Question about Zebra LP 2824 Printer
I have zebra l2824plus i need solve problem flashin gred ain green led
  • wageeh makram Feb 20, 2012
    i need programming flsh memory
  • 669 Answers
Lp2844 sound is coming from printer while printing
Green light red
I've a Zebra LP2824 printer , It gives me the Green-Red error .. And the manual guide told me that's a problem with flash programming .. What can I do to solve it ??
Feb 12, 2016 | Zebra LP 2844 Thermal Printer
How di I set a new pattern on a proscan PLT7602G(UK-K)
You need the rest barcode scan it with your scanner it will beep and flash gred till it turns green then you scan other programming barcodes that came with your scanner or else you'll have to create the barcodes
Sep 04, 2014 | Computers & Internet
Green light red
I would re-calibrate the printer and see if that helps, usually the quickest and correct means to fix ya !
Calibrate Zebra Desktop Printer
Oct 05, 2013 | Zebra Eltron LP 2824 Thermal Printer
I use a TLP 2844 Zebra Printer, and i just cant get it to print. Each time i send a test print, the red light automatically comes on. I've tried the Dumb test to reset it to the manufacturer's...
You have to proceed with the callibration.
It's in the manual.
I think it's as follows.
Switch on the printer while pressing on the feed button.
Wait until the led stays red stable and release the button.
The printer will advance the labels and if everything is correct it will feed one label and the led will turn green.
Now your printer is ready for use with this label
Aug 05, 2011 | Zebra TLP 2844-Z Thermal Label Printer
How long does it take to charge. mine has a problem charging and operating. how do you know when it is charging?
the light on the front of the heli blinks green red green gred then when its fully charged it just blinks green. also make sure the tx is turn to the charge setting which is all the way down
Feb 21, 2011 | Air Hogs Reflex Micro Helicopter
Hi I have a gk420d zebra thermal label printer and I have been having a problem where the light on the printer continues to flash orange green orange green how do I go about sorting the problem out....
Try to calibrate the label length.
with the feed button pressed switch on the printer.
Keep the button pressed until you have Seven flash of the green led and release the button.
The printer will do a manul callibration.
After that when you press the feed button it should feed one label
Dec 17, 2010 | Zebra 2844-Z Thermal Label Printer
Hi, My printer model is TLP 2844.i m facing the problem in printing. The printer is hang after one or two lines printing and red LED are ON and I press Green button repeat same as before. Please solve my...
Solid red light. This indicates the printer is in an error state and will not print until the error is cleared. Check to make sure the printer is not out of labels or out of ribbon if it is a TLP model.
A solid red light will occur if
  • the printer is out of labels
  • the printer is out of ribbon ( TLP models only )
  • the printhead is open, not latched down all the way. Press down on the top cover of the printer to see if the error light clears and goes to green.
  • the ribbon spool is slipping on the ribbon spool holder on TLP models:
These 2 links will help you troubleshoot the problem:
https://support.zebra.com/cpws/docs/eltron/2844/28x4_rib_det.htm
https://support.zebra.com/cpws/docs/eltron/2844/2844_tsguide.htm
Click on this link. Or copy and paste it into your browser.
If I could be of further assistance, let me know.
If this solves your issue, please be kind to rate it.
Thanks, Joe
Mar 15, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Trying to setup a Zebra TLP 2844-Z on serial port
Two possibilities are the port configuration and the type of serial cable.
The printer has a feature that will try to match itself to the PC's configuration. Press and hold the feed button until the green status led flashes three times. While the led flashes send a ZPL format to the printer (hopefully you can do this through Design Pro by trying to adjust the printer or print labels, but the labels will not print). When the printer and PC are synchonized, the led changes to solid green.
If you can synchonize but still can't print, the problem might be the serial cable; not all serial cables will work. You should use a full null model cable (all pins connected except 1 and 8).
Sep 19, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Failure to initialize
better give it for service
Feb 25, 2008 | Zebra Z4M Printer
Zebra LP 2824 Printer Logo
176 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
