My Samsung J843 front load washing machine has blown a fuse (I think). Where and how can I find and replace it.
  • Ian Wilton Feb 16, 2012
    The belt broke , I replaced the belt, turned on the power and then heard a "pop". Then there was no power, no lights, nothing. I then had another look and noticed that when the belt had broken it had also taken out 3 wires. I suspect that when I turned the power back on that these wires have touched and shorted out something, hopefully just a fuse. Can anyone tell me if there is a fuse, and if so , where to find it.
Selvol
  • 115 Answers
SOURCE: door on samsung front load J843 washing will not open after wash
Kind of simple but had to ask. Is it on "child lock"?
Turn it off/on by pressing two buttons at once. The buttons should have dotted lines with a face connecting them.
Posted on Dec 17, 2008
  • 1531 Answers
SOURCE: How to replace the door diaphragm on a Samsung
remove the lid.then you need to take off the control panel move it out of the way.there will be a spring that holds the boot in place on the front where the door closes remove this spring the rmove the boot from the front panel then remove the front panel.there will be another spring that holds the boot to the drum.i have found it easy to remove the counter balance weights to remove and reinstall the new boot. i hope this helps sounds like alot but not real bad
Posted on Sep 19, 2009
SOURCE: Our samsung j845 front load washing machine won't
SAME THING HAPPEND TO ME, SORRY BUT YOU NEED A NEW WATERPUMP, THEY GO ON THEM WASHERS ALL TIME. I REPLACED 2 AND HAD MY WASHER JUST OVER A YEAR. NOW ITS THE DOOR
Posted on Sep 29, 2009
  • 353 Answers
SOURCE: LG front load washing machine - need to replace drain hose
It's jusy one clip go in from the bottom
Posted on Mar 20, 2010
SOURCE: How do I replace the oring gasket on a front
I can tell you how to fix one on the WF218ANW/XAA washer. Your model may be the same. You need to take the top panel off the washer by taking out two screws on back panel. You need to remove the control panel and place it on the top of the unit (it is attached with electrical cord). You need to talk out the detergent tray (press the clip in the middle). You then take off the front panel. it is not necessary to take off the door; however, to remove the panel you will need to remove the door latch mechanism on the inside of the door. To remove front panel, there are also two screws on the bottom of the unit. Once you have the front panel off, remove the old gasket by loosening the two springs rings. Pay attention to how the gasket is installed before removing. Replace gasket by installing inner portion first and replacing spring ring and tightening. Put all the parts back on the washer and install the outer portion of the gasket (with the spring ring). Samsung charges $130 to do this in my area and it's a pain in the neck.
Posted on Feb 12, 2011
How to install a belt on a samsung j843 front loader
Take the back panel off. You will see the motor pulley and the large drum pulley. Place the belt on the motor first and use the large drum pulley to pull the belt on. There is usually no adjustment, the belt is made a certain length and when installed it self tensions.
Jan 05, 2015 | Samsung Washing Machines
How do I replace the door seal of a samsung j843
Contact manufacturer and get a new seal for your make and model washer, then follow instructions that come with new seal.
Jun 02, 2014 | Samsung WF337AA Front Load Washer
Samsung j843 wont turn on
Check your breaker box... If not there I would check the cord to see if a powersurge damaged the cord or worse the machine utself.
Jul 15, 2012 | Samsung Washing Machines
Hi! My 7kg Samsung J843 Front Loader Washing Machine is not spinning at all. Makes a whirring sound but no movement. Any tips?
Hi, I've had this problem before. It was a while ago but it was either a broken belt or the belt had slipped from the correct position and needed to be put back on. It was under warranty and a service tech fixed it.
May 08, 2011 | Samsung WF337AA Front Load Washer
Door on samsung front load J843 washing will not open after wash
Nov 17, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
How to replace the belt on a Samsung J845 frnt loader washing machine
If you stand in FRONT of the washer, leaning over the top, the drive wheel is underneath the main drive motor, on the RIGHT hand side.  Loop the belt over the drive motor wheel, then over the main pully, and it should be good to go!
May 20, 2008 | Samsung WF337AA Front Load Washer
Active light flashing after wash
First check the fuse. It might be blown. if so, you can Call Customer Service to replace the fuse or replace it by yourself: lot of times you can buy replacement fuses at a local electronic or hardware store and they're easy to replace. Sorry i can help u more.
Dec 11, 2005 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
118 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
