the garden hose section) S bend so push it on there , again with a hose clamp
check the size as the pump fitting may be 3/4 not 1/2 inch as drain hoses can be larger , but the principle of fitting is the same
Aug 20, 2016 | Beko DE2542FS 45 cm Silver Freestanding...
Danby portable Dishwasher advances from pre-rinse to dry and then beeps continuously and dry light continues to blink. Doesn't proceed, reset or stop cycle. Just continues to blink.
I actually found out (one of) the solution to this by accident. It could be the water source is not providing enough pressure
I purchased a Danby DDW1899W-1 and, using the connector screwed into my utility sink in the basement, I connected the water. When I tried to run a cycle, I had the same results (filled/emptied 4-5 times, beeped and went to dry cycle).
My alternate, long term plan was to put a Y-splitter (with shutoffs) on the hot water line for my washer, and have one hose go to the dishwasher when needed. I purchased a washer line hose from Home Depot and a 3/4" to Quick Connect fitting from Ace Hardware and then connected the dishwasher to this.
And, Voila! Problem solved!!!
To confirm this was the solution, after the first completed cycle, I connected back to the faucet and, once again had the fill/empty/beep/dry problem. Reverting to the split washer water feed, it was able to run the cycles properly (again!!!)
So you may just need a line that will supply more water pressure to the dishwasher.
Good luck and, hopefully, this solves the problem.
MP
Oct 18, 2014 | Danby Dishwashers
I've hooked up my danby to the faucet but the water leaks out the top how do i fix this?
You need to have the RIGHT couplings so that the inlet is secured correctly to maintain the right water pressure to the washer. A visit to the hardware shop, plumbing section could help a lot to get the right choice of coupling to mate the hose from the outlet to the machine. You can use teflon if the thread is too loose and makes a leak.
Dec 31, 2012 | Danby Dishwashers
Danby ddr5511r owner manual
Yess the DDR5511R has the drain hose connection inside the compartment where the water bucket sits. It is at the top right corner. You have to remove the water drawer to see it. At the right side of the unit (on the outside) is a small "door" that flips up so that you can feed a hose throught to the threaded outet inside. The drain hose is not supplied with this unit.
Mar 26, 2012 | Danby Dehumidifiers
Can you extend the exhaust hose on these danby air conditioners?
Generally, no. These units only have just so much fan pressure to exhaust the heat & moisture out of the house. Extending the hose could cause a draining & exhaust problem.
Jul 07, 2011 | Danby DPAC8020 Air Conditioner
My dishwasher draining but does not take water in
Hi
When the Dishwasher is not filling in, you'll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. Hope this helps... Please post back if you need more information.
Daniel
Jun 07, 2011 | Danby DDW1805W Designer Series...
Whirlpool dishwasher Leaking water
Hello there:
Troubleshooting Leaks
If the dishwasher leaks, and you know the problem is not related to tub overfilling, the pump, or inlet valve problems, the plumbing connections may be faulty. Most dishwashers are connected to the water supply with metal pipe fittings, and the leak could be at these fittings. If the fittings are threaded, tighten them with an adjustable wrench. If this doesn't work, chances are the threads are stripped or the fitting is cracked or otherwise damaged. In this case, replace the fitting.
Most dishwashers discharge used water through a pipe or a hose connected to the drain or garbage disposer under the kitchen sink. If the drain line is made of flexible hosing, it may have cracked from prolonged exposure to hot water. Examine the hose; if it's damaged, replace it. If the hose is leaking at its connections with the disposer or dishwasher, tighten the fittings or clamps at the connections, or replace the clamps. Also check for water leaks around inlet valves, drain valves, and anywhere you see flexible hoses and hose connections. Leaks at clamps can be stopped by tightening or replacing the clamps. Leaks in hoses can be eliminated by replacing the hoses.
I HOPE THAT YOU FIND THIS INFORMATION VERY HELPFUL
BEST REGARDS MICHAEL
Nov 13, 2009 | Dishwashers
Danby portable dishwasher 1805W hose too short. Where I can find a extension hose.
First cut the hoses off near where they would connect to the plastic quick adapter. Leave a little slack at 2-3 inches between where you cut and the metal clamp.
Take those two pieces you just cut off to home depot or lowes. Afterwards you can chuck them if you don't want them (I did read below). Take the metal faucet adapter with you too.
For the water supply hose (this is the smaller one) need a Hose barb adapter 3/8 Barb x 3/8 FIP
You need a clamp for this.
Get a plastic hose the length you want and the right barb to fit the drain hose and your new hose. You need two clamps. Also you might consider hooking it up to an external water pump depending on your situation. If the hose is long or has to go up above 36 inches then you may need a pump.
Then you want a standard dishwasher connecting kit. They have them from 4-6 feet, they come with a 3/8 brass fitting make sure you get that.
You also need plumbing teflon.
I also wanted to replace the faucet connector because the plastic one it came with leaked all over the place. I got a quick snap that goes to a garden hose. It fits the metal faucet adapter that came with the dishwasher. . I had to get a few connectors to go from the garden hose adapter to the standard dishwasher hose.
Installation. Take the clamp for the supply hose and put it on the hose connected to the dishwasher. Put insert the barb and tighten the clamp.
Put teflon on the 3/8 male connector that came with your standard dishwasher kit. Connect it to the Barb adapter you just installed. Connect your standard dishwasher hose.
Connect the other end. Its pretty straight forward just don't forget to put teflon on any of the thick threads.
From this you can pretty much figure out the rest with the drain hose.
If I were to do it again I probably wouldn't have used the standard dishwasher kit. I would have gotten a cheap plastic tube and connected it. Also if you're happy with the plastic adapter they gave you save the plastic connectors you cut off and you can use another 3/8 barb adapter to connect it to the other end of your extension hose either a simple plastic tube or the standard dishwasher connector.
Dec 04, 2008 | Dishwashers
Dishwasher leaking at the bottom of the door during operation.
hi If the dishwasher leaks, and you know the problem is not related to tub overfilling, the pump, or inlet valve problems, the plumbing connections may be faulty. Most dishwashers are connected to the water supply with metal pipe fittings, and the leak could be at these fittings. If the fittings are threaded, tighten them with an adjustable wrench. If this doesn't work, chances are the threads are stripped or the fitting is cracked or otherwise damaged. In this case, replace the fitting.
thanks....................
Sep 12, 2008 | Whirlpool Dishwashers
What is the size of the drain connector on a Danby DDR401 not a garden hose connector, that doesn't fit? THX Mike
Strange but true. I had tried to use a steel/brass connector from a garden hose. Although the same size as a normal garden hose connector when used with the nylon threads on the humitifier it simply would not tighten without coming off. I went to my local hardware store and tried plastic/nylon hose adapter to hose connector and it worked like a champ? Although it worked it to if overtightened (and not to much) would also want to fall off? it worked ok and everything is fine.....cheap engineering.
Jul 18, 2008 | Danby DDR401 Dehumidifier
Dishwashers Logo
237 people viewed this question
Top Danby Dishwashers Experts
Batista Saint
Level 1 Expert
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
