Question about Coleman Heating & Cooling
I need a wiring diagram for a Coleman Heat Furnace Model 6524A901
Gigatech
  • 259 Answers
SOURCE: REPLACED 10KW FAN/HEAT SEQUENCER AND LOST TRACK OF WIRING
Could not find the E1Eh-020HA but found the E2 series
http://www.nordyne.com/Literature/707716c.pdf
http://www.nordyne.com/Literature/901a.pdf
Hope this helps. :]
Posted on Dec 13, 2007
SOURCE: Wiring diagram needed RV rooftop coleman
Motor1258,
Thanks for the response, to be more specific, the nine pin connector was damaged, but I was able to connect the wires back to main unit panel. I am ready to hook to the hunter thermostat and do not know which wires to connect to. This is my problem and I do not want to short something out. Hope this helps, I want to get it installed again. Thanks again for caring....Jerry
Posted on Aug 16, 2008
morefords
SOURCE: have a coleman evcon furnace
Your centrifical swith is stuck open on your blend motor. I found that removing the blend motor housing and spinning the stuck motor (from setting over the summer) will get you out of a bind ,.but you may end up needing this centrifical switch (locatedon the bottom of the blend/fresh air intake) motor replaced.
Posted on Nov 07, 2008
  • 659 Answers
SOURCE: Anyone have a wireing diagram for a nordyne E1EH-015HA
Intertherm does not offer a wiring diagram for the E1 series anymore. So I have included a link to the E2 series. They are very similar and you may find this service manual helpful for whatever problem you may be having.
http://www.nordyne.com/literature/359a.pdf
Posted on Apr 11, 2009
motor1258
  • 6674 Answers
SOURCE: I need the wireing diagram for a coleman rv/ac
If it is mechanical controls at ceiling, this link should be it. It's a service manual, but has what you need and more.
http://www.rvcomfort.com/pdf_documents/1976141_copy.pdf
If that's not yours, try ( http://www.rvcomfort.com/rvp/rvp.php ) and go to technical information and search for yours.
Posted on Jul 07, 2010
How do I wire a Coleman Evcon 3500A916 furnace Model
Wiring Diagram for a Coleman Furnace - RV-Coach Online
www.rv-coach.com > Discussion Forum > RV - Insurance
... Furnace, Mark, 9-12-07. Need wiring diagram for coleman furnace Model # 7700B856 .... Amanda, 11-10-11. I need a wiring diagram for a Coleman evconpresidential model 7956c856 ... Need wireing diagram for coleman 3500a916 ... More results from www.rv-coach.com
FURNACE Diagram & Parts List for Model eb15b Coleman ...
Dec 22, 2015 | Coleman Heating & Cooling
I need the wiring diagram for a colemen presidential. 7700 heating only furnace model 7700B series 856
Try this link: https://www.google.com/search?newwindow=1&client=firefox-a&rls=org.mozilla:en-US:official&channel=sb&tbm=isch&q=wiring+diagram+for+a+coleman+presidential.+7700+heating+only+furnace+model+7700B+series+856&spell=1&sa=X&ei=2BxgVNeTL4GzyAT114DQAw&ved=0CBsQBSgA&dpr=1&biw=1280&bih=661#facrc=_&imgdii=j33zYJKetrRZNM%3A%3BQwlvLKBRQkbPMM%3Bj33zYJKetrRZNM%3A&imgrc=j33zYJKetrRZNM%253A%3Byv4vNEhfvEIQ1M%3Bhttp%253A%252F%252Fmobilehomefurnace.com%252Fzcart%252Fimages%252Fart150.bmp%3Bhttp%253A%252F%252Fmobilehomefurnace.com%252Fzcart%252Findex.php%253Fmain_page%253Dproduct_info%2526cPath%253D767_768_769%2526products_id%253D14583%3B1154%3B766
Nov 10, 2014 | Heating & Cooling
Wiring diagram for gas furnace COLEMAN
Alvaro, can you give me the model number of the Coleman Furnace you are needing this diagram for?
Dec 20, 2013 | Cars & Trucks
Hook ignition wire
This is a typical 5 wire setup. The colors can change depending on the person installing the system, meaning if the installer liked using BLUE for cooling instead of YELLOW, that's how he hooked them up. If YELLOW wasn't available, they could of used BLUE or BLACK, and visa-versa. But, the wiring below is the most common. If you have a heat pump system, it will be slightly different. Hope this helps!
R- Red- Power 24v
G- Green- Fan
W- White- Heat
Y- Yellow- Cooling
C- Blue- Common
Dec 07, 2013 | Coleman Heating & Cooling
Coleman wiring diagram
I can't find any manual but i found a site where the same model was installed in a 1971 mobile home. Their unit had been tampered with and is a fire hazzard.
Nov 08, 2013 | Heating & Cooling
The wires in my gas furnace have been messed with and the heat side of it no longer works. I need help getting it to work properly.
type in the manufacture name to get to that site, and somewhere type in the name & model #'sand search wiring diagrams..!
Sep 08, 2008 | Coleman Heating & Cooling
Heating & Cooling Logo
44 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
