Question about Hunter Humidifiers
Need wiring diagram for Hunter Humidifier 33282
Wiring diagram for Hunter Humidifier 33282
  • 3 Answers
SOURCE: Humidifier control .
if humidifier was wired into thermostat circuit for power instead of seperate transformer , this can happen. you need to see if you voltage going to the solenoid valve. if you do , and it isn't opening, the valve is bad . this is assuming that it is using a # 50 relay to come on only when the fan runs . . make sure the water valve is open
Posted on Dec 28, 2007
SOURCE: Model 760 Humidifier - need wireing diagram please....
I logged on to the April Aire website and found the wire diagram i needed.
they have really good information on all their units. thanks.sc.
Posted on Aug 19, 2008
SOURCE: Aprilaire 700 Humidifier Doesn't work
check this website for a wiring diaghram Aprilaire 700 Repair Parts & Supplies
http://www.arnoldservice.com/Aprilaire_700_repair_parts_supplies.htm
Posted on Dec 08, 2008
mastatech
  • 478 Answers
SOURCE: I have a Honeywell HE360A
Peice of cake: You run the white to sail switch the to common 2. Yrun thr re to humistat switch then to the white on the control board or conact us www.airenergyexperts.net
Posted on Mar 14, 2009
  • 11 Answers
SOURCE: does anyone know where i
I hope this helps.
http://www.aprilairepartners.com/products/category/humidifiers
Scroll down towards bottom of page. I looked under the heading "CURRENT RESIDENTIAL MANUALS", and clicked on "Humidifier Model 600 Series Safety and Installation Instructions Template with Model 60".
Posted on Dec 28, 2010
No "C" on furnace power strip for humidifier power "C"
Hello, since this humidifier has a transformer installed with it, you bring one wire from humidifier to Humidistat and then a wire from humidistat to Transformer. You will need a current sensing relay to turn the humidifier on and off with the Furnace cycle. I will attach a link for a wiring diagram for your Humidifier http://docs.electronicaircleaners.com/aprilaire_700a_installation.pdf
Nov 15, 2012 | Aprilaire 700 Humidifier
Have two Hunter humidifiers - model 34357-about 5 years old #1, fan just quit running. All else seems normal. #2, Unit starts running and then stops with the humidity reading at max. Since the...
This is the manual for your de-humidifier. It lists the part number for the power and fan control switch and it states they have a 5 year warranty.
http://www.hunter-humidifiers.com/manuals/34357.pdf
This is their link for support:
http://www.hunterair.com/suppo.95rt
They have a msrp on the unit at 84.95. What I wuld do is definately check into the warranty ting with them and I'm sure you could probably salvage one ot of the two units. Replacement parts may not be cost effective. You can test the motor from #1 in #2 and, if it runs, you know it has to be a switch or a start capacitor, etc. I guess it all depends on how much tinkering you want to do. I would think there is a good chance there is a wiring diagram for the motor somewhere inside the case or on the motor. Good luck.
Dave
Jun 05, 2011 | Hunter 34357 Humidifier
I installed a honeywell 360a flow thru humidifier, and a new transformer. I have power thru the wires to the fan cover. Also the humditstat clicks when turned on. The fan does not work and the solenoid...
Posting a diagram of how you wired the installation will help the both of us figure out what the problem is. You don't have to accept or rate this solution in order to post comments or information. But accepting a solution will not stop you from communicating with the expert. You can still communicate with the expert as long as you need assistance regarding the issue stated herein.
Jan 11, 2011 | Honeywell HE360A1027 Whole House...
I have a Honeywell HE360A Humidifier and everything is installed now I am trying to wire it. The wiring diagram is very vague. Does anyone know how to correctly wire this? I have the humidifier, a...
Jan 31, 2009 | Honeywell HE360A1027 Whole House...
I have a Honeywell H220a humidistat and have everything hooked up, but I cannot get the wiring to work. The wiring diagrams do not include the selanoid that comes with the humidistat. Any suggestions. The...
Thanks for your question Mike,
The wiring for your humidistat and solenoid are fairly simple, you will need 24volt t-stat wire, you have the two wires at the Solenoid, one wire goes to the terminal board at the furnace, it connects to the (c) or common terminal, the other wire connects to one leg of the humidistat, run another wire from the other leg of the humidistat, to either the HUM terminal on your furnace circuit board, make sure its not a 120v leg, should say in the owners manual, if if is or your not sure, connect that same leg to the (w) terminal at the furnace, this way it only comes on in heating mode, some models need a second 120v-24v transformer, but you would still wire it through the same way, only exception is that you have to hook up 120v to the transformer, and route your wiring like I told you above but through the transformer to complete the circuit, hope that helped you out Mike, please let us know, thanks again, mr.grzz
Jan 10, 2009 | Honeywell HE220A1019 Whole House...
Humidistat installation question
I suppose you are looking at the do-it-yourself model. Depending on the wire that is run up to you Regular Thermostat from your furnace. You may have to run a seperate line for the Humidistat. A digital thermostat that does Humidity and Temperature is recommended. Or you could just place a Humidistat near the furnace room. A wiring diagram will come with the Humidifier discribing the different ways to wire it.
Jan 09, 2009 | Honeywell Power Humidifier: Furnace...
Dec 07, 2008 | Aprilaire 700 Humidifier
Humidifiers Logo
Top Hunter Humidifiers Experts
jdthefixer
ka4iup
ka4iup
Vernon Taylor
Are you a Hunter Humidifier Expert? Answer questions, earn points and help others
