Heater roller rolling very tight paper jam - Office Equipment & Supplies
  • 140 Answers
It could have the problem with teflon sleev (non sticky sleev) or lower roller in fuser unit. You can check any physical damage on it.
Posted on Feb 17, 2012
  • 54 Answers
SOURCE: My HP Laserjet 1000 printer
Cleaned the paper pickup unit gear & sensor, your problem will solve.
Thanks.
Posted on Mar 21, 2008
SOURCE: OKI c3200 Laser Printer...
There are 3 little black and white rollers under the cover on the back of the printer. They are pushed under the upper rollers. They should be on the outside of the upper rollers. Somehow they got wedged under the upper rollers. This should fix the accordian paper jam.
Posted on Apr 04, 2009
  • 133 Answers
SOURCE: Paper Jam
what you need to do is pull out the drum and remove the paper that you can see.
just pull out the drum unit harder.
Posted on May 23, 2009
  • 13433 Answers
SOURCE: paper jam ,no paper jam found Dell 1815dn
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 12, 2009
SOURCE: Paper jam at transfer roller with no paper jammed
Had the same problem after cleaning the rollers also. Technical help was rubish. In the end I found some clues n fixed it. There is a flag between the rollers n if it gets stuck and or in my case the spring behind it came off, then the sensor thinks there is a constant paper jam. Undo one screw and get inside n check the spring n flag. I done this. placed sping etc back in place, put it all back together n bingo. Be carefull not to drop the screw inside and make sure the cog is properly engaged or you will get a funny noise. I can provide pics etc if needed.
Posted on Jul 30, 2009
Paper jam
To fix this kind of error, remove the ink cartridge and turn the printer upside down and gently shake it.Check if anything comes out.If nothing goes, or you can't hear anything rattling around, get a piece of card stock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there. Open up the printer and clean the insides with a soft cloth and a brush. That should remove all the bits of paper inside.The teeth on the roller sides may have some dirt stuck on them which does not allow the rollers to roll freely and hence is as bad as paper jam. The idea is that the rollers do not roll whether because of paper or some dirt on the roller teeth. They have to be cleaned.
Thank you !!
Jul 14, 2010 | Canon SELPHY DS810 InkJet Photo Printer
Paper jammed message and alarm light remain on even though there is no paper jammed
Thank you !!
Jul 09, 2010 | Canon PIXMA MX310 All-In-One Printer
Paper jam tightly fan-folded above ink cartridge
Most likely a broken gear in the fuser (heater) assy. - will need to be replaced by a tech.
Feb 25, 2010 | Canon imageCLASS MF6550 Monochrome Laser...
Paper is jamming during printing process. Gets half way round and jams. please suggest solutions
There are rollers that the paper has to go between to be pulled forwards. When the rollers get dirty with paper dust, paper starts jamming. So you need to clean the rollers with a moist (not wet) soft cloth, Keep rolling the rollers manually and keep cleaning them. Then allow a few minutes to dry them up. And no jam after that.
Dec 10, 2009 | Dell 1100 Laser Printer
The printer is saying there is a paper jam but there is no paper stuck any way in the machine.The resume button does not resolve the problem.
The paper jam may not be very visible and obvious. It may be somewhere after the rollers. Some paper may be stuck in some place in the paper path. Open up the printer and clean the insides with a soft cloth and a brush. That should remove all the bits of paper inside. OR the teeth on the roller sides may have some dirt stuck on them which does not allow the rollers to roll freely and hence is as bad as paper jam. The idea is that the rollers do not roll whether because of paper or some dirt on the roller teeth. They have to be cleaned.
Nov 17, 2009 | Canon PIXMA iX4000 InkJet Photo Printer
Paper wrapped around the red roller
lift the cover remove all the cartridges and the drum unit slowly and carefully and slightly pull the upper side of the paper not the lowerside and if it is rolled completely you have to open the heater unit to remove if you donot have any technical knowledge do not try because the red roll you are taking is a costly thing,call the service technician and get it repaired that would be more cheaper.
Aug 08, 2008 | Samsung CLP-510 Laser Printer
Paper/tape jam
Get a pair of scissor and cut through the tape. IF it is rapped up too tight where you can't get a pair of scissor through it, then get an exacto knife or razor blade to cut the paper. Just remember not to press too hard so you don't cut through the rubber roller beneath it.
After cutting the paper, then press the paper advance and start taking the pieces of paper out.
Good luck.
If you still have problems, feel free to repost again.
Have a good day.
Mac =)
Mar 25, 2008 | Sharp EL-2196BL Calculator
Frequent Paper Jams
The only suggestion I could make may be obvious but my experience has taught me that you need to make sure the paper is installed correctly, especially with double ply paper. We have learned that the yellow receipt copy ply must be attached properly to the green roller so that the double ply paper from the roll feeds correctly through the print roller. Also make sure the double ply roll paper is not loose coming off the roll that feeds to the print roller.
Nov 20, 2006 | Ithaca (93+PRJ11) Matrix Printer
20 people viewed this question
jasbo
jasbo
