Question about Bosch Ovens
How to connect electric wire to oven and to wall. White box socket already on wall with cover underneath shows three wires.
aborcass
  • 2651 Answers
SOURCE: wiring oven microwave wall unit
sounds as if you need an electrician, the red is a "hot" lead and if not at the wall id say you have the wrong power supply at location
Posted on Nov 29, 2008
dgjtex
  • 405 Answers
SOURCE: i want to know if my wall oven is 110 or 220 .
Almost all electric oven are two twenty, but a voltage tester is a good idea, look at the breaker for it, if it is a double pool it probably is the red and white should both have 110 to the white wire, I hope this helps, God Bless.
Posted on Dec 27, 2008
jumptrout51
  • 3361 Answers
SOURCE: Admiral Clean-O-Matic oven: Power cord black red white ground?
Your terminal block has been by-passed .
Hook your black cord wire to the black screw on the terminal block.
Hook your white wire to the white screw on the terminal block. Hook the bare ground to the exterior ground screw.
The 2 wires that are wire-nutted together will have to hook to the red wire on the cord.(they originally went to the third connection on the terminal).
You will probably have to cut and strip the red cord wire and attach it with the 2 wire-nutted connections.
Posted on May 24, 2009
  • 10865 Answers
SOURCE: Gas oven electrical hookup issue
Hello. I can help you. What you have there at the wall is a circuit with 120 volts of power available. Your Gas oven requires 240 volts of power, thus the additional [red] wire. That said, they do not match up.
You will have to run a 240 volt wire from your electrical panel to rear of your stove opening with the correct circuit breaker in the panel, the correct amperage wire to the stove, the correct receptacle for the stove and the correct plug on the stove.
This is serious electricity here so do not proceed on your own as you could get seriously hurt or worse.
Posted on Aug 02, 2009
SOURCE: WIRING FOR AN ELECTRIC COOKER (I NEED A DIAGRAM) !!!
Trying to wire up an electric oven. Good with electrics, normally. Sounds stupid bus there are no holes to place the wires into on the oven panel. In other words not like the speces on a plug or on the main live circut on the wall. Where do I put the wires????
Posted on Oct 30, 2009
What is the ground & neutral wire for a JPK15 GE Oven?
Assuming this is in the USA there are 3 wires normally in a 240 volt circuit. A black, red and white. Sometimes there is a bare ground wire. The white wire and bare ground wire are basically the same.They connect to the same place in the electrical box. The red and black are your power wires. They would connect top the outside connectors and the white and bare wire (if supplied) would connect to the center connector.
Mar 22, 2015 | GE JKP15 Electric Single Oven
I have FP Double oven OD 302 the screen dark no light and oven as of no power, but breaker is on, please help
Pull the oven from the wall and look for a safety switch. See if it is off or the inside breaker trip. Check for corroded wires. Check for loose connection in the wall sockets. Sometimes those wires connected to the wall socket are so corroded that proper connections are not possible.
Jun 24, 2014 | Fisher and Paykel AeroTech Double - OD302M...
Hotpoint oven manual
I found that GE offer a specific plug which allows four connections:
Universal range power cord (4W / 4' / 40A) WX09X10035
You may need to find out if you have such a socket or how to produce such a socket.
Dec 18, 2013 | Ovens
I have white, black and ground out of wall, i have red, black, white and ground from oven, how do i connect
Unfortunately you can't. Your wall outlet is a 110V circuit (B-110V; W- common) and your oven needs 220V circuit to operate. Red - 110V; Black - 110V; White - Common.
You will need to installed a 220V, 30 AMP (10-3/w ground) homerun from your circuit breaker panel to the oven
Jun 21, 2011 | Whirlpool RBS305PR Electric Single Oven
JTP56 Electric Double Oven Dead after self-clean. Power Pigtail comes into back of top control enclosure in flex conduit. The three red,black,white conductors are spliced to 2 molex connectors. I am...
I doubt there is a fuse on the pigtail, it sounds like your black wire is grounded somewhere. Check black to red, if you get 120 or close to it, your black is shorted to ground.
Jun 07, 2011 | GE Profile JTP56 Electric Double Oven
I have a jenn-air wall oven it has a red wire a black wire a white wire and a copper wire but coming out of my wall is only a red/black and copper what dose the white wire go to please help thank you
IF you nhave a 3 wire feed fronm the house for your range, you connect the red and black for the power and then use the copper wire from the wall to connect to the white and copper wires from the range. All new construction must have a 4 wire feed to a range and dryer.
Oct 26, 2009 | Jenn-Air 30 in. Pro-Style Electric Single...
My Maytag Oven has 3 wires one red, one black & one white and then a copper wire. Will my oven model M5530DDs work with 220VAC? If so how can Identify which wire is which in electric terms?
red and black wires are the two "hot" power wires, the white is your "N" neutral connection and the bare goes to the appliance metel case as safety ground
Oct 02, 2009 | Maytag 30 in. Electric Single Wall Oven...
How to wire bosch oven pke691e02e
I guess you mean installing a plug and cord on the unit or do you mean hardwiring it from the breaker panel?Either way open up the access panel run your cord or wire thru the strain-relief and your white wire or smaller of the three wires goes to the "N"(neutral) terminal on the unit the other two wires,more than likely colored red & black go to "L1" and "L2" load 1 and load 2 those can be on either terminal after thats done arrange your wire and tighten the strain relief and replace your access cover
Jul 14, 2009 | Bosch Appliances 27 in. Wall Oven Electric...
I want to know if my wall oven is 110 or 220 .
Dec 27, 2008 | GE JKS05 Electric Single Oven
Moffat oven
U need to open/unscrew back and look at bottom connections to the left ( looking from the back) Earth green and yellow- Blue is neutral and Brown is live you probably need electrical female spade connectors for your end of the 'hard' wire !!
Jun 07, 2008 | Jenn-Air JJW8330D Electric Single Oven
Ovens Logo
19 people viewed this question
Top Bosch Ovens Experts
ashburton
paulcarew
Are you a Bosch Oven Expert? Answer questions, earn points and help others
