Question about Singer 7258 Sewing Machine
Singer 7258display screen shows dashes..machine wont respond to foot pedal or anything..no buttons affect machine
My machine only displays six dashes on the screen..I cannot select a thread option, it won't respond to the foot pedal. What on earth happened since last time I plugged it in?
  • Singer Master
  • 7,365 Answers
Sounds like part of the computer is going out & needs to be checked
Posted on Mar 27, 2012
SOURCE: Singer 2638 - three "beeps" when the foot pedal is pressed
when I stiches any cloth the thread gets lose on backside of cloth or some times it breaks how to solve is problem I am not understanding please help me.
Posted on Feb 03, 2008
SOURCE: foot pedal and thread guide
Same thing happened to my CE-200. It would only stitch one stitch at a time or else it would run full speed. My husband made an adjustment through a small hole on the back of the pedal and it now works much better. The adjustment hole apparently allows you to set the sensitivity of the electronics inside the pedal. He turned it slightly toward the + direction. It took a couple of small adjustments to get it to work nearly normal again.
rbwinter@wbsnet.org
Posted on Jul 14, 2008
  • 27 Answers
SOURCE: Singer 1725
The hook drive gear is seized and requires lubricant ,this is the gear right behind your bobbin case I believe you can access it from the rear ,I hope this helps
Posted on Jan 10, 2009
JeremySew
  • 65 Answers
SOURCE: foot pedal not working
You can purchase that singer sewing machine foot control here:
http://www.sewingpartsdirect.com/foot-control-w-cord-singer-979314-031.aspx
Posted on Apr 21, 2009
  • 5 Answers
SOURCE: singer 2010 doesn't want to stop
I have a Singer Merritt 4530.  I don't know if the foot pedal works the same way on your model, but on mine it is held together not by screws or latches, but simply by white plastic rods that serve as hinges.  These rods have a hole drilled in their center, presumably so some special tool can be used to pull them out.  Lacking a special tool, I glued a nail into the hole, and once the glue dries you can pull the nail and pull the rod out with it.  The rod is about an inch long and held in place merely by friction - no glue or screw threads.  Once one rod is removed, you should be able to slide the pedal off of the rod on the other side, though that might have only worked because some of the plastic housing was cracked on mine.  If you don't want to take the time to test that, just glue a nail into both rods and pull them both out.
Once you get the pedal open, mine had a giant white cylinder that looks kind of like a battery or a fuse.  This thing was getting very hot the longer the pedal was left plugged in.  I read on many web sites that this object can cause overheating or short circuit the pedal so it's always sewing.  It's called a suppressor and can be safely thrown away.  I haven't found an explanation for precisely what it does or why it can be safely thrown away, but I theorize it's a surge suppressor and that most modern wiring isn't going to surge too much.  I got rid of it and the pedal still works and doesn't overheat.  It may be safest to plug the machine into a surge-protected power strip once the suppressor is gone - just my theory.
Posted on Jun 16, 2009
Hi, My Quantum 9960, needs the bobbin refilled, but the machine shows me an icon of the foot paddle, then an icon of machine and conect? cord. The cord is connected, I've tried it 3x. Don't know what to...
Is there an up arrow in the icon you see? What you describe could be the Release foot controller pedal icon. Take your foot off the foot pedal. See the trouble-shooting page on page 102 of the manual. The manual is available from Singer here: http://www.singerco.com/uploads/download/5b9200a32cfd31ffc30b8d29fd195a57dff4a9e3.pdf .
You are supposed to take your foot off the controller (or press Stop) after winding a few turns of thread on the bobbin. Trim the excess thread above the bobbin. Then step on the foot controller or press Start. Release the foot pedal again when the machine stops winding the bobbin. See page 28 of the manual for the procedure.
I hope this helps. If you do not have the Release foot controller icon displayed, please add a longer description of the icon or indicate which icon from the trouble-shooting section of the manual that is closer to the one you see. If you have released the foot controller and the icon persists, then something may be wrong with the control pedal. A replacement control pedal is ~$35; see http://www.sewingpartsonline.com/singer-9960-quantum-stylist-parts.aspx .
Jul 21, 2017 | Sewing Machines
What is the most likely cause of a Quantum 9960 that powers on but won't start? Both foot pedal and button tried a few seconds after each hear a beep and screen says to release button/pedal.
could be the foot pedal is not making the right contact
could be a computer problem
or a motor problem
if the problem persists, having the machine checked would be a good idea
Mar 03, 2016 | Singer 9960 Quantum Stylist 600-Stitch...
My Singer Sewing Machine runs too fast. Is there a way to slow it down?
what type of machine do you have. I have two that I operate with buttons and it has a little slide button to speed or slow down I don't know why it should run to fast with a foot pedal because you control the speed with your foot you may want to check to see if there is any trash that has gotten in the foot and somehow not allowing the foot to come back up
Sep 10, 2015 | Singer Sewing Machines
Foot pedal not working
Well, you are definitely getting power from the electric plug in.
Let's do some diagnostic work. Do you hear anything when you press the foot pedal? Any hum? Did you happen to leave it in bobbin winding mode?
your machine doesn't have a "sew" button for use without the pedal. So please rotate the hand wheel toward you as you press the pedal. Did the motor take over and sew?
If you know someone with a meter... have them test the pedal. (they will place probes on/in the part that plugs in which tests for shorts, etc.) If that tests ok... then we know it's something more than the pedal and it will need servicing by a Singer Tech.
Aug 27, 2012 | SINGER 7470 Sewing Machine
Trouble shooting a Singer Athena touchtronic 2000 Sewing machine I have a Singer Athena touchtronic 2000 Sewing machine. The light comes on but the needle will not move when you step on the foot pedal. ...
Yes it's true, most parts are not available for this machine anymore. You might try to push the red reset button on the bottom of the machine. Also make sure that the reset button is not being depressed by anything that the machine is sitting on, and that the reset button pushes in and out freelyl.
Apr 27, 2011 | Singer 3116 Simple
All power and motor seems ok but needle shaft doesn't respond to foot pedal ... nothing happens! Help! Can't find model number but it is electric Singer 70/80's
It is probably the foot pedal. There should be a plate that gives the model # and Serial #. You can call Singer at 1-800-4singer and order or go on their site and find it by serial #. There are also sites
like www.sewingpartsonline.com and see how much a universal foot pedal is and go from there. Usually, they are about $30.
Mar 19, 2011 | Singer Sewing Machines
Machine wont stop once started.
your foot pedal is just like an accelerator , lifting and pressing the foot increases and decreases the speed ,but if this does not happen ,,change your foot pedal
Mar 18, 2010 | Singer Sewing Machines
Singer 7258 Sewing Machine Logo
82 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
