Question about Garden
Rover i4000 Q start
Hi,My Rover i4000 Q start lawn mower is not starting, have checked the spark plug and have changed it for a new one, still no spark. It really sounds like it wants to turn over but, alas no it wont. It is 5 month's out of the warranty, Nice clean unit as all my tools are any way can you help in solving this problem This problem has just started. Thanking you for any advice. Bill.
  • gangesboy65 Feb 18, 2012
    For the time being i have bought another type of Pull start mower. I know there are some good advice out there,which one to try or many to try. To look at the problem, mower it's in brand new condition that's what annoys the you know whats out of me but i shall not let this get on top of me the many answers the more chances of it working again. Thanks to all and everyone for help.
Try tapping the front of the engine with a hammer I do this with mine and it starts 1st every time..!!
Posted on Feb 26, 2012
    Sergeant:
  • 176 Answers
You will need to pull the top cover off the mower and follow the spark plug wire to the coil. when you pull the rope it turns a circlular drum that when it rotates near the coil will create a spark. you need to take some sand paper and clean the drum and the coil. there is probably some rust or film causing no spark.
hope this helps.
Posted on Feb 16, 2012
vincob
  • 718 Answers
SOURCE: Rover lawn mower is not working
Make sure you get a spark, Clean the gas tank, maybe even go as far as cleaning the carb, make sure everything is like new and start it up.
Posted on Sep 26, 2009
  • 211 Answers
SOURCE: my lawn mower will not turn off
Hi
From under the flyweel comes a wire(probably black).check it.It is connected with the off position of the trotle.
best regards savumihai71
Posted on Dec 22, 2008
defadad
  • 351 Answers
SOURCE: I have a Rover easy start lawn mower with a
They could be on a metal plate around the carbi and tank
Posted on May 11, 2009
rwvanlue
  • 486 Answers
SOURCE: how to prime a rover i5500 engine lawn mower
Fuel Starvation - Float Bowl Carburetor
1) remove air filter assembly
*be cautious of tearing the mounting gasket. If it does tear, you HAVE to replace it. It is part of the priming system
2) remove the float bowl fastener. This is the main jet
3) carefully remove the float bowl, the rubber o-ring/gasket will not be able to be used if it is removed, you WILL have to replace it
4) using a spray 'carb cleaner'
spray up thru the center of the carburetor
spray and clean the main jet with cleaner and 'tag' wire
(tag wire is very thin, and can be used to clean the hole in the center of the main jet)
5) clean any debris from inside the bowl or carb body
6) re-install bowl and center bolt, air filter assembly
*if you need gaskets, your Briggs dealer can supply. The kit is cheaper than individual gaskets, and all the parts needed to finish the above repair are in the kit.
Posted on Nov 25, 2009
SOURCE: replaced blades duel deck high
Try leveling your deck beacuse it sounds like the right hand side of the deck is too high causing the high spots. move the mower to a flat surface, drop the deck to its lowest point and measure the deck height with a tape measure.
Posted on Nov 27, 2010
Service and repare rover lawn mower b&s motor 200 series
Clean fuel bowl and fuel jet see what happens.
Mar 08, 2015 | Garden
Hi I did a tune up ,changed and checked every thing I done ..too I changed the oil ,oil filter ,gas filter air filter ,got a new battery changed the plugs there new too...even a new belt new key ...but...
Spark and gas??? Must have both. Pull spark plug wire and check for spark. If you have spark, check gap on spark plug. Check the bowl on carburetor. loosen bowl screw to see if gas is coming out. If you have gas coming out, carb needs to be taken off and cleaned or rebuilt.
Oct 11, 2013 | Cub Cadet Street Sign- tractor lawn riding...
Lawn mower wont start. changed air filter, spark
Does it turn over? If it does, what happens? Does it sound normal when its cranking? I need more information to help. Is it a push mower or riding mower? Does it start by key or pull start?
May 01, 2010 | Poulan Garden
Cannot find the sump plug on rover i4000 push mower
It should be under the deck above the blade. Look for a square headed pipe plug. hope this helps you
Jan 16, 2010 | Garden
Engine will not start, no spark
Try taking of the engine shroud and cleaning the magnets on the fly wheel. Also clean the two little prongs that are really close to the fly wheel. Use fine sand paper or emery cloth. Then check the spark plug wire for rust (clean if any). Try replacing the spark plug if it is old.
Let me know if this helps.
roundo4
Aug 22, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Jun 21, 2009 | Garden
My lawn mower doesn't start
Hi Every 2 stoke engine needs three things to run:Fuel+oil/air mixture in correct proportions,compression and ignition.Remove the sparkplug and see if the spark appears when the piston in the cilinder is at top death point(almoust),if not check the flyweel key(not to be sheared).Check engine"s sealing(crankcase gasket,cilinder gasket,seals-crankshaft,carb gasket).Also the mufller(not to be clogged),disassembly the carb (check and clean it),fuel lines and fuel filter (check and clean them),gas cap tank vent(not to be clogged),the air filter.Please let me know. best regards savumihai71
Dec 22, 2008 | Troy Bilt 5.5hp Self Propelled Mower
My lawn mower doesn't start and when it does, smoke comes out of exhaust
you may need to change the oil and/or empty the old gas and replace it with new.
This thing happens when you don't take care of your lawn mower for too long.
Sep 01, 2008 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
579 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
