LG Quantum (16 GB) Smartphone Logo
heather Posted on Feb 16, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Camera can you reverse the view on the camera
Anonymous
Level 3:
  • Master 380 Answers
  • Posted on Feb 16, 2012
Anonymous
Master
Level 3:
Answers
380
Questions
0
Helped
102656
Points
1118
I have a CA-531 backup camera. ToGuard is brand. in my Car or Truck, not a PC The monitor will only work if someone walks in front of the camera.
it was installed wrong !
on the reverse wire, (at transmission TRS PRNDL wire)
in reverse it turns on.
RTM read the manual this is clear, lost the manual did you?
the maker lost the manual too I see (USA OEM site)
1 youtuber said, clear as day , view in Reverse only (general view)
find no manual on earth using google even makers site.
sad no?
Apple iPad selfie works but can not take a regular picture everything else works
In "camera" mode, click on the white "camera" icon. This will reverse the camera's view angle from your viewing screen to the camera's aperture screen on the opposite side.
Navara tekno reverse camera always dark how do I lighten the view
I know of no adjustment for this. It must be defective or the camera lens is dirty.
When put in reverse the image is up side down.
How to Reverse the Image on Backup Camera eHow
EVERYTHING YOU NEED TO KNOW ABOUT REAR VIEW CAMERAS
After installing a backup camera on your vehicle, you need to reverse the image so that the image on the screen matches that of your rear-view mirror. The orientation must match so that the driver doesn't get confused with two conflicting images. The nature of the camera's technology is that its image will be recorded un-reflected, but the mirror will display a reflected image. Fortunately, the engineers who designed back-up cameras thought of this and created simple controls for you to change the orientation.
Read more : http://www.ehow.com/how_6641139_reverse-image-backup-camera.html
2helpful
My pioneer double din screen says ''Caution, screen image may appear reversed''...how can i solve this problem?
As you know, you can use this DVD AV Receiver with a rear view camera. And also it can be installed to switch automatically from the video to rear view image when the gear shift of the car is moved to Reverse position.
But it is important to use a camera which outputs mirror reversed images.
Otherwise the screen image may appear reversed. And this means that you will see the rear view reversed in the monitor. And that may cause accicent and injury.
To solve this problem, first check your rear camera whether it has the capability to output mirror reversed images.
If it is, then check the wire connections of the rear camera using the operation manual or ask a technician.
Also check the settings of camera polarity if it is set properly or not in the system menu when connecting the rear view camera.
You can download the operation manual (pdf file) by clicking here.
I hope this helps.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
4helpful
2answers
What does the green/white wire connect to on my jensen vm9312hd? Says it is reverse +
Rear View Camera Input: The VM9313 features a composite video input and a green/white wire lead attached to the harness for connection of a rear view camera. If a rear-view video camera is connected, the unit is on, and the TFT monitor is retracted inside the unit, the TFT monitor automatically moves into the viewing position and Camera modes is selected upon shifting into Reverse gear. When shifting into Drive gear, the TFT monitor is retracted back inside the unit. If the monitor is already in a viewing position and in display mode, the monitor automatically switches to Camera mode upon shifting into Reverse. When the reverse driving stops, the monitor returns to its original input display mode. You can choose for the monitor to display a Mirror mode image or a Normal mode image from the rear-view camera.
2answers
Image in viewfinder reversed left to right
is there a setting for "mirror"? if so turn it off
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
