Question about LevelOne VOI-7000 - VoIP phone - SIP, SIP v2
Polycom ip 7000 conference phone disconnect during call after 3 minutes
Connected with EPABX of Alcatel Lucent
I'm trying to connect a polycom vsx 700 to this conference room. Same unit is able to connect to local scopia xt5000 with no trouble. If dialing 135.11.119.48 it times out without connecting to an
hello
This is not a dialing but trying to connect to the IP address setup in the system. Start editing the IP address giving the one that you would have already allocated to the device in the Router (i.e. 192.168.1.99) and then reboot it. It should connect then automatically.
Best regards
Dec 16, 2014 | Polycom VSX 7000 Video Conference
What is polycome?
Polycom is a company that provides ip phones and Video conferencing equipment
Mar 06, 2011 | Polycom VSX 7000 Video Conference
Polycom 7000 series System Settings
Web into the unit by it's IP address and go to "Home Screen Settings" and check "system".
Mar 18, 2009 | Polycom VSX 7000 Video Conference
Polycom VSX 7000 will not turn on
Hopefully the problem was resolved. Call Polycom to see if it under warranty. Call me at 415.659-8178 if it is not. Maybe I can help. David
Feb 17, 2009 | Polycom VSX 7000 Video Conference
Polycom Soundstation 2 disconnects during calls
this does not appear to be the sound station problem it appears u ve connected this system behind an epabx extension .if yes the extension is programmed for a call disconnection time of 15 mins.ask ur epabx programmer to change it to infinite
Feb 02, 2009 | Lands Phones
Can You View what the Camera sees through a Computer?
i will connect with microsoft netmeeting just dial in your polycom ip adderss to it and it will connect if you have given private ip address to polycom then connect with private ip if given with public then with public ip adress .
Jul 31, 2008 | Polycom VSX 7000 Video Conference
Flash timing setting for polycom sound station
You need to update the flash timing on your Soundstation to match what is on your PBX.
Check out http://knowledgebase.polycom.com/kb/search.do?cmd=displayKC&docType=kc&externalId=10964&sliceId=SAL_PUBLIC_1_2&dialogID=2075496&stateId=0%200%202071605 and http://knowledgebase.polycom.com/kb/search.do?cmd=displayKC&docType=kc&externalId=11208&sliceId=SAL_PUBLIC_1_2&dialogID=2075496&stateId=0%200%202071605
Jun 06, 2008 | Polycom SoundStation Premier EX Audio...
Dropped Conferences
You need to upgrade the code on your system. This happened to me and upgrading the code fixed it. Good luck!
Oct 24, 2007 | Polycom VSX 7000 Video Conference
LevelOne VOI-7000 - VoIP phone - SIP, SIP v2 Logo
70 people viewed this question
Top Levelone Computers & Internet Experts
micky dee
Prashant M
Prashant M
Are you a Levelone Computer and Internet Expert? Answer questions, earn points and help others
