Question about Whirlpool GX5FHTXVA Bottom Freezer French Door Refrigerator
Water leaking from whirlpool gold refrigerator
We have had this fridge for a year. Small pools of water are leaking from underneath the freezer. Can this be caused by us being overdue on changing the filter?
  • Whirlpool Master
  • 4,654 Answers
When refrigerators leak water it usally is a sign that the defrost drain found inside the rear of freezer and behind the rear panel of freezer has become clogged with ice or gunk. Sometimes the pan below refrigerator has a crack and allows water to leak onto floor. Please click here=> Leaking Refrigerators Just What may Be HappeningYou will at times see water build up inside freezer bottom especially on bottom freezer refrigerators. This will take a little reading over to understand what may be happening. Click Here=> Leaking Refrigerators
I will be here should you have questions, Thanks Sea Breeze
Posted on Feb 16, 2012
  • 41 Answers
SOURCE: Whirlpool Gold Side by Side (GD25DFXFW02) is over
the drain sump under the evaporator plate may be blocked or you may require a new defrost element
Posted on Jun 12, 2010
arikrom
  • 528 Answers
SOURCE: Water is leaking into top shelf of Refrigerator - Whirlpool Gold
the drain in the freezer is clog make sure the drain from the freezer is clean all the way to the pan next to the compressor . you need to open the back wall of your freezer for that ( the inside wall) clean with buster (water pump)the drain is in the bottom middle of the freeze.
Posted on Jan 02, 2010
mamapie
  • 5 Answers
SOURCE: whirlpool gold side by side freezer not freezing but fridge is running
Your fan in the freezer is wearing out. When your food in the freezer is blocking the air, the motor is working too hard. After years of using, it needs to be replaced. Get a repair man in to replace with a new parts. My Fridge/Freezer was totally broken and I found this out because the ice was melting. It got fixed and now no problem.
Posted on Oct 16, 2008
EllaWatson25
  • 725 Answers
SOURCE: Whirlpool Gold refrigerator water leaking
If it's flooding, it's NOT the drain pan. It's probably the water valve has gotten stuck in the open position. Hope this helps!
Posted on Aug 21, 2009
BarrettDenCo
  • 1772 Answers
SOURCE: Refrigerator lights both not working.
Sorry to read about your problem, I hope this helps you out.
you lost a control board
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Posted on Dec 23, 2010
Fridge leaking water
The drain line may be misdirecting the defrost water so that it misses the pan or the pan may be damaged or mispositioned.
Dec 03, 2013 | Whirlpool Gold Series GB2SHTXTS (219 cu...
Small pool of water underneath Whirlpool fridge
There may be a water filter built in. Look for access lower front panel below door. recommend replace every year. They will leak when neglected.
Nov 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Sep 10, 2009 | Whirlpool ET1FTKXK Top Freezer...
Whirlpool gold side by side freezer not freezing but fridge is running
Oct 10, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool gold
hi thanks for the question it looks like the drain tube is clogged up you can clean this out first turn off fridge let thaw pull back cover off vacuum any dirt you find find the evaporation tray that's where the melted ice is suppose to go buy a small plastic hose to shove up the tube clean out should be ok the appliance doc
Sep 13, 2008 | Whirlpool ED2FHEXN Side by Side...
Hotpoint Ultima Fridge/Freezer keeps leaking underneath
yes this is probably the source of the problem - the defrost water doesn't flow down the drain.
melt the blockage with hot water till you get free flow down the drain - takes a bit of patience
tresilla
Aug 28, 2008 | Hotpoint FFA60 Bottom Freezer Refrigerator
Whirlpool GX5FHTXVA Bottom Freezer French Door Refrigerator Logo
7,404 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
