Question about Western Digital Caviar WD1600 (1600YD) 160 GB Hard Drive
MY WD 16OO NOT SHOW UP ON MY COMPUTER - Western Digital Caviar WD1600 (1600YD) 160 GB Hard Drive
    Sergeant:
  • 233 Answers
Check power and data cords , try to replace SATA cable, if your bios still cannot detect it, then the PCB controller board is defected and must be fixed or replaced with a working exact same one
Posted on Feb 16, 2012
2 Suggested Answers
kornho
  • 781 Answers
SOURCE: MY COMPUTER KEEP SHOW NEW HARDWARE NOT FOUND
you may have not properly set the jumpers on your new installed hard drive.
usually a computer will have 2 eide drive controllers where you would connect a ribbon cable. a ribbon cable has a middle connector and end connector and obviously another end connector that connects to the motherboard)
now you can connect upto to devices to that ribbon cable. most computers will have one device connected to the end connector (the hard drive) and no devices connected to the middle connector or sometimes they may have 2 device on the same cable: the hard drive on the end and a cd/dvd drive on the middle. others computers may have one ribbon cable for each device as computers usually come with 2 drive controllers (so you can connect 2 cables which means a total of upto 4 eide devices)
now, when you connect devices on 1 ribbon cable, the end device is the master device, the one the middle is the slave. to make a device a master or a slave you need to set a jumper. the jumper is usually located in between the ribbon cable connector and the power connector, the legend to know where the jumper goes to make it a slave or a master is usually on the label of the hard drive. you may need to check that label and with some pliers make the proper setting for that jumper.
on a new hd usually the jumper setting will be in master. so if you connected the hard drive on a ribbon cable that already has a master at the end it may not be detected. try to connect that master device on another ribbon cable that has no other devices connected and connect it on the end connector (not the middle one). if you have no other option but to connect it in the middle already having a master device at the end, set the jumper to on the slave position.
while you are at it. make sure you have your power connector and data (ribbon) cable properly seated.
if the caviar hd your are trying to install is an old hd and you know that you have the proper hd configuration and the cables properly seated, it is possible that no detection means hd failure.
Posted on Apr 04, 2010
WD 1tb hard drive only shows up as 10GB
schmuck, under my computer, what does that hdd show?
Apr 27, 2014 | Western Digital WD My Book Essential 1TB,...
When i connect my WD passport 1TB USB 3.0 on my television or my car, we can't read it. But it's ok on the computer. What can we do ?
what sort of computer do you have? mac is generally non-compatible with mainstream equip. does the hdd show up at all on the tv? If it does but you cant see any files, try removing the files from any folders, do you have any more info you can post?
Jan 01, 2013 | Western Digital WD My Passport Essential...
All my music that was on my wd are gone when i plug in my wd it doesn't show anything
Connect the WD Passport to a different computer, to see if YOUR computer is the problem.
If that does not help, any external disk-drive has two major components, inside the enclosure:
* disk-drive
* USB-to-disk-drive adapter
Open the case, and disconnect the disk-drive from the adapter, and remove the disk-drive. Connect it as a "slave" disk-drive in a desktop computer, to see if the files can be "directly" read from the disk-drive.
Oct 10, 2010 | Western Digital WD Passport 250GB Portable...
Apr 04, 2010 | Western Digital Caviar WD1600 (1600YD) 160...
My WD 250 GB drive, when plugged in initially, spins clicks and then goes silent. I believe that a virus has been moved to it and opened via an MP3 file my daughter down loaded. how can I get it to power...
Does it show up when you open my computer? If not, try unplugging it and plug it back in. Then check my computer again, if its not listed then it has probably died. Check the WD website for warranty info. I see allot of problems with WD external drives. Be it a bad hard drive, control boards, and or faulty power supplies. If it does show up you should be able to scan it. Good luck.
Aug 19, 2009 | Western Digital My Book Essential 1TB...
Wd 500 not showing
It may be in raw format. Go to Control Panel-Administrative Tools- Computer Management- Disk Management. It will show all your drives and their formats. You can format from there if you need to.
Char S.
May 30, 2009 | Western Digital My Book Essential Edition...
WD Passport Drive Lights Up But Compu Does Not Find the Drive
Does your drive make any unusual sounds like any of these: http://datacent.com/hard_drive_sounds.php ?
If yes then you got a problem - it's something mechanical with the heads.
If it sounds normal or doesn't spin up at all - try to connect it to another computer and if still no go - remove the internal drive from enclosure and connect directly to PC via SATA port.
Sep 29, 2008 | Western Digital Caviar SE WD1600AAJS 160...
No drive letter
When remove the drive do this steps properly first when you want remove the drive remove safley than remive it
Jul 13, 2008 | Western Digital My Book Essential Edition...
Western Digital Caviar WD1600 (1600YD) 160 GB Hard Drive Logo
138 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
