Question about Electronics - Others
A problem occurred during hardware installation. Your new hardware might not work properly.my pen drive 8GB
Hi! can u help me? i bought usb flash drive yesterday hp 8gb and it's properly working, when i create bootable usb im in diskpart in command promp and my computer got freeze not responding, im in a computer shop that's why i remove my usb flash drive and just went home. when i plug the usb it says a problem occured during hardware installation. i know there is the connection about diskparting the usb yesterday. i troubleshoot my usb flash. i go to device management and uninstall the usb drive and scan plug and play, but its not working it always show the yellow mark. even i update the driver its not working. what should i do? i hope u can help me :( here is my email just incase u have a solution for me. rk_mrace@yahoo.com Thank you very much!
Posted on Aug 12, 2014
  • 27,725 Answers
Click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if you need more help with this post a reply
hope this helps you
Posted on Feb 17, 2012
SOURCE: Pen Drive is Not able to write the data
i had purchased a pen drive of Moser Baer AZ-601USB device. previously it was working good, but since last 3 days i could not open my pen drive..it asks for formattin. i have formatted it , but after that it says your pen drive is write protected. so i could not open and use my pen drive....
so plz solve my problem to open my pen drive.
Posted on Dec 20, 2008
rytech uk
  • 85 Answers
SOURCE: pen drive problem
Ok, firstly which versoin of windows are you using.
Secondly, does the pen drive have any lights on it that come on when it is inserted into a usb socket?
Posted on Jun 20, 2008
pankaj_dic
  • 1250 Answers
SOURCE: problem in 4 GB Pen Drive of Transcend JF V10
check your drive on some other usb port, if it gives the same massage, then replace it
Posted on Nov 03, 2008
Romy_Dec
  • 56 Answers
SOURCE: pen drive
Hey There,
You are getting ur problem because ur WIN32.EXE Application is not wrking properly. To repair or come over ride of this problem is
You need to restore your system using System Restore tool. Follow The following Steps to Restore ur system:
For restoring your system do the following:
1. Go to Start -> All Programs -> Accessories ->System Tools
and select System Restore
2. Go to next window, Choose the restore point that is available, remembering ur system was exactly what you wanted for (choose the point remembering, at particular point ur system was good and wasnt giving u any error while u install any software).
3. Select that restore point by reading the description (The software you've had installed).
4. Click next to restore.
Note: Your system will restart after choosing the restore point and clicking next. It takes some time to restore.
Thanx.
Gimme your Acknowledge by rating me.
Romy
Posted on Jan 06, 2009
ichimaru_gri
  • 6 Answers
SOURCE: sandisk 8gb pendrive not detected
You can try using another usb port, or it might be that other things conncected to the usb are interfering with it. Try disconnecting things attatched to other usb ports (check in the back of the computer) but be sure that they're not important before you go ripping out cords.
Posted on Aug 21, 2009
When i plug in my TRANSCEND 4GB USB DRIVE,i got the connecting tone,connecting msg(found new hardware:mass storage device And finnaly problem occured during hardware installation,your new hardware might...
Hi Friend, As you have mentioned that you got the message after installation that it will not work properly, i would like you to check that since you are connecting the USB 2.0 into your system, i would recommend you to please check if the USB ports of the system are compatible with 2.0 version of USB drives
Dec 08, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Problem for Transcend 4GB JetFlash 110 USB 2.0 Flash Drive My pen drive gets heated up and not recognised by computer. what can i do. pl. help
when i plug in my TRANSCEND 4GB USB DRIVE,i got the connecting tone,connecting msg(found new hardware:mass storage device And finnaly problem occured during hardware installation,your new hardware might not work properly).ssuppose if i unplug it i can hear the removing tone.PLs help me to resolve this.........
Aug 24, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Pen drive problem
Click Start, click Run, type compmgmt.msc, and then click OK. 2. click Disk Management. The Disk Management window will appear.
3. On this disk management window, you can see some drives including the portable drive. Right click on your portable drive and click change drive letter and paths.
4. assign a new drive letter which is not used by any of your drives in My Computer.
5. After assigning the new drive letter your pen drive will show in my computer.
Feb 25, 2010 | Transcend 8GB SSD, 2.5- Inch, IDE, SLC...
My 8GB pen drive was working on my laptop Now suddenly it has stopped working It is working fine on my desktop
Just Check Your Pen drive If It Ok Then Goto System Properties>>Device Manager >>Usb Controller >>Scan Hardware Change!!
Check USB Install Or Not If Not THen Install It!!
Feb 05, 2010 | Transcend (589307) Media
Kingston 8gb pen drive problem
format the pendrive...need to remove virus
Dec 08, 2009 | Kingston Technologies 512MB DataTraveler I...
Sandisk 8gb pendrive not detected
Aug 21, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Hardware problem
unplug it go to add an remove . remove it. put you cd in after you restart . install driver remove cd after its done power off install your hardware power up pc will now see new hardware wait untill its done ... this will work for you..Good Luck
Aug 15, 2009 | SimpleTech SimpleDrive Pininfarina 500GB...
Pen drive drivers
if its the windows XP you are using make sure you add the service pack 2 . then the prob wont occur.
BUt the prob you are having is rare, service pack installation or reinstallation should mostly do the job for you.
Apr 10, 2008 | Computers & Internet
MP3 DEVICE
DO you have media player 10 or 11 installed?
Nov 07, 2007 | Samsung YP-K3 MP3 Player
Electronics - Others Logo
882 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
