SOURCE: Motorola FV200 Walkie-Talkie
Scanning Channels
Use scanning to monitor channels for transmissions or to find someone
in your group who has accidentally changed channels.
1. Short press MENU until the "Z" appears. The current setting
On/Off will flash.
2. Press either + or – to turn On or Off.
3. Press the PTT to confirm or MENU to continue set up.
Here is a link to the manual http://www.motorola.com/mdirect/manuals/FV200_userguide.pdf
SOURCE: motorola walkie talkie t4508
http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T4500_User_Manual_E.pdf
This one should be a very close match. The T4508 is a foreign version of the T4500.
SOURCE: charging walkie talkies
This is more for "mshtexas" than the OP but I'm sure there may be others out there wondering the same thing. The power cord that comes with this unit has a 9.0v output at 200mA with the center pin being positive
SOURCE: walkie talkie symbol stuck on cannot remove it
The symbol you are describing indicates you have the radio on HI power. It will not go away unless you reprogram the radio to LOW power, or change to a low power channel. Here is a link to the user guide: http://www.motorola.com/staticfiles/Business/Products/Two-Way%20Radios%20-%20Unlicensed/_Documents/XTNiD/Static%20Files/XTNiD%20Manual%20EN.pdf?localeId=252
Best regards.
SOURCE: how do you use dora walkie talkies?
No certain what exact Motorola model the Dora radios are, however, here is a link to the Disney radios user guide: http://www.giantintl.com/ContentManage/manuals/Moto/Disney%20Adventure%202way_User_Manual_E.pdf
And this is a link to the list of user guides: http://shop.giantintl.com/Manuals.asp?offset=30
TalkAbout radios generally operate similarly, so the manual should be of assistance. Check to see your radios are set to the same settings as one another. Static is a sign of a low or defective battery. Try new batteries, or trade the batteries between radios to determine if the batteries are the cause.
Best regards.
