Question about Sony CDP-CE315 5-Disc CD Changer
Sony CDP-CE315 tray won't open
Push the open/close button and nothing happens but cd changes.
  • 4234 Answers
SOURCE: Sony CDP-XA30ES CD Player
Try opening up the top and cleaning the lens using a cotton swab and alcohol. If that does not resolve the problem, look at the back side of the optics and there should be a marking like KSS-xxx. This is the generic part designation. Any electronics supplier that supports Sony should have these.
Dan
Posted on Apr 08, 2008
VOTIT
  • 2071 Answers
SOURCE: Sony CDP-C505 door stuck open
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit. If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
Hope this may help;
Regards,
VOTIT
DON'T TO FORGET TO RATE
Posted on Aug 17, 2008
  • 15 Answers
SOURCE: jammed tray
Hi there, had a similar problem.
This unit is easy to open. the four screws on the sides and two i think on the back. When it is open you will have access to the discs in the machine. the last disc will probably be jammed between the facia and the caddy and will be impeding the carousel mechanism, once removed you should check the functions starting with eject, and again to cycle, load disc position 1 insert disc and check. this player i think rotated the disc on loading to a set position, would have to open one to check. hopefully the carousel is not out of sync and all is well.
Posted on May 01, 2009
JULIANFIX
  • 975 Answers
SOURCE: sony model # CDP-CE415 Tray alignment off when closed
Your goin to need to re align the tray , your gonna need the service manual for this purpose. Go to this link :
http://www.nodevice.in/manual/Sony/page15.html ,hope this helps you, AJ
Posted on May 07, 2009
satavlad
  • 405 Answers
SOURCE: My Sony CDP-C305 tray won't open. What should I
You will have to replace all belts, this unit all most 20 years old, probably could use some cleaning and re-greasing too.
Posted on Nov 02, 2009
I took out all discs. When I tell it to play a disc the table moves back and forth slowly about an inch. After a couple trys "Table Error" shows up. Both belts are old but on.
Tray will prolly need retimed after the belts slipped off the pulleys.
Procedure is with tray brackets removed lift tray in back then push open button to let the cam gear spin around to open position. Then let tray down and try to close it with button. Reinstall brackets and may take a few attempts to get that gear in the right position!
Dec 16, 2014 | Sony CDP-CX300 CD Player
Cdp-ce315 skips in songs
My answer here only concerns if you're trying to play burned audio CDs. Burn your audio CDs at the lowest speed (1). Try the JVC/Taiyo Yuden brand.
Nov 09, 2011 | Sony CDP-CE315 5-Disc CD Changer
How do you burn discs that will play on a CDP-CX 355?
Anything that creates finalized standard audio cd's will do (filenames= xxx.cda). On a PC that would usually mean copying the files from original CD's rather than 'ripping them, then 'burning' the project to a disc.
Jul 22, 2010 | Sony CDP-CE315 5-Disc CD Changer
Closed player without stabilizer.
I dont know this player, but you can unscrew the top of the housing and look if you can see the CD tray. Just giving a shot.
regards,
Gerard
Jan 11, 2010 | Sony CDP-XB930 CD Player
I have a denon 3500 cd player my cd is stuck
Open the top cover of your CD using a screw driver, (usually a star screw driver),. Then, manually turn the driving gear of the CD tray to free the stucked tray and until to the point where you can take the disc from the tray. Be careful so the setting of the tray and the laser eye is not change. Then, close the close the cover and play. You can send your e-mail thru fix ya to let me know.
Sep 25, 2009 | Sony CDP-C910 10-Disc CD Changer
Sony model # CDP-CE415 Tray alignment off when closed
May 07, 2009 | Sony CDP-C265 CD Player
Tray will not stop opening and closing
You have to open the cabinet ..with the power off!! with tray open look at the laser it should be in the cd home position..move the laser toward away from the spindle motor or turntable.you should see a switch with a cover over it,it may be black or white or clear..the is your laser home switch..with your finger or small screw driver gentely push the switch towards you or bend it towards you.with the cover off.plug the unit up.Watch the laser as it moves away from you towards the cd spindle, it it stops and the tray moves in, and the cd mech chucks .you should see the laser turn on and see the objective lens move up and down..if it does not..and it continues with your original problem the you have to retime the tray and loading gear..try this first..
Nov 02, 2008 | Sony CDP-CE335 5-Disc CD Changer
Sony CDP-397 Problems
The CD tray is driven by a belt below the tray or on the right hand side (I can't remember the exact model). The belt is probably slipping. Replace the belt and you should be fine. I think you should be able to replace the belt without removing the tray.
I'll look up the model tonight and update this if there are significant differences from what I already stated.
Dan
Mar 31, 2008 | Audio Players & Recorders
Sony CDP-CE315 5-Disc CD Changer Logo
98 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
