Question about Toshiba B-SA4TP Printer
Delete a uploaded file from Toshiba B-SA 4TP
I uploaded A file in Toshiba B-SA4TP Now I want to delete the file from the printer
I enable to print FRID tag with B-SA4T printer. Can you advise me how to enable RFID printing in the printer
You need to send the correct codes to the printer.
Use Caodesoft RFID or Batender automation to program the RFID
Else you should send the programming codes depending on the RFtags.
Apr 11, 2011 | Toshiba B-SA4TP Printer
NO SE POSICIONA LA ETIQUETA, AUTOMATICAMENTE Y CADA VEZ SE VA DESPLAZANDO, no se centra
Check that you have selected the right sensor in your driver and if the label size is correctly programmed
Mar 15, 2011 | Toshiba B-SA4TP Printer
How can i change the printing font size on a Toshiba label printing B-SA4TP_OM_EN?
What driver are you using?
To change the font size you have to re program your labels.
Check with the programming manual
Jan 25, 2011 | Toshiba B-SA4TP Printer
Printer is connected online with PLC and command is given through MMI but printer except for blinking is not giving the printout.
Hi
Your printers motherboard must be replaced it
the cost of it is to high
You better replace your printer
Pls vote me to keep me alive
Nov 24, 2010 | Toshiba B-SA4TP Label Printer
Lables getting printed alternatively
This is due to :
Wrong size of label.
You must give a page size and the gap size
It is very important to give the correct height and ga dimensions
The detecting sensor chosen is not the right one
Nov 27, 2009 | Toshiba B-SA4TP Printer
Can i get linux divers for Tosibha B-SA4T-T barcode printer
Contact Toshiba tec in france for linux driver.
Now available.
I wrote one based on cups ddk for them
Mar 03, 2009 | Toshiba B-SA4TP Printer
Toshiba B-SA4TP Printer Logo
66 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
