Question about Logitech G5
G5 sensitivity issue in TF2
I recently purchased a G5 corded mouse. And I love it. I have set up setpoint, and even updated it to the most current version. I am running XPsp3
The problem I have is that whenever I launch many full screen games, including Valve's Team Fortress 2 , my mouse5(default 'forward' in a browser) button acts up. If I press the mouse5 button in game, the mouse resets it's sensitivity, and the LED drops to the bottom of the three. and all three sensitivity settings default to the lowest. I have tried adjusting settings in TF2, setpoint, and the control panel, but none of this works.
Any help would be appreciated. Thanks
  • 2 more comments
  • Anonymous Dec 06, 2008
    same prob fro me. I use this button to spot in BF2 and everytime I do ir resets my DPI to default
  • Anonymous Jan 20, 2009
    i have noticed the exact same thing.. unfortunately, i have not found a fix yet.
  • Anonymous Mar 16, 2009
    Well I'm another user with the same problem. No solution yet
  • Anonymous Apr 16, 2009
    Same issue, fscking setpoint.
Choosing "Setpoint Implementation" instead of "OS Implementation" in Setpoint (the last tab) did it for me.
Posted on Dec 18, 2008
G5 keeps powering up for a few mins then switches off?
Thank you for contacting Fixya Support, I am glad to assist.
There are a few steps you can try to troubleshoot this issue:
Try a PMU Reset:
* Turn of your iMac if it is already turned off
* Disconnect all connections to the iMac except the power cord
* Now disconnect the power cord for approximately 20 seconds
* Reconnect just the power cable the keyboard, mouse and power cord, and then power your iMac G5 up.
* Check to see if the iMac boots up normally without power interruption.
* If the iMac G5 shuts off again, try these steps, another recommendation would be to remove all connections including the power cord, and lay the iMac G5 on soft cloth face down and with a philips screwdriver, remove the plate on the bottom of the iMac G5 where your RAM memory is located.
Before removing the RAM however, touch your hand on the metal boot to discharge any static current you carry for approximately 5 seconds.
Now remove each RAM card and then reseat (re-install) each card.
Restore the RAM card cover with your Philips screwdriver, reconnect your power cable, keyboard an
d mouse and turn on your iMac G5.
See if this second procedure helps if the first procedure does not work.
Let me know if this helps.
Regards
-Mactechtrainer
Sep 11, 2010 | Apple iMac G5 Desktop
The mouse appears to be on but the pointer on the screen does not move. The keyboard is still working. The re-set button does not correct the problem. Re-booting the computer does not work.
The same thing happened to me today. Somehow, something uninstalled my setpoint mouse software?!?!
While I was actually using the mouse?!?!
(it just stopped moving all of a sudden)
Don't ask me how/why this happened but I fixed it by unplugging the MX1000--both power and usb connection, plugging in an old serial mouse, rebooting the computer, opening mouse properties, going to the Mouse settings (in Control Panel), clicking the Setpoint tab, telling it to look for an update to the Setpoint program, letting it download and install the program automatically, then unplugging the old serial mouse, plugging in the MX1000 (usb first, them Power) and Voila'! Working as it should once again, even without a reboot. :o)
I love this mouse--perfect size, fast, programmable, accurate, long battery life, Perfect!
Aug 06, 2010 | Logitech MX1000 Laser Cordless...
G5 laser mouse freezing
Download the latest mouse driver from it's manufacturer's support website.
Jun 09, 2010 | Logitech G5 Laser Mouse Mice
Right Click Defected in-game
try switching the right click to another button using setpoint. if the button works perfect then it is the micro switch for the right click contact logitech. if it drops turn off setpoint and try the regular right click if that drops just may be a glitch in the game. check for mouse controls in the game to tune the mouse.
Jul 17, 2009 | Logitech G5
Left button of G5 laser mouse wont work
If you are talking about the left mouse button not on the sides, your mouse may have some buildup in the mouse on the sensor that says it was being touched. if you remove the screws and blow it out with a can of air, it may resolve the issue if not i would check the warranty and see about getting it replaced if there is no warranty. If you are talking about the mouse buttons on the left side of the mouse, you need to install the software from the following site. http://www.logitech.com/index.cfm/441/135&cl=us,en
I would follow the instructions and update the firmware and then install the setpoint software as well. If it still doesn't the mouse will need to be replaced.
Mar 06, 2009 | Logitech G5 Laser Mouse Mice
No audio sound after installing the keyboard software
when you loaded the software for the keyboard, the buttons on the keyboard for functions will be active, have you made sure that the mute key on the keyboard is not pressed 'on' to mute the sound?
Nov 18, 2008 | Logitech Cordless Desktop MX3200 Laser...
Logitech g5 mouse problems
Hey.
If you go into the logitech mouse setup program "Setpoint" there should be a section that tells the mouse what each button will do. It's probably got "Nothing" or something similar selected. See if you can find one that says "Right Click" or something along those lines, and select that, and press OK/Apply to save settings, and see if it changes anything.
Sep 22, 2008 | Logitech G5
Trying to bind my MX400 Mouse's forward and backward buttons inside of games. I've been using the Setpoint tool, tried binding them to keys on the keyboard with no success.
Try setting the buttons to "generic" in SetPoint and then assign fuctions via the game options.
From Logitech Knowledge Base:
The information in this article applies to the following products:
All Logitech Mice
Logitech SetPoint
Cause:
Most games that support a mouse will give you options to program or assign specific functions to various buttons on the mouse. These games normally look for generic mouse buttons when attempting to bind the mouse buttons to a game function. If the button is set to another function in SetPoint (such as Universal Scroll, Back, Forward, etc), the game may not see the mouse button as available to bind. This mainly affects buttons 3, 4, and 5.
Solution:
To resolve this issue, set the button you wish to program to a generic value in SetPoint. The following values should be used if you are having problems binding buttons in games.
Mouse Button 3 (The Middle Button/Scroll Wheel):
In SetPoint, assign this button as Middle Button or Generic Button.
Note for MX Revolution users: You must disable Logitech Smart Shift Technology or the Middle Button option will not be available in SetPoint.
Mouse Buttons 4 and 5 (Normally the thumb buttons):
In SetPoint, assign the thumb button(s) as Generic Button. Note that these buttons will still work in most browsers for forward and back. It is not necessary to assign these buttons to Forward and Back in SetPoint for this functionality.
May 15, 2008 | Computers & Internet
Error Message when trying to update SetPoint 4.00.121
GO TO SETPOINT DIRECTORY. DELETE FILES: LULNCHR.INI & LULNCHR.EXE. FILES ONLY RELATE TO AUTOMATIC UPDATE FOR NEW LOGITECH SOFTWARE. DELETING DOES NOT EFFECT FUNCTIONALITY OF SETPOINT.
Nov 03, 2007 | Logitech S 510 (967555) (DH967555)...
Logitech G5 Logo
1,740 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
